Old 25th August 2009, 15:28   #2201  |  Link
rack04
x264 core:72 r1232M x86
Download
Built by rack04 on August 25, 2009, 9:20:51 AM CST
  • $ gcc --version
    gcc.exe (GCC) 4.4.1 (x86.core2.Komisar)
  • $ ./configure --extra-cflags="-march=core2"
    Platform:   X86
    System:     MINGW
    asm:        yes
    avis input: yes
    mp4 output: yes
    pthread:    yes
    debug:      no
    gprof:      no
    PIC:        no
    shared:     no
    visualize:  no
  • $ make fprofiled VIDS="bigbuckbunny.avs LosslessTouhou.avs riverbed.1920x1080.yuv"
Patched with:
rack04 is offline   Reply With Quote
Old 27th August 2009, 08:49   #2202  |  Link
JEEB
もこたんインしたお!
JEEB's Avatar
x264 r1235 64bit unpatched:
download ; hash
  • built on Aug 27 2009, gcc: 4.3.4 20090220 (prerelease) (x64.generic.Komisar)
  • fprofiled, otherwise defaults
________________________________________________________________________________
x264 r1235 32bit
download ; release notes
  • built on Aug 27 2009, gcc: 4.3.4 20090220 (prerelease) (x32.generic.Komisar)
  • fprofiled, -march=i686
x264 r1235 64bit
  • fprofiled, -march=core2
patched with:
A bit longer list this time since I just merged two changelogs >:3
[I'm human, no debug]
JEEB is offline   Reply With Quote
Old 27th August 2009, 15:21   #2203  |  Link
rack04
x264 r1235M x86
Download
Built by rack04 on August 27, 2009, 9:14:16 AM CST
  • gcc --version
    gcc.exe (GCC) 4.3.4 20090526 (prerelease) (x86.core2.Komisar)
  • -march=core2
  • make fprofiled
Patched with:
Old 27th August 2009, 16:32   #2204  |  Link
techouse
Strictly Rhythm
techouse's Avatar
x264_x64_r1235_unpatched | MD5
GCC 4.4.1 20090803 (x64.core2.Komisar), unpatched, generic, fprofiled
x264_x86_r1235_techouse | INFO
GCC 4.4.1 20090803 (x86.core2.Komisar), fprofiled, -march=core2
x264_x64_r1235_techouse | INFO
GCC 4.4.1 20090803 (x86_64.core2.Komisar), fprofiled, -march=core2
Patches used:
x264_hrd_pd_interlace.16.fix.1232.diff
x264_win_zone_parse_fix_06.diff
techouse is offline   Reply With Quote
Old 28th August 2009, 01:49   #2205  |  Link
woah!
Patches used:
i get this with you patched x86 version: unrecognised option `--nal-hrd'
rack04 version above you with same patches works ok...
woah! is offline   Reply With Quote
Old 28th August 2009, 06:03   #2206  |  Link
juGGaKNot
juGGaKNot's Avatar
32/64 bit ? are you sure you have the patched one ?
--longhelp
Originally Posted by Dark Shikari View Post
If they can beat x264 in visual quality on ordinary test clips without postprocessing, I'll eat my hat.
juGGaKNot is offline   Reply With Quote
Old 28th August 2009, 06:44   #2207  |  Link
woah!
i said x86 patched version so 32bit patched...
rack04 has these options: --nal-hrd --pulldown
techouse's doesnt, and thats fine to know, so i will use another version which does.
Old 28th August 2009, 07:21   #2208  |  Link
techouse
Strictly Rhythm
techouse's Avatar
I'm pretty sure I patched it, but I'll recheck my building scripts and report back later.
EDIT: You're right, I had a typo in my script and cause of that it didn't find the diff file. Thanx for noticing it ONLY my patched r1232 and r1235 builds are affected. I'm fixing/rebuilding r1235 now.
Old 28th August 2009, 07:39   #2209  |  Link
woah!
np ... i am guessing anyone who does bluray stuff would have said something soon enough too
Old 28th August 2009, 08:00   #2210  |  Link
techouse
Strictly Rhythm
techouse's Avatar
Fixed.
Old 28th August 2009, 15:54   #2211  |  Link
moviefan
What I have been wondering about is:
  1. --march=i686/core2/... - What is the difference?
