Old 9th September 2008, 21:13   #6161  |  Link
nautilus7
nautilus7's Avatar
First, .thd+ac3 is only accepted for input. Just use .thd. Furthermore, why use nero? Libav is the default TrueHD decoder because it works better. Finally, you don't need any -24 or whatever switch. All source data will be present in the output wav file. If source is 24bit, the wav will be 24bit, if it is 16bit, the wav will be 16bit. You will get a report about the actual bitdepth at the end of the procedure.
So your command should be:
eac3to input.thd output.wav
nautilus7 is offline
Old 9th September 2008, 21:21   #6162  |  Link
hdpete
Althogh my source thd is 24 bit and the wav says it's 24bit, tsmuxer only recognises it as a 16bit, either way the -24 bit didn't seem to make a difference.
I'm usimg nero with blu-ray plugin as I thought it was a reference decoder as opposed to libav.
I just want to be able to convert TrueHD to LPCM to mux with tsmuxer to get a BD25 (tsmuxer doesn't like TrueHD). Previous converts using eac3to have resulted in screaching audio when muxed onto a BD25
hdpete is offline
Old 9th September 2008, 21:28   #6163  |  Link
nautilus7
nautilus7's Avatar
That's tsmuxer's bug, I'm afraid.
What you say is true for the lossy decoders (AC3, E-AC3). All lossless fortmat decoders have to output the same data. That's the case with nero and libav TrueHD decoders. In addition libav supports up to 7.1ch when nero doesnt.
Again tsmuxer's bug. It supports pcm in a weird format. Use pcm2tsmu to convert eac3to's pcm files to tsmuxer's compatible ones.
Old 9th September 2008, 21:38   #6164  |  Link
hdpete
Thanks a lot for this, I can start backing up my TrueHD blu-rays/HD-DVD's now and keep lossless audio for my Onkyo amp.
hdpete is offline
Old 10th September 2008, 16:14   #6165  |  Link
hdpete
What file extenstion should I use to extract the 1080p blu-ray video using eac3to which will allow tsRemux to recognise and import it? Will it be a different file extention depending on the codec, i.e. H264 or VC-1?
Thanks for your help
hdpete is offline
Old 10th September 2008, 17:41   #6166  |  Link
rack04
I always change the container format to mkv and convert the audio to whatever format I fancy. So in my case the extension for the container wouldn't vary by video codec but the audio would. Clear?
rack04 is offline
Old 10th September 2008, 17:56   #6167  |  Link
nautilus7
nautilus7's Avatar
.h264 for H.264, .vc1 for VC-1 and .m2v for MPEG-2.
Old 11th September 2008, 00:51   #6168  |  Link
rica
BD which i have issues is "Welcome Jungle".
Here you will see it has an english thd:
And i can play it with TMT with my analog outputs to my A/V receiver and no problem:
But i can only see french thd when i open it with eac3to, i extract it to thd+ac3, remuxed to m2ts with TSMuxer and finally remuxed to m2ts with TSRemux using the file created by TSMuxer; it works but it is french:
 eac3to v2.60
command line: eac3to\eac3to.exe  "F:\RUNDOWN_P1_SPITASLA\BDMV\STREAM\00002.m2ts" 3: "C:\output.thd+ac3"
M2TS, 1 video track, 5 audio tracks, 13 subtitle tracks, 1:44:15
1: Chapters, 16 chapters
2: h264/AVC, 1080p24 /1.001 (16:9)
3: TrueHD/AC3, French, 5.1 channels, 48khz, dialnorm: -30dB
4: TrueHD/AC3, German, 5.1 channels, 48khz
5: AC3, English, 2.0 channels, 192kbps, 48khz, dialnorm: -26dB
6: AC3, English, 2.0 channels, 192kbps, 48khz, dialnorm: -29dB
7: TrueHD/AC3, English, 5.1 channels, 48khz, dialnorm: -27dB
8: Subtitle (PGS), English
9: Subtitle (PGS), French
10: Subtitle (PGS), German
11: Subtitle (PGS), Dutch
12: Subtitle (PGS), Arabic
13: Subtitle (PGS), Modern Greek
14: Subtitle (PGS), Turkish
15: Subtitle (PGS), French
16: Subtitle (PGS), German
17: Subtitle (PGS), Dutch
18: Subtitle (PGS), French
19: Subtitle (PGS), German
20: Subtitle (PGS), Dutch
[a03] Extracting audio track number 3...
