Old 16th March 2007, 21:44   #181  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
ffdshow incorporates a MSVC-buildable version of libavcodec. Very helpful for debugging, but I know a couple of months ago it wasn't quite buildable anymore. I've seen a few MSVC compatibility messages go through svn since then, not sure of the exact status now, I'll test when I get home. That might be simpler to use than the raw ffmpeg version. (MSVC can't do any of the inline asm, though.)
foxyshadis is offline
Old 16th March 2007, 22:18   #182  |  Link
Inventive Software
Turkey Machine
I think libavcodec was recently made MSVC buildable according to the SVN changelog...
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld
Inventive Software is offline
Old 16th March 2007, 23:40   #183  |  Link
ToS_Maverick
x264 Tester
just a small bug report:
- if the disk is full, dgavcindex continues, without an error, but the file is incomplete, because the disk is full
ToS_Maverick is offline
Old 17th March 2007, 11:12   #184  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
Okay, it builds fine in VC 2005. Can't test whether the VC 2003 project is up to date. If you want to check it out, it's under sourceforge project ffdshow-tryout, path /trunk/src/ffmpeg, and it will build the dll by default in /trunk/bin. Of course, you can strip out all the extraneous codecs.
It has some dependencies on ffdshow, mainly replacing its codec naming/ordering etc with ffdshow's, and some ffdshow-specific hooks, so it's worth checking the whole project out, or at least the trunk branch. Any patch you make against it should be applyable back onto the svn ffmpeg code.
Old 17th March 2007, 14:30   #185  |  Link
Is there a free version of VC 2005 that will build it? I still use VC 6.0
Does it also build the libs needed to dynamically link the DLLs?
Guest is offline
Old 17th March 2007, 15:23   #186  |  Link
orbitlee
@neuron2: VC2005 Express edition is free.
http://msdn.microsoft.com/vstudio/express/support/faq/
orbitlee is offline
Old 17th March 2007, 17:48   #187  |  Link
Eastermeyer
Happy Easter!
Eastermeyer's Avatar
I would appreciate a version based on the reference implentation by JM , because of the PAFF-Support and the Accurancy.
Sorry for my terrible English!
I am from Germany.
Eastermeyer is offline
Old 17th March 2007, 18:48   #188  |  Link
Inventive Software
Turkey Machine
I still use VC 6.0
Dinosaur!
VC Express is indeed the way to go for a free kit. I think they were doing the VC2003 binaries a while ago too, not sure if they're still kicking around MSDN somewhere.
Old 17th March 2007, 18:57   #189  |  Link
lucassp
it would be nice. but that will take a lot of time to optimize. i don't want to even imagine how fast it will run on my A64 3000+@2,34GHz
lucassp is offline
Old 17th March 2007, 19:05   #190  |  Link
bond
the reference is damn slow. i doubt people would be happy reencoding their stuff a whole week
Ogg Theora | Ogg Vorbis
bond is offline
Old 17th March 2007, 19:12   #191  |  Link
Well yes, but so was the reference MPEG2 decoder that developed into the heart of DVD2AVI, DGMPGDec, etc. I'm still mulling it over.
Guest is offline
Old 18th March 2007, 14:42   #192  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
Yeah, the libs will show up in ./Release (Debug, whatever), and not the bin folder, though.
Old 19th March 2007, 14:19   #193  |  Link
OK, thank you. I have managed to build it using VC 2005. Now it seems sensible to just make DGAVCIndex buildable under VC 2005 and then incorporate the AVC decoder code directly, so that no external DLL is necessary.
Then add PAFF.
BTW, active SPS/PPS management is something of a nightmare for random access.
Guest is offline
Old 19th March 2007, 17:20   #194  |  Link
Hans Ohlo
Hans Ohlo's Avatar
Then add PAFF.
.... oh 'then' :/
Hans Ohlo is offline
Old 20th March 2007, 18:45   #195  |  Link
bob0r
Pain and suffering
bob0r's Avatar
@neuron2
Only if you care:
Video: MPEG4 Video (H264) 960x1088 [Video] <-- AR 16:9
(from canal ad on hispasat 30 west)
(maybe bond is interested too, how crappy it looks)
But for DGAVCDEC testing purposes:
Canal.AD.ts 23mb
(playback: mpc internal .ts splitter works, haali splitter says: Unspecified error, reported to Haali)
bob0r is offline
Old 20th March 2007, 19:27   #196  |  Link
bond
Originally Posted by bob0r View Post
Only if you care:
yeah gimme gimme. at the start bbc also used that res
bond is offline
Old 20th March 2007, 20:03   #197  |  Link
SeeMoreDigital
SeeMoreDigital's Avatar
Canal.AD.ts 23mb
Jeez....
That sample contains six different "Program" sectors. Only the last one (Program 900) contains the video and audio stream.
SeeMoreDigital is online now
Old 22nd March 2007, 09:21   #198  |  Link
G_M_C
I want to make this post just to thank you, and compliment you on your excellent work.
I've just used DGAVCIndex to succesfully replace the video on my DVD with a, resized but very much improved, AVC-720p version My DVD went from OK to sublime after the replacing (50i PAL to PAL anamorphic 25 fps progressive). So for me the tool works like a charm.
Now only VC-1 is left to do, as far as i can read around here, and all HD-possible formats can be input in AviSynth succesfully (i.e. without using DSS() ).
So
G_M_C is offline
Old 22nd March 2007, 13:20   #199  |  Link
Glad to hear it. But there's still a lot of work to do. Right now I am in the midst of upgrading to VC++ 2005 and pulling in libavcodec code so that I will be able to develop and debug transparently, without the hassle of DLLs built in a different environment, etc.
Guest is offline
Old 27th March 2007, 03:13   #200  |  Link
Just a little progress update in case you're wondering what is going on.
Recall that I am in the process of moving to the ffdshow-tryouts based code that will allow me to build the DLLs using Visual Studio and later integrate the code directly, eliminating the DLLs. That will greatly simplify further development and debugging, especially adding PAFF support.
Converting DGAVCIndex and DGAVCDecode for building under Visual Studio 2005 Express was straightforward. (I also did it for DGMPGDec.)
The first problem I ran into was that the ffdshow-tryouts build of ffmpeg's DLLs includes only a stub for libavformat, whereas I was heavily relying on it. So I had to find a way to use libavcodec for H264 decoding without libavformat. I have now accomplished that successfully.
The next step is to convert from the DLLs built in the pseudo-linux (MSYS) environment to the DLLs built in the ffdshow-tryouts environment. At that point everything will be buildable and debuggable using Visual Studio. After that I will integrate the decoder directly and eliminate the DLLS. Then proper development of needed functionality will resume.
Guest is offline
