Old 30th May 2012, 13:59   #21  |  Link
Ghitulescu
Ghitulescu's Avatar
The graph helped understand where the "half-overlapped" frames go... (see VFR frames 1 and 2 that overlap more than, respectively less than half).
Born in the USB (not USA)
Old 30th May 2012, 14:09   #22  |  Link
Aktan
I see. Though I'm confused now then. Does the solution I posted not work?
Aktan is offline   Reply With Quote
Old 30th May 2012, 15:24   #23  |  Link
Ghitulescu
Ghitulescu's Avatar
I don't know, in theory yes.
Old 30th May 2012, 23:16   #24  |  Link
Aktan
It just hit me now that you were giving an example where VFRtoCFR would do bad. Sorry about that. I pretty much strapped that algorithm for the proposed one, which I'm currently writing. Expect to see an update!
Edit: On second look, currently VFRtoCFR would have it correct. Another brainfart...
Old 30th July 2012, 20:09   #25  |  Link
Aktan
I've finally took the time to rewrite the plugin. It should be a lot smarter in choosing which frame to use and it follows my proposed algorithm in my posts above.
Old 26th June 2016, 09:55   #26  |  Link
Selur
Selur's Avatar
@Aktan: any change for a 64bit Vapoursynth version of this filter?
Old 14th January 2018, 03:02   #27  |  Link
Aktan
I have no idea how I missed this, but if you mean would there be a need to change the source to compile to 64-bit, I think so, but I have not tried.
Old 14th January 2018, 08:08   #28  |  Link
Selur
Selur's Avatar
No just wanted to test it with Vapoursynth 64bit back then and the download only included a 32bit version.
Old 14th January 2018, 23:33   #29  |  Link
Aktan
Ah, I see. I needed to compile a 64-bit DLL anyway. So I'll release an updated archive soon. Not sure how hard to compile to VapourSynth 64-bit.
Old 22nd June 2019, 05:41   #30  |  Link
attackworld
Hi, will you be making a 64bit version soon?
attackworld is offline   Reply With Quote
Old 15th May 2020, 17:15   #31  |  Link
Aktan
Sorry, I don't know how I missed this. Yes, I play to compile to 64-bit soon.
The 64-bit compiled version is available here.
Old 4th June 2021, 23:48   #32  |  Link
kedautinh12
New ver of TimecodeFPS
https://github.com/Asd-g/TimecodeFPS