[a03] Removing AC3 dialog normalization...
[a03] Removing TrueHD dialog normalization...
[a03] Creating file "C:\output.thd+ac3"...
Video track 2 contains 149977 frames.
eac3to processing took 20 minutes, 49 seconds.
Done.
The Q is where this english thd is hidden?
_ _ _ _
rica is offline
Old 11th September 2008, 00:59   #6169  |  Link
woah!
umm number 7 is the english thd audio isnt it?? you are asking for 3: so you get the french audio...
woah! is offline
Old 11th September 2008, 01:02   #6170  |  Link
rica
Thanks i didn't see it really
Looking but not seeing. How stupid i am
Edit:
OK, i got it in english:
_ _ _ __
Last edited by rica; 12th September 2008 at 09:58. Reason: mpc-mpa decoder just decodes ac3 core so removed graph.
rica is offline
Old 11th September 2008, 07:29   #6171  |  Link
JustABDFan
2.54 works...2.55 doesn't
Madshi,
I did some checking by downloading old versions and it looks like it was working in 2.54 but broke in 2.55. I'm gonna take a guess that one of these changes from the 2.55 changelog did it. I made some guesses but i could be wrong.
* improved VOB/EVO audio delay detection algorithm
* detection and automatic skipping of invalid vob units
* options "-60i" and "-24p" are no longer supported for MPEG2 video
* improved detection of MPEG2 framerate / pulldown state / mode (my first guess)
* improved MPEG2 muxing warnings (3rd guess)
* several bugs in MPEG2 video muxing fixed (2nd guess)
* fixed interlaced VC-1 muxing with user data (Nine Inch Nails)
Originally Posted by Encoder888 View Post
@madshi
I have trouble demuxing the MPEG-2 stream from VOB files. Here's what I get:
eac3to v2.62
command line: D:\eac3to\eac3to.exe vts_02_1.vob+vts_02_2.vob 2: Video.mkv
VOB, 1 video track, 4 audio tracks, 5 subtitle tracks, 0:43:15
1: Joined VOB file
2: MPEG2, 480p24 /1.001 (16:9) with pulldown flags
3: AC3, 5.1 channels, 384kbps, 48khz, dialnorm: -25dB
4: AC3, 2.0 channels, 192kbps, 48khz, dialnorm: -25dB
5: AC3, 5.1 channels, 384kbps, 48khz, dialnorm: -27dB
6: AC3, 2.0 channels, 192kbps, 48khz, dialnorm: -27dB
7: Subtitle
8: Subtitle
9: Subtitle
10: Subtitle
11: Subtitle
[v02] This doesn't seem to be a valid MPEG2 stream.
Aborted at file position 1713938432.
I tried it with an earlier version of eac3to (I think it was 2.51) and it worked fine. Please, fix it if possible
JustABDFan is offline
Old 11th September 2008, 11:08   #6172  |  Link
Inventive Software
Turkey Machine
Try a much newer version as well.
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld
Inventive Software is offline
Old 11th September 2008, 14:00   #6173  |  Link
sehgal.v7
eac3to v2.62
command line: eac3to Rambo -check
M2TS, 1 video track, 1 audio track, 1 subtitle track, 1:21:00
3: RAW/PCM, English, 7.1 channels, 24 bits, 48khz
4: Subtitle (PGS), English
[s04] Extracting subtitle track number 4...
[v02] Extracting video track number 2...
[a03] Reading RAW/PCM...
[a03] Swapping endian...
[a03] Remapping channels...
[a03] This audio track has a constant bit depth of 24 bits.
Video track 2 contains 116523 frames.
eac3to processing took 46 minutes, 15 seconds.
Done.
This is log of Blu Ray Disc, i created last. In this Swapping & Remapping being done twice, is it alright? Or i had done something wrong while remuxing??
