Old 5th December 2012, 17:56   #16001  |  Link
MSL_DK
Unfortunately I don't have access to the yCMS sources so I can't say what's wrong exactly or fix the problem myself. However, I would guess that inconsistencies in your measurements might be the problem.
I do not think so. I just got my Spyder4 swapped to a i1pro and I'm pretty sure that it makes correct measurements.
MSL_DK is offline   Reply With Quote
Old 5th December 2012, 17:59   #16002  |  Link
MSL_DK
Originally Posted by dansrfe View Post
It would be nice if someone wrote up a mini guide on how to calibrate madVR via yCMS with hfcr from scratch for people like me who are relatively new to hardware calibration and somewhat clueless.
Old 5th December 2012, 18:39   #16003  |  Link
pururin
So now for Intel users DXVA2 scaling for both Chroma/Luma is the best choice?
Also can HD 4000 handle Bicubic75 Chroma+Lanczos3 AR Luma? I'm planning on getting one (I3 3225).
Personally, I prefer less taxing combinations that give reasonably good result (Catmull-rom Chroma+ Bicubic75 Luma in the old discussion?) to save power consumption.
pururin is offline   Reply With Quote
Old 5th December 2012, 19:46   #16004  |  Link
clsid
@madshi
Would it be possible to make the default scaling settings dynamic? Then you might be able to provide a better out-of-the-box experience, certainly on weaker hardware.
I was thinking of something like this:
1) Show the graphics card name and DeviceID somewhere in madVR settings.
2) Create a topic where people can post test results for the various scaling algorithms in madVR.
Provide links to some representative sample files, so everybody can test with the same ones.
Something like:
http://xhmikosr.1f0.de/samples/2160p/ParkJoy/ParkJoy_720p50.x264.CRF23.mkv
Testers should post details like:
- graphics card name and deviceid
- windows version
- CPU
- screen resolution
- max GPU usage for the sample file(s) for the various scaling methods
3) Based on the results you can decide which sane defaults should be used for each card. I am sure some of the regulars in this topic are willing to help out to generate such conclusions for you, saving you the trouble/time.
A rule of thumb could be at most 80% GPU usage for processing 30i/60p, or maybe a bit more conservative.
And of course the heaviest algorithms should not blindly be used on powerful hardware. You could decide to choose a specific one as the max for default settings, so that there is a good balance between performance and quality.
4) Add a simple lookup table to madVR that uses the DeviceID as index and contains the default scaling settings for each card. A relatively small table should probably already suffice for listing the most popular cards.
(perhaps an external .xml file might be an alternative for an embedded table, as it would allow additions without touching madVR)
5) Use conservative defaults for unknown cards. Or perhaps use some heuristics based on GPU details such as memory/core frequency/shadermodel version/#of shader units. I dunno what kind of info you can (easily) acquire.
Old 5th December 2012, 20:29   #16005  |  Link
ryrynz
ryrynz's Avatar
Already been suggested a number of times, looks to be one of those possibly 1.0 polishing features.
Once again falling into final stage fine-tuning but having MadVR perform a benchmark and auto selecting a preset would be quite cool.
Old 5th December 2012, 21:04   #16006  |  Link
6233638
Originally Posted by khanmein View Post
i'm using mobility HD5650. can u suggest what setting for chroma, image up & downscale? thanks~
my setting
chorma 3 jinc AR
luma up 3 jinc AR
down Catmull-Rom AR + linear
If you can run those settings without dropping frames, I would say those are already ideal.
I'm trying to figure out a "scale" for the settings in madVR, to see what the best options are from low-end to high-end, balancing performance and image quality.
how about an audio renderer which works hand in hand with madvr to get rig of the frame drop repeat problem by resampling the audio
so madvr runs 100% smooth without reclock and out of the box.
That's exactly what Reclock is for though?
Old 5th December 2012, 22:51   #16007  |  Link
dansrfe
madshi,
Is it possible to have an option to override PGS subtitle positioning? I know if you choose to do this it will be at the bottom of your list and that's ok. Just wanted to see if you deemed it worthy to enter the list in the first place. Thanks!
Old 5th December 2012, 23:14   #16008  |  Link
madshi
Originally Posted by pie1394 View Post
At least it looks much closer if compared to the one produced by version 0.85.1 on ION chipset.
I've found a little bug. Colors with DXVA scaling turned on might now be too bright by a factor of "257/256". This will be fixed in the next build. Then colors should truely be 100% identical.
and how about an audio renderer which works hand in hand with madvr
I do not have any plans to write an audio renderer.