  2. --fprofiled: What is this for?
moviefan is offline   Reply With Quote
Old 28th August 2009, 16:02   #2212  |  Link
kemuri-_9
Compiling Encoder
kemuri-_9's Avatar
march=i686 is used by default to have gcc use the cmov instruction which speeds up some of the c code a bit here and there.
core2 does just about nothing; it's mostly used to have gcc schedule tasks in way that's optimal for core2 as the instructions barely differ from that of march=i686.
fprofiled is a scheme that you compile a program with that capability, execute it, and then recompile it optimizing based on which code paths were executed the most/least from your executions.
other compilers can have different names for such a feature, but gcc's is called 'fprofile'.
custom x264 builds & patches | F@H | My Specs
kemuri-_9 is offline   Reply With Quote
Old 28th August 2009, 16:46   #2213  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Profiling means that the application is analyzed while it's executing and processing "real" input data. The info collected during the profiling process can be used by the compiler to enable additional optimizations (or to enable the optimizations in parts of the program where they are really needed). Compiling x264 with fprofiled takes much longer than without, because the binary is compiled twice (once before the profiling and again after the profiling is completed). Also you need to provide a sample video clip that will be encoded several times (with different settings in order to cover all code paths) during the profiling process...
Old 28th August 2009, 23:44   #2214  |  Link
moviefan
OK, very interesting! Thanks for the explanations!
Old 29th August 2009, 01:30   #2215  |  Link
JEEB
もこたんインしたお!
JEEB's Avatar
x264 r1239 64bit unpatched:
download ; hash
  • built on Aug 29 2009, gcc: 4.3.4 20090220 (prerelease) (x64.generic.Komisar)
x264 r1239 32bit
  • built on Aug 29 2009, gcc: 4.3.4 20090220 (prerelease) (x32.generic.Komisar)
x264 r1239 64bit
patched with:
Old 29th August 2009, 04:25   #2216  |  Link
rack04
x264 r1239M x86
Download
Built by rack04 on August 28, 2009, 10:13:17 PM CST
  • GCC 4.3.4 20090526 (prerelease) (x86.core2.Komisar)
  • -march=core2
  • fprofiled
Patched with:
Old 29th August 2009, 12:39   #2217  |  Link
buzzqw
HDConvertToX author
for any interest
http://www.64k.it/andres/data/x264/x264.1239.x86.tar.gz
gcc 4.4.1
$ ./configure
Platform:   X86
System:     LINUX
asm:        yes
avis input: no
mp4 output: yes
pthread:    yes
matroska: yes
Patched with: x264_hrd_pd_interlace.16.fix.1232.diff
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 29th August 2009, 21:46   #2218  |  Link
rack04
x264 r1240M x86
Download
Built by rack04 on August 29, 2009, 1:39:08 PM CST
  • -march=core2
  • fprofiled
Patched with:
Old 30th August 2009, 02:12   #2219  |  Link
JEEB
もこたんインしたお!
JEEB's Avatar
x264 r1240 64bit unpatched:
download ; hash
  • built on Aug 30 2009, gcc: 4.3.4 20090220 (prerelease) (x64.generic.Komisar)
x264 r1240 32bit
  • built on Aug 30 2009, gcc: 4.3.4 20090220 (prerelease) (x32.generic.Komisar)
x264 r1240 64bit
patched with:
And something deeply experimental.
x264 r1240 with MixAQ and OreAQ patches: download
  • fprofiled, default CPU flags, --extra-ldflags="-lz"
Patched with the patches:
If you plan on building, the file 'AQDebugLog.h' has to be in the root of your x264 codebase:
These patches are made by Seraphy and Muken AKA VFR Maniac, each developing their own versions and VFR Maniac updating the standard patches for newer revisions. And yes, the patches seem to need zlib. Tobinaka has written some articles on these AQ modes on Doom9, so please search for his posts if you have any basic questions on the patches, and please do report any findings if you decide to test these builds.
Also, I took these patches in this time because of the large amount of interest they have gathered in Japan overall. Personally I didn't dislike what an older MixAQ build did with the blackpearl sequence on 500kbps, but otherwise I'm not saying any of these patches greatly increases quality or something like that. Isn't it fun to have something not-so-usual on your hands?
Last edited by JEEB; 30th August 2009 at 02:58. Reason: Updated the experimental patches to their newest revision
Old 30th August 2009, 02:19   #2220  |  Link
VFR maniac
Spinner of yarns
VFR maniac's Avatar
Hi, JEEB.
I updated OreAQ qp_adj calculation according to rev1236.
Please check below.
http://seraphy.fam.cx/~seraphy/cgi-b...ne&namber=2269
Edit: Woops! I passed by you.
僕と契約して、L-SMASH developerになってよ!
L-SMASH | L-SMASH Works | Opus-in-ISOBMFF specification and reference software
VFR maniac is offline   Reply With Quote
h.264, x264, x264 builds, x264 patches, x264 unofficial builds
