Old 5th September 2017, 16:22   #3581  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
Not sure why your example has a .mp4 extension but opening a script "おどるポンポコリン.avs" works fine in mpc-hc even without switching the locale to Japanese. This is on XP.
Sorry I meant "おどるポンポコリン.avs" I'm using Windows 10 x64. Anything I could look for to debug the issue?
MysteryX is offline
Old 5th September 2017, 16:30   #3582  |  Link
Groucho2004
Maybe this could be the problem?
Edit: Alternatively, change the system locale to Japanese and check if you still can't load the file in mpc-hc.
Groucho2004 is offline
Old 5th September 2017, 16:56   #3583  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Atak_Snajpera,
What happens if you get virtual memory use over 2048MiB ?
Speed progressively drops after 2000 MiB mark. AVS meter silently crashes or terminates around 3.5 GiB (around 32 bit memory limit) . Speed drops to 0.5 fps before silent crash.
Atak_Snajpera is offline
Old 5th September 2017, 17:19   #3584  |  Link
I've always thought that there was something not quite right with either avs or windows use of pagefile (dont know which).
EDIT: What do the 'big guns' think could be wrong ?
StainlessS is offline
Old 5th September 2017, 17:37   #3585  |  Link
Groucho2004
There have been a lot of improvements regarding exception handling in AVSMeter since 2.2.6. This won't prevent the crash but it might provide more info as to where it occurs.
Old 5th September 2017, 18:24   #3586  |  Link
Atak_Snajpera
More data but this time on nice graph
Just generic Access Violation after 3.5 GiB mark
Old 6th September 2017, 09:51   #3587  |  Link
LigH
LigH's Avatar
Well, you used AVSMeter 2.6.2 (x86), so, a 32-bit process.
AVSMeter64 will run a 64-bit process.
Yet ... if you have LAA binaries, utilizing above 2.0 and up to 3.5 GB RAM should not cause so much speed penalty, that's a different issue (bold guess: maybe using a plugin which is not really LAA compatible, thus system calls occur a lot to try to prevent issues?).
New German Gleitz board
LigH is offline
Old 6th September 2017, 10:29   #3588  |  Link
Groucho2004
I'm a bit puzzled by your post. What makes a plugin LAA compatible? LAA only applies to the calling executable (AVSMeter, x264, VDUB, ...). Setting that linker flag in Avisynth.dll or plugins is pointless.
I have no idea why Avisynth+ doesn't exit gracefully with a proper out of memory message, I guess it's a plugin misbehaving in combination with multi-threaded AVS+.
Old 6th September 2017, 10:44   #3589  |  Link
LigH
LigH's Avatar
I'm sorry about my lack of in-depth knowledge here ... long ago, I read a brief remark about compilers or linkers abusing the most significant bit of addresses (which will be unused in a 32-bit process environment) as a behavioral flag, which I did not understand in detail, but since then I am unsure if there might be code – even in a DLL – which might rely on this bit serving as a flag, rather than being ignored. Very vague, I know. But some people use strange memory addressing trickery. I would not be able to exclude this as "half-wit nightmares", unless pointed to a convincing reason why I don't need to bother.
On the other hand, I can easily imagine issues regarding threading, despite the list of default plugin functions threading modes being so much tuned already.
LigH is offline
Old 6th September 2017, 13:21   #3590  |  Link
Groucho2004
Don't sell yourself short, there are indeed risks involved although I think that following simple coding guidelines should avoid these.
Old 6th September 2017, 15:50   #3591  |  Link
pinterf
@Atak_Snajpera: could you please put this line at the beginning of the script?
SetLogParams("log.txt", LOG_DEBUG)
Then look into the generated file. When there are a lot of messages for shrinking caches, it can cause heavy slow down.
And another question: what are your speed numbers when you specify e.g. SetMemoryMax(2000) or SetMemoryMax(3000)?
pinterf is offline
Old 6th September 2017, 17:17   #3592  |  Link
Atak_Snajpera
Default
INFO: Ignoring unnecessary MT-mode specification for mvtools2_MSuper() by script.
INFO: Ignoring unnecessary MT-mode specification for mvtools2_MAnalyse() by script.
WARNING: Caches have been shrunk due to low memory limit. This will probably degrade performance. You can try increasing the limit using SetMemoryMax().
WARNING: A plugin or the host application might be causing memory leaks.
2000
AVSMeter 2.2.6 (x86)
AviSynth+ 0.1 (r2508, MT, i386) (0.1.0.0)
Loading script...
Number of frames:                  420
Length (hh:mm:ss.ms):     00:00:14.014
Frame width:                      1920
Frame height:                     1080
Framerate:                      29.970 (5000000/166833)
Colorspace:                       YV12
Frames processed:               420 (0 - 419)
FPS (min | max | average):      0.397 | 472295 | 12.13
Memory usage (phys | virt):     2686 | 2880 MiB
Thread count:                   53
CPU usage (average):            87%
Time (elapsed):                 00:00:34.632
3000
Loading script...
Frame width:                      1920
Frame height:                     1080
Colorspace:                       YV12
FPS (min | max | average):      0.300 | 472295 | 13.40
Memory usage (phys | virt):     2627 | 2819 MiB
Thread count:                   53
CPU usage (average):            92%
Time (elapsed):                 00:00:31.334
What is max safe value for SetMemoryMax in 32 bit? 3500 or 4000?
Old 6th September 2017, 17:24   #3593  |  Link
Groucho2004
@Atak_Snajpera
Which version of mvtools2 are you using?
Old 6th September 2017, 17:27   #3594  |  Link
Atak_Snajpera
Old 6th September 2017, 17:35   #3595  |  Link
Groucho2004
You might get some speedup by using the latest version from pinterf.
Old 7th September 2017, 07:50   #3596  |  Link
pinterf
Yes, there were many fixes and changes since mvtools2 2.7.13.22 and the latest 2.7.22 probably fixes this one as well:
"WARNING: A plugin or the host application might be causing memory leaks."
I'd say the safe limit is 3000, but you have to experiment. AviSynth+ maintains its own memory consumption (frames, caches) internally but cannot count with a situation when a plugin is allocating so much memory that the total consumption is over limit.
pinterf is offline
Old 7th September 2017, 08:20   #3597  |  Link
Atak_Snajpera
Your version of mvtools2 solves performance drop after 2000 MiB mark. I don't even have to specify SetMemoryMax values at all
Old 7th September 2017, 16:59   #3598  |  Link
Atak_Snajpera
Simple question. Which one is better?
#Prefetch
video=Prefetch(video,16)
#Triming
video=Trim(video,0,1771)
or
#Triming
#Prefetch
Old 7th September 2017, 17:36   #3599  |  Link
Groucho2004
#Prefetch
#Triming
or
#Triming
#Prefetch
Whatever gives you more performance and/or less memory usage. AVSMeter is your friend.
It may not matter at all.
Old 8th September 2017, 19:16   #3600  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
This isn't working with Avisynth 2.6
if (!vi.IsY() && !vi.Is420() && !vi.Is422() && !vi.Is444() && !vi.IsRGB())
    env->ThrowError("ConvertToShader: Source format is not supported.");
Is420 returns false, but IsYV12 works. I made sure to update headers to the latest version.
MysteryX is offline
