Old 8th November 2019, 21:24   #57761  |  Link
tony359
Originally Posted by Klaus1189 View Post
What GPU and what driver version do you use excatly?
nVidia 1050ti - driver version 431.70
Thanks!
tony359 is offline   Reply With Quote
Old 8th November 2019, 21:43   #57762  |  Link
Klaus1189
Please update your Nvidia driver to latest GRD, for infos see also my dedicated driver thread:
AMD, Intel and Nvidia driver issues and last recommended version
Please report back if done, perhaps better in the driver thread, since it is driver related at least I think so for now.
Old 9th November 2019, 15:48   #57763  |  Link
box4m
MADVR - duplicate monitors - one with HDR / one without HDR
Is this possible?
I cant get it working with my second monitor duplicated to the TV.
TV is HDR capable (and it works if its extended) and the monitor is not
Any particular setup for this, if its possible?
I maybe shoulve asked in this thread instead of making a new thread about it, not sure.
Thanks
box4m is offline   Reply With Quote
Old 9th November 2019, 20:04   #57764  |  Link
mclingo
it should work but you might need to have the TV as primary, i'm not sure really. I'm using my TV as my main monitor but I also have a non HDR HDMI dummy plug which I use for teamviewer remote connections, teamviewer drops to 480p if you dont have an active monitor turned on.
HDR works fine on my setup, i have mine setup as only show on monitor 1 though (TV), however it also works if I duplicate, it doesnt work if I extend.
OLED 4k HDR EF950-YAM RX-V685-WIN10 444 RGB 60hz-AMD RX 5700 19.11.3 KODI DS - MAD/LAV 92.17/0.74.1 - 3D MVC / FSE:ON / MADVR 10bit
Old 12th November 2019, 18:46   #57765  |  Link
d3rd3vil
Could someone give me a tip what settings to use to upscale 240p-360p material as best as possible? Of course it looks shitty so upscaling wont do miracles. Still.....someone said add a bit of grain and then sharpen it?!
So under "chroma upscaling" and "image upscaling" what do I pick there, NGU Anti-Alias? What about under processing" what to do there under "image enhancements" and maybe "artifact removal"? God bless you in advance
d3rd3vil is offline   Reply With Quote
Old 12th November 2019, 19:16   #57766  |  Link
if it is high quality 240+360p which i doubt you can use NGU sharp add grain helps NGU quite a lot in this case. if the quality is not "pristine" and the image has compression artifacts just use NGU AA and try add grain.
the rest is content specific.
Old 12th November 2019, 20:05   #57767  |  Link
cork_OS
cork_OS's Avatar
Very informative advice, I could only mention that adding sharpness could boost artefacts too, so you could play with the "Reduce compression artifacts" option.
I'm infected with poor sources.
cork_OS is offline   Reply With Quote
Old 12th November 2019, 20:19   #57768  |  Link
toki
I don't know if this is a madVR question or MPC-HC, but I can't get subtitles to show no matter what I do and I'm unsure of what's going on.
toki is offline   Reply With Quote
Old 12th November 2019, 20:21   #57769  |  Link
d3rd3vil
Ok thank you. Do I activate NGU sharp (or AA) in both chroma and image upscaling categories?
And how do I add grain?
Old 12th November 2019, 21:59   #57770  |  Link
i personally not aware of a situation where NGU sharp is better then NGU aa for chroma i would generally use NGU AA or super xbr for chroma. this is totally different from image doubling chroma where the same algorithm is preferred and that what madVR trys to use.
you find add grain under upscale refinements in the past it was only usable for NGU sharp i know it works for NGU AA too now but not sure about the rest of the scaler. the grain is added before scaling this somehow help NGU sharp in upscaling beware at a low resolution the grain can get quite big.
RCA and RRN have heavy effects on the image quality even on good source that's why it should be set depending on the source.
the results of NGU sharp change heavily if they are used because NGU sharp can't handle low image quality/compression artifacts and often enhance them.
RCA and RRN make the image pretty soft so using some sharpening filter to counter this is a good idea in such a situation but again heavily depends on the content so i can't do a recommendation here.
Old 12th November 2019, 22:07   #57771  |  Link
ryrynz
ryrynz's Avatar
For some reason are 10 bit videos more demanding to upscale than an 8 bit ones? Both files full HD and scaling to 4K, using the same profiles and there are some huge differences here between the rendering times which I've confirmed on the OSD.
Showing the renderingsteps only shows that the bulk of it is going to chroma and NGU doubling. Is this normal? First time I've seen it.
Old 12th November 2019, 22:29   #57772  |  Link
the texture could be double the size with 10 bit which could impact scaling performance.
never really notice this you may also see more copy back impact.
Old 12th November 2019, 23:18   #57773  |  Link
nevcairiel
I wouldn't expect scaling to be any different, as I would expect madVR to use high bitdepth textures in all cases already.
Timing info can be treacherous, it might be influenced by another step entirely and only show there.
Old 12th November 2019, 23:26   #57774  |  Link
d3rd3vil
God bless you I will try the good stuff
Old 13th November 2019, 09:43   #57775  |  Link
Msarc
One reason I can think of is subtitles set to render too far below the frame.
You can find it under MPC options > Subtitles -> Override placement -> Vertical.
Set it to 95% or lower and see if that helps.
It's also possible that you have Default Style for subtitles enabled in MPC, which can do the same thing. Try fiddling with it under "Screen Alighnment & Margins".
Msarc is offline   Reply With Quote
Old 13th November 2019, 13:15   #57776  |  Link
toki
I figured out what the problem was. Thank you for your help.
Old 13th November 2019, 16:48   #57777  |  Link
Klaus1189
What was the problem? On forums you should always post the reason if you know it.
Old 14th November 2019, 01:57   #57778  |  Link
Furgiuele
Hi all and sorry for my bad English! I have a (clock deviation) issue. I use Jriver MC25 and Madvr .17, on htpc with I5 9600 cpu - Nvidia 2060 gpu. When I start watching a movie I have a big clock deviation with a frame drop every second or littlemore, but the cd decreases and frame drop time increases continuously. Then, after one hour, really I won't have any frame dropped and I won't have any stuttering or artifacts. I try to use custom resolution in Madvr, but my gpu driver didn't accept. Can someone help my to solve the strange issue? Thanks
Furgiuele is offline   Reply With Quote
Old 14th November 2019, 06:07   #57779  |  Link
Klaus1189
Use the suggested settings of madVR for custom refresh rate and create it with CRU:
https://www.monitortests.com/forum/T...on-Utility-CRU
Old 14th November 2019, 10:51   #57780  |  Link
jeffk
Is there any trouble with the tone mapping ?
Here the screenshoot of the 1080p SDR version versus the 4K HDR tone mapped to SDR (using "Let MadVR decide" and "Pixelshader", they both have the same result)
1080p SDR :
https://reho.st/view/self/631eef439c...004bf6a411.jpg
4k HDR to SDR (downscaled to 1080 using Jinc)
https://reho.st/view/self/8319a1c769...516a19b141.jpg
Thanks,
jeffk is offline   Reply With Quote
