Old 13th May 2015, 19:27   #29881  |  Link
Originally Posted by tobindac View Post
Spare me the passive aggressiveness. If the source is suitable, it may be better in some specific cases. I know banding makes it worse in some cases.
I wouldn't be surprised if various modern movies from good sources do not require dithering filters for a good viewing experience.
i can't disagree that not all scene need dithering no question.
but a movie without a dark scene or gradations is unlikely.
even with really high bit deep there could be banding in a BD when dithering isn't used.
Old 13th May 2015, 19:33   #29882  |  Link
nevcairiel
You will *always* need dithering, because its about the mathematical process, not about the quality of the source. In fact, its entirely independent of that (although its going to be more obvious in some sources than in others, of course)
If such a perfect source would exist, then dithering also wouldn't add noise, since dithering, by definition and design, is only used to spread the rounding error to multiple pixels, instead of accumulating it all in one. If there wouldn't be a rounding error, there would be no "noise".
At the end of the day, movies are all going to be in YUV, and YUV needs to be converted to RGB. This conversion process (if done right) results in floating point values, which need to be converted to 8-bit (or recently, 10-bit) on output. If you don't use dithering, you will effectively cut off data. Thats also were your analogy goes wrong, dithering isn't about hiding flaws, its about preserving data when converting to a lower bitdepth (ie. from 16/32-bit float, to 8/10-bit integer for output)
Of course you are free to use whatever settings you like, but please don't spread them as advice.
Old 13th May 2015, 19:35   #29883  |  Link
Dogway
I'm a bit confused when you ask "what mode my PC is", where should I look that? Control panel just said (roughly) 1080 native, 60Hz.
Anyways I had a look and I don't find any video that turns my TV to 1080p60 mode, it stays always in PC mode which is fine and bad at the same time... I would expect a bit more consistency for these things (I should be able to treat 60fps sources as every other non-PC source, TV settings wise). 1080p59 is also defaulting to PC mode.
Then I played a 50fps video and screen turned to 50p mode, so here the story does apply.
Anyways I removed the 1080p50 entry and it defaulted to 1080p60 now seemingly and oddly enough "PC mode" (I still think passthrough should be a better idea?). I will report back when I find something strange. Sorry to disturb.
I'm still curious on why I can't seem to enable chroma NNEDI doubling. I even tried with "always - if upscaling is needed", only luma gets upscaled with nnedi.
Old 13th May 2015, 19:36   #29884  |  Link
cvrkuth
Originally Posted by cvrkuth View Post
Yes, madvr display modes work correctly now. Thanks!
My playback is fine (no dropped frames, no glitches).
Anyway, just for info .. when I watch movie 24.000 and refresh rate fix is active, render queue and present queue are low (render queue 3-5/8 and present queue 2-3/8. Average stats present 31.00 ms which is abnormally high, usually 0.05 ms.)
When I watch movie 23.976 and refresh rate fix is not active, everything is fine with numbers (render queue 7-8/8 and present queue 6-7/8. Average stats present is 0.05 ms.)
Hope this help,
Regards
Intel Core i7-4790 CPU @ 3.60GHz, RAM 32 GB Dual-Channel DDR3 @ 665MHz (9-9-9-24),
Panasonic TX-P42G20E, NVIDIA GeForce GTX 970, Win 10 Pro x64,
PotPlayer 1.7.16291 64-bit, madVR v0.92.17
cvrkuth is offline   Reply With Quote
Old 13th May 2015, 19:38   #29885  |  Link
nnedi3 chroma doubling was removed under image doubling.
Old 13th May 2015, 19:41   #29886  |  Link
Dogway
Since what version? I'm using v0.87.21
Old 13th May 2015, 19:42   #29887  |  Link
since 88.x
but if you are using 87.21 can you give me a screen from the osd ?
Old 13th May 2015, 19:55   #29888  |  Link
Dogway
since 88.x
Old 13th May 2015, 20:01   #29889  |  Link
on this screen chroma doubling is used.
BTW. any reason you didn't use smooth motion on this 60 Hz screen?
just interested in your reasoning.
Old 13th May 2015, 20:02   #29890  |  Link
Asmodian
I noticed that ordered dithering is a very noisy process. I found it fun lately to turn on 1bit output and see very obviously some algorithmic patterns. It appears not dithering at all gives the most "stable" unnoisy picture while error diffusion is more stable and 'random' is a total mess.
I'm surprised, but it appears no dithering at all is a viable choice.
Choices..
No dither at all is NOT a viable choice.
I am not at all sure how one could conclude dithering is bad when watching 1-bit output. Watching 1-bit output without dithering makes it hard to see what is going on. Almost all detail is lost. Turn off "change dither for every frame" if you want a more stable image, DO NOT turn of dithering entirely. Ordered dithering has very low apparent noise even at only 4-bit (256 colors), especially with "change dither for every frame" off.
Originally Posted by Ver Greeneyes View Post
But - sure, if the noise bothers you when madVR is set to the correct output bitdepth, turn it off. Or turn off "change dither for every frame", which will make it less effective but might make it less visible (except on very uniform surfaces that are displayed for a considerable length of time). But it does mean you'll get more of a rounding error on average, reducing color accuracy.
