Old 16th April 2007, 14:12   #221  |  Link
@J-Wo
What was the length of the entire pathname?
Guest is offline
Old 22nd April 2007, 13:06   #222  |  Link
CruNcher
CruNcher's Avatar
I have created an Avisynth source filter for AVC/H.264 streams. I would appreciate feedback and suggestions for the most important features to add. At this point it is fast and reliable but limited in functionality. I need your guidance to prioritize future work. I also ask to be notified about any streams that are problematic with DGAVCDec.
Blue-Ray .m2ts with AVC doesn't work (feature request)
It is about Time
CruNcher is offline
Old 22nd April 2007, 16:05   #223  |  Link
Do you mean the demuxed elementary stream or the m2ts file itself? Obviously the latter doesn't work because I haven't added container support yet. I will be adding transport stream support first, followed by MP4.
If the elementary stream is not working, please post a link to the stream if you want support.
Guest is offline
Old 22nd April 2007, 17:43   #224  |  Link
CruNcher
CruNcher's Avatar
no no everything fine with the elementary stream (except that the slider seems to sometimes flip back/forth @ when seeking with the mouse hard todo fine seeks that way with the mouse useing the arrow buttons is precise and works fine hmm) i meant container support
huh and it crashed after bringing the main window into the back and then onto the front again boom dgavcindex terminated itself, only happens with a Stream loaded. Jep happens allways with every kind of elementary loaded in the preview window
It is about Time
CruNcher is offline
Old 22nd April 2007, 17:53   #225  |  Link
Oops. I'll fix that.
Guest is offline
Old 22nd April 2007, 19:27   #226  |  Link
bob0r
Pain and suffering
bob0r's Avatar
Blu-Ray
BLU-RAY
REPEAT AFTER ME:
BLU-RAY BLU-RAY is without an E!
(in dutch it rhymes, but oh well )
bob0r is offline
Old 22nd April 2007, 19:35   #227  |  Link
CruNcher
CruNcher's Avatar
okay BLU-RAY (will forget it in 2 secs anyway yeah dementia is something bad)
It is about Time
CruNcher is offline
Old 23rd April 2007, 14:42   #228  |  Link
tomos
not sure if this has been mentioned previously, but i found that dgavc doesnt like AVC files named *.mpv.
it scans fine but just times out loading. renaming the video to .h264 and editing the filename in the dga file so it ends with .h264 works fine. no re-scanning needed
tomos is offline
Old 24th April 2007, 00:41   #229  |  Link
I'm not able to duplicate this. What do you mean by "times out loading"?
Guest is offline
Old 24th April 2007, 01:16   #230  |  Link
tomos
at the moment i am messing with the hd-dvd movie 'babel'.
i am doing this now.
i run the file babel.mpv through dgavcindex. runs fine. no probs. then the probs start.
I drag and drop the AVS file onto vdub and it sits there for aaaages. task manager shows the cpu use going from 5-25%.
after a while (takes longer depending on the length/size of the source file i think) i get this error from vdub (for the trailer. took about 5 mins. would take 20+ for the actual movie)
VirtualDub Error
Avisynth open failure:
AVCSource: Could not open one of the input files.
(L:\Babel\extra\Trailer.avs, line 2)
OK
After this i change the extension of the file from movie.mpv to movie.h264. i change the extension in the dga file as well. then drag and drop onto vdub and bingo. works fine.
if you still have probs replicating it, i suppose it could be this particular clip maybe?
tomos is offline
Old 24th April 2007, 01:41   #231  |  Link
Please give me the AVS script and a fragment of the source stream that causes the problem. Thank you.
Guest is offline
Old 24th April 2007, 02:01   #232  |  Link
tomos
took 5 megs worth of the video and included the files in a rar file here
http://www.mytempdir.com/1306335
replicated the same issue with this sample
thanks
tomos is offline
Old 24th April 2007, 05:07   #233  |  Link
Still works fine for me.
Can anyone else duplicate it with the files supplied?
Guest is offline
Old 24th April 2007, 06:47   #234  |  Link
Trahald
Wewkiee
Trahald's Avatar
if i use his files i get the same, 'avcsource:could not open one of the input files' errors.
i tried to drop the file directly into dgavcindex and i get '
Warning
slice_qp_delta makes slice_qp_y out of range
Hit Yes to continue with further popups, hit No to disable them.
Yes No
warnings..
renaming the extension made no difference... dunno if it has to do with where he cut the file? the warnings pop up pretty much immediately
...yeah...but...why on earth would I compare apples with apples?
Trahald is offline
Old 24th April 2007, 13:47   #235  |  Link
Do you mean just to the warnings? Did it make it possible to open the AVS in VirtualDub.
I cannot duplicate this, everything works fine for opening the AVS. Yes, I have the warning popup but it is harmless.
There is nothing in the code that even looks at the filename extension!
Guest is offline
Old 24th April 2007, 20:59   #236  |  Link
Deinorius
Najarenthur
Deinorius's Avatar
I get an error with DGAVCIncx a4. By indexing it shows this warning (attachment). For a second it works, then it stops. But it uses still 50 % CPU, which is much with mine.
Indexing with a3 und decoding with a4 .dlls works fine.
Deinorius is offline
Old 25th April 2007, 00:30   #237  |  Link
For the hundred millionth time, if you want support give me the unprocessed input stream, or a fragment thereof.
Guest is offline
Old 25th April 2007, 00:41   #238  |  Link
tomos
i'll give it a go at some point on some other systems and retry. it does seem a little weird.
tomos is offline
Old 25th April 2007, 01:25   #239  |  Link
Only thing I can think of is that you are inadvertently using DGAVCDecode.dll from alpha 3. You did update both DGAVCIndex and DGAVCDecode, yes?
Guest is offline
Old 25th April 2007, 02:31   #240  |  Link
tomos
crap. sorry, i missed the update.
sorry about wasting your time
tomos is offline
