16th June 2019, 08:45 | #56581 | Link |
Without HDMI 2.1 (which AFAIK doesn't exist yet GPU-side, and is only supported by the new LG C9 display-side), you can't output RGB 2160p60.
Charky "Rule #1 : If it works, don't change anything." |
16th June 2019, 08:50 | #56582 | Link |
Surely you meant to say 10 or 12 bit? 2160p60 RGB 8bit is fine.
LG OLED55BX6LB, Zidoo Z1000 Pro, Yamaha RX-A3060, Polk Signature Fronts & Centre, Wharfedale D300 Atmos surrounds, Polk Signature HTS 10 Sub, DSPeaker Antimode 8033 Cinema |
16th June 2019, 09:55 | #56583 | Link | |
HDMI 2.1 allows RGB 2160p120, which I am very much looking forward to when a GPU with HDMI 2.1 comes out.
madVR options explained |
16th June 2019, 10:06 | #56584 | Link |
Yeah, will be nice from a technical view, but I don't see myself rushing out to upgrade my entire A/V chain...
16th June 2019, 10:11 | #56585 | Link |
there is older version with that option.
you can use the windows HDR where this could work. or it just works for you. you should still figure out where your gpu is taking ages for an totally trivial conversion. there are far more variables to check why this could go wrong. |
16th June 2019, 12:45 | #56586 | Link | |
Envoyé de mon SM-G930F en utilisant Tapatalk
16th June 2019, 13:26 | #56587 | Link |
Stuck on 1080 on my OLED until my amp gets updated, banged in some 48Gbps HDMI cables for good measure. Most of my stuff is 1080 anyway so I can deal for now, but damn OLED is so God damned clean/pure in picture quality, get that 4:4:4 poppin and lord almighty, it's glorious. 10-bit is a waste of time based on the Pana OLED with my limited testing.
16th June 2019, 13:38 | #56588 | Link |
Yeah, I've updated all my cables in the chain to 48Gbps versions too.
And when I go to update my display (but not any time soon), I'll def be looking at OLED.
16th June 2019, 16:48 | #56589 | Link | |
16th June 2019, 21:16 | #56590 | Link |
I meant I've tried 2 different cords in 2 different spots on the tv and they're both the same. 4.2.0 8 bit. I can't even get RGB, let alone 8 bit 10 bit and so on. I've tried looking for the magic mode to put it in, but haven't found it yet.
16th June 2019, 22:28 | #56593 | Link |
Hello, recently I have noticed a lot of stuttering but it could be because of the the new win 10 update (1903) since it started around that time, but I'm still wondering if anyone else have noticed it? Here are some stats, I noticed I have 20k presentation glitches after 10min.
http://https://i.imgur.com/xcWMXDl.png https://i.imgur.com/4fjKpIy.jpg My second question, I'm wondering what's your preferred settings for motion/smooth playback? Nvidia Gsync on/off? Smooth motion on/off? Present a frame for every Vsync? My specs: i7-8700k Gtx 1080Ti 1440p 144hz monitor Thanks in advance. Last edited by mambans; 16th June 2019 at 22:30. |
16th June 2019, 22:36 | #56594 | Link |
G-sync Off, madVR hates Gsync
Smooth motion ON, this takes some GPU power but keeps everything smooth without perfectly tuned refresh rates. Present Frame for every Vsync On, I have had better luck with this option. Do you have power set to "Adaptive"? The drivers default to Optimal Powder, which is not good. Also, do you have the newest Nvidia drivers? The older ones had a bug that used a lot of CPU. A test with D3D11 disabled and with windowed overlay enabled might be useful.
16th June 2019, 23:02 | #56596 | Link |
Glad it was so easy. Happy to help.
16th June 2019, 23:19 | #56597 | Link |
Oh, the stuttering/glitches are back. They came back after I restarted the player around 3 times.
Tried disabling D3D11 but that just makes the whole screen black and turning Vsync off didn't help. Since it worked in the beginning it seems to be fixable but can't find anything else to test. hm.. |
16th June 2019, 23:21 | #56598 | Link |
Disabling D3D11 made the screen black after restarting the player?! Do you have G-sync fully disabled?
17th June 2019, 03:12 | #56600 | Link |
Did you try MPC-BE or MPC-HC instead of Potplayer as Potplayer is known to have issues with madVR in some cases.Even though it is working fine in my system. I have MPC-HC, MPC-BE, Potplayer, Jriver MC and Zoom player installed in my two HTPCs. Every player is configured to use madVR and LAVfilters and I have all these players working fine with madVR. If one player has issues, any one of the other always works.