"change dither for every frame" doesn't make dithering less effective or less accurate. It makes dither patterns easier to see but average rounding error and color accuracy is the same with or without "change dither for every frame".
Turning off "change dither for every frame" trades more visible dither patters for less apparent dither noise.
madVR options explained
Old 13th May 2015, 20:02   #29891  |  Link
x7007
Hope this help,
Regards
Same happens to me
x7007 is offline   Reply With Quote
Old 13th May 2015, 20:07   #29892  |  Link
Dogway
How do you know that? shouldn't it be "chroma > nnedi16 > Mitchel..."?
I never use smooth option (a gimmick IMO) but this is my PC monitor not my TV anyways.
Old 13th May 2015, 20:08   #29893  |  Link
Ver Greeneyes
Changing the dithering pattern every frame is more effective because it adds a time-based element. Let's take Error Diffusion as an example with a hypothetical losslessly compressed test pattern showing large uniform patches of color. Without temporal dithering, each pixel is going to have a particular color all the time - rounded either up or down depending on its position. Only the patch taken as a whole will have the right color on average. With temporal dithering, each pixel will have the correctly rounded value on average.
Of course in real material the difference is going to be negligible because of changes in what's being displayed, and noise in the source material subtly changing the dithering decisions each frame. Still, if you combine temporal dithering with something like smooth motion so that it changes for every screen refresh, it makes it much more effective (which is why I would prefer dithering to be tied to vsync rather than the video frame rate - but I always use smooth motion anyway, so it's a moot point).
Old 13th May 2015, 20:15   #29894  |  Link
the first chroma line is always the 4:2:0 to 4.4:4 part and nothing else.
and because there is no second chroma line image doubling is doing this.
why gimmick?
please don't compare it to frame interpolation like SVP or the interpolation from TVs.
but usually it is not needed on a TV anyway.
Old 13th May 2015, 20:24   #29895  |  Link
Dogway
I think I understand what you mean, first line is converting to 4:4:4, then it upscales the whole thing with nnedi (hence image >, and not luma >), but in my opinion it shouldn't be doing that... it's not a good idea to use a a scaler before nnedi because you are amplifying artifacts, also you are adding one more step to chroma.
chroma > mitchell > nnedi (double) > resizer (for up or downscale to 1080)
has the behavior changed in last version?
edit: btw I don't think what you say is right, I disabled chroma nnedi and I get the same OSD output.
Old 13th May 2015, 20:32   #29896  |  Link
Asmodian
I see the point, however this temporal effect isn't going to give "correct" pixels values because what value the pixel gets over time is random, not influenced by accumulated error. madVR's dithering is spacial dithering, not temporal, and the option does not change this.
Old 13th May 2015, 20:37   #29897  |  Link
Anime Viewer
Troubleshooter
Anime Viewer's Avatar
jumping frames on pause
Originally Posted by ibius View Post
Issues with D3D11:
3. Sometimes after seeking/stopping playback video gets stuck in a loop, jumping between few frames.
I noticed that too (when pausing videos), but wasn't sure how to word it. The best description I could think of at the time was it jumping back and forth between frames during pause. I've found that if you change scalers (up or down) it stops it and stabilizes the picture, so it may be a combination of D3D11 and scaler coding/changes.
System specs: Sager NP9150 SE with i7-3630QM 2.40GHz, 16 GB RAM, 64-bit Windows 10 Pro, NVidia GTX 680M/Intel 4000 HD optimus dual GPU system. Video viewed on LG notebook screen and LG 3D passive TV.
Anime Viewer is offline   Reply With Quote
Old 13th May 2015, 20:44   #29898  |  Link
vivan
/人 ◕ ‿‿ ◕ 人\
It will, because the chance the pixel will be rounded up (or down) is proportional to it's remainder value.
The way it changes is random - so it's random temporal dithering. It might be possible to make it ordered (imagine 3D matrix for ordered dithering, which is "good" in all dimensions).
Ordered dithering works on probability too, the only difference from random is that it uses special "good" matrix. "Good" means that peaks and valleys are as far from each other as possible.
vivan is offline   Reply With Quote
Old 13th May 2015, 20:52   #29899  |  Link
Asmodian
Remember the chroma is half the resolution of the luma so you need to upscale it before doubling somehow, an extra step for chroma is unavoidable. If you don't think it is a good idea to use mitchell before NNEDI3 don't tell madVR to do that. You can use NNEDI3 to do this first upscale as well (set it in 'chroma upscaling').
On my system with v0.87.21 if I disable chroma doubling I get a second chroma line below luma that says chroma is being upscaled with what is set in 'image upscaling' (and 'image' changes to 'luma'). I don't get the same OSD output if I disable chroma doubling.
Old 13th May 2015, 20:53   #29900  |  Link
Werewolfy
Stupid me. I forgot that the refresh rate fix also needs new madHcNetXx.dlls. You'll find them here:
http://madshi.net/madVR885refreshRateFix2.zip
These files together with the modified madVR(64).ax should make the refresh rate work again.
Your fix never worked for me even before but this time it works! Thanks, great work.
Windows 8.1 and 10 x64 - Intel Core i5-4670K (4.2 GHz) - 8 GB DDR3 - MSI Geforce GTX 1080 8 GB - Sony KD-55A1 - Denon AVR-X3600H
Werewolfy is offline   Reply With Quote