Workaround-
Extracted Video & Audio from Original Blu Ray// Converted Audio from DTSHD-MA to PCM
eac3to v2.62
command line: eac3to Audio.dtshd Audio.pcm
DTS Master Audio, 7.1 channels, 24 bits, 48khz
Decoding with ArcSoft DTS Decoder...
Swapping endian...
Creating file "Audio.pcm"...
eac3to processing took 25 minutes, 42 seconds.
Done.
After this command line: Pcm2Tsmu.exe Audio.pcm Audionew.pcm -i 24 -c 8 -s 48000
And atlast creating Blu Ray Disk with TSMuxer v1.8.4(b)
sehgal.v7 is offline
Old 11th September 2008, 18:02   #6174  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Small request madshi.
Could you rename first analyzing process from "progress:" to "analyzing:"
So instead of two "progress:" I would like to have "analyzing:" and then when stream is really demuxed I would have "progress:"
Thanks
Atak_Snajpera is offline
Old 13th September 2008, 18:55   #6175  |  Link
K1ngp1ng
i found a bug: truehd 16bit -> flac 24bit
K1ngp1ng is offline
Old 13th September 2008, 20:52   #6176  |  Link
xkodi
please, upload small sample somewhere, you can cut the first 5-10MB from the truehd track using hex editor.
xkodi is offline
Old 13th September 2008, 21:39   #6177  |  Link
Snowknight26
Just a little quirk:
eac3to v2.62
command line: eac3to.exe "G:\Unsorted\Click"
1) 00032.mpls, 00000.m2ts+00027.m2ts, 1:47:31
- MPEG2, 1080p24 /1.001 (16:9)
- AC3, English, multi-channel, 48khz
- RAW/PCM, English, multi-channel, 48khz
- AC3, English, stereo, 48khz
2) 00031.mpls, 00027.m2ts, 0:58:11
...[snip]...
With a trailing \, :
eac3to v2.62
command line: eac3to.exe "G:\Unsorted\Click"\
M2TS, 1 video track, 3 audio tracks, 17 subtitle tracks, 1:47:31
2: MPEG2, 1080p24 /1.001 (16:9)
3: AC3, English, 5.1 channels, 640kbps, 48khz, dialnorm: -27dB
4: RAW/PCM, English, 5.1 channels, 16 bits, 48khz
6: Subtitle (PGS), English
...[snip]...
Snowknight26 is offline
Old 14th September 2008, 19:31   #6178  |  Link
n0mag!c
use 'r'
n0mag!c's Avatar
bug report
When appending several TS file with "+" eac3to can't process files properly.
For error reproduction I took working TS-file and splitted it (with TSsplitter) to 3221380 bytes chunks.
Here is log file:
eac3to v2.62
command line: D:\PROGRAMS\AUDIO\EAC3TO\eac3to.EXE Alien1.TSSplit.1-1434.ts+Alien1.TSSplit.2-1434.ts+Alien1.TSSplit.3-1434.ts+Alien1.TSSplit.4-1434.ts -demux
TS, 1 video track, 1 audio track, 0:00:09
1: MPEG2, 1080i60 /1.001 (16:9)
2: AC3, 2.0 channels, 384kbps, 48khz, dialnorm: -27dB
[v01] Extracting video track number 1...
[a02] Extracting audio track number 2...
[a02] Removing AC3 dialog normalization...
[v01] Creating file "Alien1.TSSplit.1-1434 - 1 - MPEG2, 1080i60.m2v"...
[v01] The pes parser received incomplete data.
[a02] The pes parser received incomplete data.
[v01] This doesn't seem to be a valid PES packet.
[a02] This doesn't seem to be a valid PES packet.
Aborted at file position 3237764.
Of course, If I join chunks back (with TSsplitter or with copy /b), resulting file is fine working.
n0mag!c is offline
Old 15th September 2008, 00:24   #6179  |  Link
madshi
I think the skipping of invalid vob units is the problem. I've removed that as a test in the next eac3to build. Please retest whether DVD demuxing works again. Thanks!
