Old 9th September 2009, 20:50   #8001  |  Link
Mercury_22
Originally Posted by alexins View Post
albain
@Alexins Your ICL 10 it's not working ! I can't even start playing
x64 and x86 are working fine
Intel UHD Graphics 750; Win 10 22H2
Mercury_22 is offline   Reply With Quote
Old 9th September 2009, 21:25   #8002  |  Link
XhmikosR
Originally Posted by _xxl View Post
I have this issue with ICL11 and forced loop unrolling. ex:/Qunroll10
Hi, xxl. I noticed that this problem is gone with ICL11 if I use /Qvec-, that is if I disable vectorization. Disabling loop enrolling or increasing it to 10 didn't fix the problem.
Is it safe to use the /Qvec- option?
Another thing I've been trying to find is how to use intel specific commandline options when using devenv.
Now I'm using this which is working:
"%PROGRAMFILES%\Microsoft Visual Studio 9.0\Common7\IDE\devenv.exe"^
 ffdshow_2008_icl10.sln /Rebuild "Release Unicode|Win32"^
 /IntelSpecific Intel "Intel C++ %icl_version% [IA32]"
But if I use
 /IntelSpecific Intel "Intel C++ %icl_version% [IA32]" /Qvec-
it does not disable vectorization.
It's probably because he's using ICL v11.1.038. I had the same problem, see a few posts back. Only 11.0.072 works for me for the time being.
XhmikosR is offline   Reply With Quote
Old 9th September 2009, 21:29   #8003  |  Link
alexins
MPC-BE DEV
alexins's Avatar
Strangely, I have no problems arise...
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR
Media Player Classic - BE x86/x64. Team of developers.
alexins is offline   Reply With Quote
Old 9th September 2009, 21:51   #8004  |  Link
Mercury_22
I can't even open the video decoder configuration or audio decoder configuration or VFW decoder configuration! When I try to open the configuration tabs rundll32 it's starting to push my CPU up to 100% ! Again only with the ffdshow_rev3071_20090909_sse_icvl11 with the others x64 and x86 I have no problems
Old 9th September 2009, 21:52   #8005  |  Link
XhmikosR
Weird. It does work for me too, while my ICL v11.1.038 build didn't work with rev3069 that's why I went back to v11.0.072. Are you using ICL v11.1.038 without changing anything else? Also, your builds have this problem too. See a couple posts above, but I need confirmation if it's safe to use /Qvec-.
Old 9th September 2009, 22:33   #8006  |  Link
Mercury_22
Xhmikosr's ffdshow_rev3071_20090909_xhmikosr_icl11 it's working here !
Old 10th September 2009, 11:30   #8007  |  Link
XhmikosR
So, I created two different ICL builds. One compiled with ICL 11.0.072 and one with 11.1.038. In both builds I used /Qvec- and nothing else. From my testing both versions work fine on Windows 7 Pro RTM 32bit. Could someone test them and report back if any problems are present?
Only Mercury_22 is having problems with ICL 11.1.038 builds and I wonder what might be the problem.
alexins' build also worked for me before he removed it from XvidVideo.RU.
Old 10th September 2009, 12:19   #8008  |  Link
alexins
MPC-BE DEV
alexins's Avatar
I checked the FFDSHOW ICL 11.0.072 and FFDSHOW ICL 11.1.038, there were no problems, work well!
Old 10th September 2009, 12:50   #8009  |  Link
Mercury_22
I've just did a clean install of windows 7 x64 ultimate RTM and ffdshow_rev3071_20090909_xhmikosr_icl11.1.038 can't even install ! regsvr32 hangs at the end of install process with my cpu at 50%.
I have just updated windows and installed the drivers !
Maybe Intel's drivers have something to do with this ?
http://downloadcenter.intel.com/Filt...ting%20Systems
Can you post your ICL again ? cause I've delete it ?
Old 10th September 2009, 12:55   #8010  |  Link
XhmikosR
If a process is not using ffdshow.ax while installing ffdshow, I don't see any other reason for the regsvr32 to hang.
Let's see if other people are having similar problems like you have.
Alexins 3071 icl11 build.
Old 10th September 2009, 13:06   #8011  |  Link
Mercury_22
I can't use your link (java script error) but i can download from your folder !
Old 10th September 2009, 13:08   #8012  |  Link
XhmikosR
Try again later, it's a MediaFire problem I suppose, or use this link.
Old 10th September 2009, 13:20   #8013  |  Link
Mercury_22
OK I've downloaded and installed (alexins version) without problems but again I cant even open a video file and I can't even open FFDShow config tabs ! rundll32.exe*32 hangs and it using up to 50% of my CPU
Again I've just installed windows update it installed drivers and now I've installed vcredist 2005 and 2008 x86 and x64 ATL and directx_aug2009_redist
Old 10th September 2009, 13:25   #8014  |  Link
XhmikosR
I'm on Windows 7 Pro RTM 32bit and alexins is on Windows 7 Ultimate 64bit and we both have no problems. I cannot think of something else. It seems that only you are having this problem. It's just weird that with my ICL 11.0.072 build you are having no problems, but with any ICL 11.1.038 build you do.
Old 10th September 2009, 13:45   #8015  |  Link
Mercury_22
I'll do again a clean install and without installing drivers and update the windows i'll try to install your ICL 11.1.038 again
Edit I just did a clean install no update no drivers no nothing and it's the same ! I can't install your ffdshow_rev3071_20090909_xhmikosr_icl11.1.038
Could be cause I DON'T have ICL installed ?
Old 10th September 2009, 14:25   #8016  |  Link
XhmikosR
Of course you don't need to have ICL installed. There is definitely something wrong with the ICL 11.1.038 build and your system.
Do you have the 32bit version of Windows 7? Can you install that and test it?
EDIT: Maybe try to boot in safe mode and see if you can install the ICL 11.1.038 version?
Old 10th September 2009, 21:45   #8017  |  Link
alexins
MPC-BE DEV
alexins's Avatar
Key /Qvec- helped to make a correct ffdshow icl11. To build I used the ICL v11.1.038.
Old 10th September 2009, 21:50   #8018  |  Link
XhmikosR
Yes, I know it works, but since I'm not a programmer I don't know if it's 100% safe to use it. Maybe there is another workaround, like using /Qvec-threshold:number, but i haven't tried that yet.
I haven't found any way to pass the /Qvec- switch through cmd (see this post), do you know any way to do it? I searched Intel forums and the included documentation...
Old 10th September 2009, 22:01   #8019  |  Link
alexins
MPC-BE DEV
alexins's Avatar
It's very simple, edit the file ffdshow_2008_icl10.vcproj.
Locate the line:
AdditionalOptions="/Qip"
... and its replacement:
AdditionalOptions="/Qip /Qvec-"
Old 10th September 2009, 22:04   #8020  |  Link
XhmikosR
I'm doing everything via a batch file, that's why I ask. Maybe I'll use FINDSTR and ECHO >> to automate this step.
EDIT: It's more difficult than I thought
