Old 6th October 2009, 19:54   #1201  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Upload's complete now -- took a bit longer than anticipated.
Latest MKVToolNix is v56.1.0
Mosu is offline
Old 6th October 2009, 19:59   #1202  |  Link
Palikrovol
Palikrovol's Avatar
Now it works.
Thanks a lot.
Palikrovol is offline
Old 12th October 2009, 01:37   #1203  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
Mosu
Hi. Today I get this error message (mkvtoolnix v2.9.8):
If you really need it, here is a sample. This is a mp4 file with AAC-LTP audio. File was muxed using Haali's directshow muxer 1.9.63.13 There is 10 second silence at the beginning.
Keiyakusha is offline
Old 12th October 2009, 07:33   #1204  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Yeah, but I will not fix this, sorry.
Mosu is offline
Old 12th October 2009, 15:28   #1205  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
No problems. I created this file for testing only.
Old 14th October 2009, 22:47   #1206  |  Link
Snowknight26
Why is MPEG-2 ES muxing so slow? Compared to the speed of AVC/VC-1 muxing, I'd say its about 10 times slower. I can mux a 20GB AVC ES to MKV in under 3 minutes, whereas a 20GB MPEG-2 ES takes ~20 minutes.
Snowknight26 is offline
Old 15th October 2009, 08:06   #1207  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Because the code is not particularly optimized, I guess.
Mosu is offline
Old 17th October 2009, 10:30   #1208  |  Link
Selur
Selur's Avatar
Small question about the '-aac-is-sbr' option, I got a bunch of aac streams and wanted to mux them but I'm not sure if they use sbr or not, so will it cause a problem when I enable the option even for non-sbr streams (when remuxing later to mp4)
Notice: Since email notifications do not work here any more, it might take me quite some time to notice a reply to a thread,..
Selur is offline
Old 17th October 2009, 10:44   #1209  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Probably, but I don't remux to MP4, so I honestly don't know.
Mosu is offline
Old 17th October 2009, 13:21   #1210  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
Is there any reason why we need to choose fps when muxing h264 elementary streams? For example DGAVCIndex seems to know what fps should be here and there...
Old 17th October 2009, 13:51   #1211  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
There's obviously is no "frame rate" stored in an elementary H.264 stream on container-level, simply because there is no container
AFAIK H.264 does have a way to indicate the frame rate on stream-level, but this may not be too easy to detected, as it requires parsing of the bitstream.
As opposed to simply reading one field from the header of the container file...
LoRd_MuldeR is offline
Old 17th October 2009, 14:09   #1212  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
Yes, but mmg knows sar values and sets display dimensions according to it. Isn't some stream parsing is needed for this too?
Old 18th October 2009, 10:04   #1213  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Not every stream contains the frame rate, and I never got around to implementing the feedback needed between mkvmerge and mmg if the frame rate is actually found. And no, I will not do that now either; I'm pretty much in "bug fixes only" mode at the moment.
Mosu is offline
Old 20th October 2009, 13:10   #1214  |  Link
Forteen88
Herr
Thanks. The problem should be fixed in http://www.bunkus.org/videotools/mkv...-172-setup.exe (still being uploaded; should be done in eight minutes).
Mosu, where can I find your latest builds (like this), in portable version?
BTW, thanks a lot for mkvtoolnix.
EDIT: Thanks for the links, although I should've found it out myself (by modifying the link I quoted :P)
Forteen88 is offline
Old 20th October 2009, 13:13   #1215  |  Link
XhmikosR
http://www.bunkus.org/videotools/mkv...ate&order=desc
My Specs
XhmikosR is offline
Old 20th October 2009, 13:23   #1216  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Yeah, at http://www.bunkus.org/videotools/mkvtoolnix/win32/pre/
Disclaimer: I don't explicitely provide a portable version. The 7z archives just happen to work mostly even if the program hasn't been installed earlier via the setup.exe. But I don't provide support if something doesn't work with just unpacking the 7z version.
Mosu is offline
Old 25th October 2009, 16:40   #1217  |  Link
Palikrovol
Palikrovol's Avatar
"Save Settings" problem
Hello Mosu,
I think i have discovered a bug related to the mmg settings file or its parsers.
I load an avi into mmg, set the output mkv file and save settings into a mmg file (File -> Save Settings). Then restart mmg (or File -> New) and load the settings file (File -> Load Settings).
Only the output mkv file is read from mmg file, the input tab remains empty after the settings load, so when i hit "Start Muxing" the error
"Error: No input files were given. No output will be created."
is given.
The same happens when adding to the job queue.
Old 25th October 2009, 16:57   #1218  |  Link
Mosu
MKVToolNix author
Mosu's Avatar
Interesting, haven't had that problem before. What is the exact name of that AVI? And can you please send me that .mmg file you've said via email? Thanks.
Mosu is offline
Old 25th October 2009, 17:36   #1219  |  Link
Palikrovol
Palikrovol's Avatar
It happens with every avi i have tested.
I have put a 1 minute test video and his mmg file in your ftp server.
Test_Video.avi
Test_video.mmg (The source Test_Video.avi was in "C:\Documents and Settings\%username%\Mis documentos\")
Test_video_inC.mmg (The source Test_Video.avi was in "c:\")
It's a tv show from the spanish television tve2
The mediainfo output of Test_Video.avi:
General
Complete name                    : C:\Documents and Settings\%username%\Mis documentos\Test_Video.avi
Format                           : AVI
Format/Info                      : Audio Video Interleave
File size                        : 7.22 MiB
Duration                         : 1mn 6s
Overall bit rate                 : 914 Kbps
Writing library                  : VirtualDub build 29963/release
Video
Format                           : MPEG-4 Visual
Format settings, BVOP            : Yes
Format settings, QPel            : No
Format settings, GMC             : No warppoints
Format settings, Matrix          : Default (H.263)
Muxing mode                      : Packed bitstream
Codec ID                         : DX50
Codec ID/Hint                    : DivX 5
Duration                         : 1mn 6s
Bit rate                         : 775 Kbps
Width                            : 480 pixels
Height                           : 352 pixels
Display aspect ratio             : 4:3
Frame rate                       : 25.000 fps
Resolution                       : 24 bits
Colorimetry                      : 4:2:0
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 0.183
Stream size                      : 6.12 MiB (85%)
Writing library                  : DivX 5.1.0 (UTC 2003-09-02)
Audio
Format                           : MPEG Audio
Format version                   : Version 1
Format profile                   : Layer 3
Codec ID                         : 55
Codec ID/Hint                    : MP3
Duration                         : 1mn 6s
Bit rate mode                    : Constant
Bit rate                         : 128 Kbps
Channel(s)                       : 2 channels
Sampling rate                    : 44.1 KHz
Resolution                       : 16 bits
Stream size                      : 1.01 MiB (14%)
Alignment                        : Split accross interleaves
Interleave, duration             : 40 ms (1.01 video frame)
Interleave, preload duration     : 500 ms
Old 26th October 2009, 03:05   #1220  |  Link
ajp_anton
ajp_anton's Avatar
When I use the "Save to Matroska file", MPC-HC gives me a "File not found" error on the file.
There's nothing wrong with the chapters or MPC-HC as it also happens when I take the chapters from a working file and save to another.
ajp_anton is offline