Originally Posted by yonta View Post
eac3to v2.62 crashes on this dtswav file.
Thanks for the sample. Will be fixed in the next build.
1) I noticed that the libFLAC.dll that comes with Eac3to is 151,552 bytes and is dated 7/22/2007 while the one that comes in MadFLAC is 258,048 bytes and is dated 10/7/2007. I wanted to put Eac3to and Madflac into one "tools" folder so which I should use OR do I just make a folder for each and keep em separate?
To be honest, I'm not sure. You can try using the newer dll for both. If you run into no problems then it's fine.
2) Any chance of Eac3to using arcsoft decoders for (E)AC3 instead of Nero 7?
Maybe some day.
Thanks madshi for your new version, for me the standard dts is all ok decoded but:
2/2.1 - ArcSoft output is FL FR FC Empty LF BL, the BR channel is missing and need remap -0,1,3,4,2,5
And using -dtslog with Samples_dts-es encoded with DTS PRO SERIES SURROUND ENCODER (thanks Elektra999) seems there are a detect problem:
                     3/3.0 m   3/3.1 m   3/3.0 d    3/3.1 d
+ DTS-Core           -------   -------   -------    -------
  - frameSize        2013      2013      2013       2013
  - DTS-ES           +         +         +          +
  - channelNo        5         5         5   (?)    6
  - lfe              0         1         0          1
  - channelDescr     5.0       5.1       5.0 (?)    6.1
  - samplingRate     48000     48000     48000      48000
  - bitDepth         16        16        16         16
  - bitrate          1536000   1536000   1536000    1536000
  - extAudio         -         -         XCh        XCh
  - samplesPerFrame  512       512       512        512
  - copyHistory      1         1         1          1
With libav
3/3.1 DTS-ES 6.1 Discrete, output 5.1 with BC mixed in BL-BR, ok but need remap -1,2,0,5,3,4
And ArcSoft problems:
3/3.0 DTS-ES 6.0 Discrete, detected like 5.0 and decoded 5.0 with BC channel mixed in BL-BR like 6.0 Matrix.
3/3.1 DTS-ES 6.1 Discrete, all ok but FL and FR channels broken (missing 99% of samples)
Thanks for testing/reporting and for the new samples! The problems I could fix should be fixed in v2.63. However, ArcSoft seems to have problems with some 6.0 and 6.1 tracks. If I let ArcSoft decode them as 5.1, everything is fine. If I let it decode them as 6.0 or 6.1 the FL and FR channels are broken. Don't see how I could fix that. Funny enough Blu-Ray and HD DVD 6.1 tracks decode fine!! Because of that I can't simply block ArcSoft for 6.x decoding...
Yes.
Changed to "analyze:" and "process:".
This is a problem. eac3to contains some extra code to handle Blu-Ray seamless branching correctly. Now if I make TsSplitter splitted TS files work that may eventually harm Blu-Ray seamless branching handling. Generally if you join some TS or m2ts files which were never stored in one file you'll want eac3to to do some extra checking/processing on these files. But if you join some TS or m2ts files which were once stored in one file and which you splitted with a tool like TsSplitter the extra processing makes joining fail. I'll have to think about how to handle this properly. For now you'll have to manually join the parts with TsSplitter first to make eac3to work...
madshi is offline
Old 15th September 2008, 00:28   #6180  |  Link
madshi
eac3to v2.63 released
http://madshi.net/eac3to.zip
* fixed: incorrect detection of 6.0 DTS tracks as 5.0
* fixed: incorrect libav DTS channel remapping for 6.x or 7.x tracks
* fixed: incorrect ArcSoft DTS channel remapping for "6.0" and "2/2.1" tracks
* fixed: v2.61+62 incorrectly decoded 16bit TrueHD tracks to 24bit FLAC/WAV/RAW
* fixed: some DTSWAV files made HDCD decoder crash
* fixed: DTSWAV and AC3WAV samplerate and bitdepth were reported incorrectly
* improved DirectShow channel configuration reporting
* undocumented option -progressnumbers now outputs "analyze:" and "process:"
madshi is offline
eac3to
