28th December 2009, 21:28 | #9961 | Link |
4:2:0 hater
I think clsid wants this separate filter because if not he'll get loads of complaints in this and other forums where he's helping joe's out. I can understand his positon but this is just stupid: you already have what you want, and it's included in the MPC standalone filters. What's the logic behing making another MPC Video Decoder with just DXVA and "with a couple of checkboxes and value fields"? Because I can't find any. You can just add these to the MPC Video Decoder dialog box (something a lot of people including me have been suggesting for a long time with no response from the devs), it'll be MUCH simpler and would do everything you want.
28th December 2009, 21:38 | #9962 | Link |
A fix for the installer, as it now displays garbage instead of all the custom messages after you switched to (Unicode) Inno 5.3.x - sourceforge tracker
28th December 2009, 22:12 | #9963 | Link | |
MPC-HC Project Manager
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC |
28th December 2009, 22:18 | #9964 | Link | |
Media Control author
I understand clsid's position and I will follow his request at the end of the discussion which is not closed in my opinion About MPC standalone filters, few people use them in standalone release. Lastly, this support is also a benefit for MPC team but I will let them give more details about it EDIT : okay, parallel posting |
28th December 2009, 23:14 | #9966 | Link | |
4:2:0 hater
28th December 2009, 23:26 | #9967 | Link |
契約者
DXVA is the only "unique" thing in MPC-HC codecs set. Everything else is the same as in ffdshow (however some ffdshow filters is faster for me). As I understand from what tetsuo55 said, they will port DXVA to FFDShow and then drop support for all MPC-HC's filters.
EDIT: By the way, what about splitters? Maybe they will be fine in ffdshow as separate filter set (or how should I call this...)? Then it will be truly complete ^_^ Last edited by Keiyakusha; 28th December 2009 at 23:36. |
29th December 2009, 00:02 | #9968 | Link |
Even when the DXVA filter is separated from the ffdshow filter, it should still be possible to re-use code from ffdshow, since most functionality is divided in their own source files. For example font rendering and subtitle stuff. Just the GUI needs to be redone. But considering that most GUI elements in ffdshow do not apply to DXVA, that will result in a small and simple GUI for the DXVA filter. Plus we don't need to disable stuff in the GUI when DXVA is active. For example, suppose the DXVA decoder will eventually be compatible with subtitles, then we can't just blindly re-use all the current subtitle options available in ffdshow. Things like letterboxing are obviously not possible with DXVA.
@STaRGaZeR Making the filter separate will not in any way reduce functionality. I do not understand why people always insist on getting things integrated when it holds no benefits at all. The ffdshow filter suite will replace the (internal) decoders of MPC. Then the MPC devs can focus on the core of the player, like making it more stable and secure. @dann23 Many here on this forum even do not fully understand the limitations that DXVA has or what all the options in ffdshow do. I have years of experience helping people with video playback, so I have a very good understanding of what is best for the people that use ffdshow.
MPC-HC 2.2.1 Last edited by clsid; 29th December 2009 at 00:05. |
29th December 2009, 00:12 | #9969 | Link |
No, FFDShow is not (and will never be) a splitter
It has been a long time one said that ffdshow is too messy and should be splitted up into smaller parts. Also another thing that should be done is direct media foundation support, but another layer to the code. About different filters, one should also ask the question about the future : which DXVA filters could be added apart subtitles. If may be smart to have only the list of available internal filters wether you are in DXVA or not. For me this is more work to do so I am gonna think about the right implementation to do if we decide to go on that way EDIT : parallel posting again |
29th December 2009, 00:56 | #9970 | Link | |
4:2:0 hater
29th December 2009, 08:10 | #9971 | Link | |||
Indeed.
If you update the dxva decoder to a DXVA2 implementation (casimir has a POC for this), all filters would work, but it would completely stop working on xp. cannot wait to hear what you come up with
29th December 2009, 10:20 | #9972 | Link | |
ffdshow user
I think that splitting ffdshow's video, audio, processing and subtitles, DXVA support in standalone filters is a good solution.
29th December 2009, 14:36 | #9973 | Link |
Windows XP still has a 50%+ market share. But compared to Vista/7 it will more often be running on systems without DXVA support. So one day we could decide to drop DXVA support for XP. But I don't think now is the right time yet. We must also consider the fact that XP users are more likely to depend on DXVA from a performance perspective. For example many netbooks use XP.
It would be cool if we could transform the filters in ffdshow into a plugin based system. But I am not sure how difficult that will be considering that it is not unlikely that there are many nasty workarounds and hacks in the current filter chain.
MPC-HC 2.2.1 |
29th December 2009, 19:33 | #9974 | Link |
VLC 1.1 supports hardware decoding using DXVA2.
moreover it uses directly the hardware decoding architecture of ffmpeg (which supports VDPAU/VA-API on linux and DXVA2 with this patch). it would be good to use it to avoid hacking of ffmpeg like in the MPC decoder. I think it would be OK to just support DXVA2 with ffdshow, since people using XP could still use the "legacy" MPC DXVA standalone decoder. here is the source code for the VLC decoder : http://git.videolan.org/?p=vlc.git;a...vcodec/dxva2.c |
29th December 2009, 19:49 | #9975 | Link |
How about adding to video profiles the choice of which h264 renderer & VC1 renderer to use. DXVA2 can be shown as unavailable on XP. VC1 can include the option to use MS. Also it would contain a list of compatible filter types, e.g. subtitles, all, overlay_only, etc.
29th December 2009, 19:49 | #9976 | Link | |
29th December 2009, 20:36 | #9977 | Link |
Very interesting indeed, this could autosolve my green picture issue by the way
However, is this DXVA2 support only (vista/7) ? We have to think about it : I'd rather take the ffmpeg over the MPC patching solution but we may have to drop DXVA1 support @clsid : do you think you could update libavcodec with those latest APIs ? Last edited by albain; 29th December 2009 at 20:39. |
29th December 2009, 20:50 | #9978 | Link |
29th December 2009, 20:50 | #9979 | Link |
Yes, and I think the main reason is that DXVA2 seems to support the retrieving of picture from GPU memory to the main memory (so no need for a specific renderer) which is needed to work with VLC because it doesn't support any standard directshow renderer.
29th December 2009, 21:05 | #9980 | Link |
I should add that I think there are some hacks needed because of bad DXVA drivers (*cough* ATI *cough*) that doesn't seem implemented in the current VLC. I am thinking of the raster vs zigag order which is triggered with files using custom matrices.
It also seems that people who write this ffmpeg patch are clever because they add a variable "workaround" (currently unused) in the context for this kind of hacks I will send a report to vlc-devel to let them know of this awful implementation bug ^^ Last edited by MatMaul; 29th December 2009 at 21:17. |