Originally Posted by DragonQ View Post
You could add a very small wizard that simply asks what the user's GPU is and then set recommended scalars based on that. Might be easier to auto-detect though.
It's not necessary to ask the user which GPU he has, I can find out via Direct3D.
Originally Posted by sneaker_ger View Post
0.85.1 seems to suffer from the same problem. Also had the problem where the playback does not start with LAV Video come back. MPC-HC's decoder still seems to work fine, but I have great trouble making it 100% reproducable. I have a feeling both problems are connected. It's like a frame is requested from the dxva2 decoder and it either takes very long for it to come or it doesn't come at all.
That sounds quite weird. If you can manage to create a log which *only* has the situation in it where playback does not start at all, I'd be interested in that. If you have a monster log where playback sometimes starts and sometimes not, I'd rather pass on that because it would be hard to interpret.
Just for my information: All these issues only apply to DXVA decoding. No problems with DXVA deinterlacing and/or DXVA scaling, is that correct?
Maybe I will also create a seeking sample to better test seeking in the future, unless something like this already exists.
That might be useful.
Originally Posted by truexfan81 View Post
weird, with my gt430, if i activate the madvr deinterlacing on either setting, it becomes a slideshow. However the cuvid deinterlace to 60p works perfectly. :-/
That is very weird, I've no explanation for that. Do you have an SSE4.1 capable CPU? Are you sure that cuvid deinterlacing is done with highest possible quality? You could double check by using the cheese slices test video. Most important of all: When you get that slideshow, which of the queues are empty and which are full? You can see that in the madVR debug OSD (Ctrl+J).
Originally Posted by mindbomb View Post
the chroma upsampling being done by intel/dxva2 is also a result of dxva scaling on intel?
If you activate DXVA scaling with v0.85.2, chroma upscaling is automatically also done by DXVA on all GPUs.
I'm not saying that the measurements are incorrect. The problem might be that if you do too many measurements which are too near to each other, the measurements might not be on a straight line/curve. That could produce problems for yCMS. You could try to reduce the number of measurements. That will result in yCMS having to interpolate/guess more, but it might fix those artifacts. But I don't really know, I'm not really an expert with this.
If "reasonably good result" and "save power consumption" are your primary concerns that using DXVA2 scaling for Intel GPUs sounds like a good solution. However, there's currently the one problem with this that Intel only outputs to 8bit RGB. So you might get some banding. But I'm in contact with Intel to get this fixed. Not sure if I can get them to fix this, but I'm trying...
@madshi
Something like:
- windows version
- CPU
- screen resolution
It's a good idea, but it's a rather complex thing. E.g. on Intel GPUs using DXVA scaling and deinterlacing is running in dedicated hardwired circuits, while with AMD and NVidia, DXVA stuff mostly runs on GPU shaders. So with Intel using DXVA scaling and deinterlacing shouldn't slow madVR rendering performance down much. The situation is different with AMD and NVidia. Then performance can differ a lot depending on whether you downscale or upscale, and with which scaling factor.
But the main problem is that the current scaling algorithms may not be final yet. E.g. current algorithms all run in HLSL pixel shaders. Maybe I can use CUDA/OpenCL to squeeze more performance out of the GPU, then everything could change again. So I think it's too early right now to start creating such a GPU <-> settings database.
In the long run I do plan to either make such a database, or to alternatively add a built-in benchmark which measures GPU speed and then auto-configures madVR accordingly. But this is all future talk. I still need to add several missing features first...
I think the subtitle renderer would be the better place to have such options. Soon (hopefully) the next xy-vsfilter version might replace the MPC-HC internal subtitle renderer as the best option for madVR subtitle rendering. Let's see then which options xy-vsfilter will offer and whether that'll be enough for everybody. If not, you could try convincing the xy-vsfilter dev to add more options.
Old 5th December 2012, 23:32   #16009  |  Link
DragonQ
Yeah but what I mean is, wouldn't you have to keep a big database of every card in existence this way? With a simple menu (old IGP, new IGP/old GPU, new GPU) you can be more generic.
HTPC Hardware: Intel Celeron G530; nVidia GT 430
HTPC Software: Windows 7; MediaPortal 1.19.0; Kodi DSPlayer 17.6; LAV Filters (DXVA2); MadVR
TV Setup: LG OLED55B7V; Onkyo TX-NR515; Minix U9-H
Old 5th December 2012, 23:41   #16010  |  Link
aufkrawall
Even if no luma scaling happens?
Edit: I guess not.
But now that DXVA logic of madVR has changed, why not making it possible to select DXVA scaling also for luma?
Old 6th December 2012, 00:08   #16011  |  Link
sneaker_ger
I'm still trying to create a proper log. I have the feeling that the debug version behaves somehow different - read: better - than the normal version. Is that possible?
I tried to create a similar situation by playing a 1080p60 file, which the HD5850 is too slow to handle:
http://www.mediafire.com/?ffwpozffc2gkhyp
The symptons are the same.
I'll keep trying to create a proper sample but it really proves to be difficult.
Just testing DXVA2 decoding here. No deinterlacing or DXVA2 scaling going on.
Old 6th December 2012, 00:21   #16012  |  Link
sneaker_ger
Back to Cat 12.9, first video: transparent window, no start.
Switch to [debug]: works fine.
Old 6th December 2012, 00:49   #16013  |  Link
ajp_anton
ajp_anton's Avatar
Edit: I guess not.
Why not? DXVA scaling now outputs RGB, which it can do whether there's luma scaling or not.
And "also for luma"? It's currently *only* for luma (which automatically does it for chroma as well).
edit: I just realized, my overlayed start menu has been fixed. If it's in your list of unresolved low-prio bugs, you can forget about it.
Old 6th December 2012, 02:13   #16014  |  Link
Hwasin
This does not seem to be true in any fullscreen mode for me. Using Intel HD3000 in a optimus system with 540m
The test I did was to set chroma with Jinc + AR. In windowed mode, rendering time is 9ms. In fullscreen mode, it's 60ms.
Hwasin is offline   Reply With Quote
Old 6th December 2012, 02:31   #16015  |  Link
khanmein
dropping/delay frames impossible 0. once i start play BD-RMVB (DXVA-CB, NV12 4:2:0)
@drop frame 4
@delay frame 1
once i alt+tab full screen or adjust the seek bar drop/delay frame will increase slightly & stay at there as long i didn't pause or click forward/backward.
i noticed when start playing MKV+FLAC, the mpc will delay & hang for less than 15 sec with black screen. after that it play smoothly.
khanmein is offline   Reply With Quote
Old 6th December 2012, 04:20   #16016  |  Link
ajp_anton
ajp_anton's Avatar
And what about if chroma upscampling is set to bilinear or nearest neighbor?
Old 6th December 2012, 06:28   #16017  |  Link
Hwasin
I don't know how to tell the difference. But upon further testing. This only happens with 1920*1080 material. My screen is 1920*1080.
It doesn't use DXVA2 scaling when luma scaling is nor used.
Old 6th December 2012, 06:40   #16018  |  Link
Mangix
Audiophile
I thought that CUDA as well as OpenCL didn't expose any graphics related functionality like textures and whatnot but did allow GPGPU stuff like password cracking.
Mangix is offline   Reply With Quote
Old 6th December 2012, 09:48   #16019  |  Link
Heuer
I seem to be having problems with 85.2 - it is causing sound breakup on the centre channel. Reloaded 85.1 and everything was back to normal. Tried this iteration three times with the same result so I am back to running the earlier release. Any suggestions?
Setup - i3, GTX650Ti, W7, MPC-HC, LAV + MadVR + Re-clock. Break up gets worse as video (720p was the tester) progresses.
Heuer is offline   Reply With Quote
Old 6th December 2012, 10:09   #16020  |  Link
madshi
DXVA scaling is only active if the video needs to be scaled. If DXVA scaling is active, chroma upsampling is being done by DXVA, too. If the video doesn't need to be scaled, chroma is still upsampled by the madVR algorithms.
Well, I guess it would be possible. But I somehow doubt the usefulness of using DXVA chroma upsampling with non-DXVA luma upscaling. So I wonder whether I should invest the development time to make this combination work.
That's bad. I'll try to reproduce this on my development PC. You're using win7, right?
@drop frame 4
@delay frame 1
Try activating the "delay playback start until queues are full" in the madVR settings. That might get rid of the frame drops when starting the video.
Which MKV splitter and which FLAC decoder are you using? Try madFlac as an alternative, if you haven't already...
Both CUDA and OpenCL (1.2) have interop functionality to Direct3D9 which in theory allows accessing D3D textures. However, it only half works at the current time and is very slow with current AMD drivers. But there's hope that this might be improved in the future.
Are you using anything DXVA related? Does it help if you disable those? Does madVR drop any frames while you get audio breakup? In theory madVR does not have anything to do with audio at all. This might be a result of how DXVA/Direct3D demands resources from the CPU, maybe not leaving enough resources to the audio driver? Does your CPU run near 100% when this problem occurs? You could also check DPC latency, there are test tools available for that.
