11th January 2004, 05:50 | #41 | Link |
End of Movie Navigation
Have you noticed that on most movies there is a short blank clip that makes up the last chapter of the movie and when you reach this chapter you typically jump to the menu.
However on some movies the last chapter is just the end of the movie and credits. In this case you can not select NEXT in IFOEDIT at all you must instead wait until end of chapter. I believe Bad Boys 2 & Gigli are both like this. However (No.2) in this second scenario if you select NEXT CHAPTER with your stand alone when you get the the credits (last chapter) you start the movie over or sometimes jump to the next Title. How can I solve this. When I get the the credits, I want to be able to hit NEXT CHAPTER and have it navigate to the menu. Regards.. Jeff |
12th January 2004, 20:13 | #42 | Link | |||||
PGC Navigator in Training
Re: End of Movie Navigation
Update: Here's those guides. Inserting a Blank Cell at end of Title Adding a “Insert Disc 2” clip Enjoy!
2COOL Last edited by 2COOL; 22nd January 2004 at 19:56. |
18th February 2004, 04:06 | #43 | Link |
Identity Cheat Sheet Guide
I am having problems with the cheat sheet guide for Identity.
I followed the guide for theatrical & extended. However, when i get to the theatrical/extended selection screen and select either one, i get only a black screen!! If I go to scene selection and select the start of the movie everything else seems to be fine. Anyone have any solutions for this?? Thanks |
18th February 2004, 19:53 | #44 | Link | |
Re: Identity Cheat Sheet Guide¿
I don't know what to say as I have done a theatrical & extended backup myself. I was writing the guide in real time and have tested it too. Hmmm...are you doing a region 1 NTSC DVD? If so, I would suggest you to try it again and if you have the same problem again, please post in this thread.
2COOL Last edited by 2COOL; 30th March 2004 at 09:40. |
20th February 2004, 18:16 | #45 | Link |
problems.....
thanks for responding 2COOL
it does seem as though im not the only one having this problem.... the thread you directed me to also has a user (ccsint - last post) that appears to have the same problem as i do. As i live in canada, im assuming that it is an R1 dvd. However, I will give it another shot, and hopefully it will work out |
17th April 2004, 05:48 | #46 | Link |
HI 2COOL...
I was looking for your amazing generic WIDESCREEN/FULLSCREEN menu guide and can't find it on the list... Is it still here...? Thanks... Jeff FOUND it... sorry was looking for the words WIDESCREEN/FULLSCREEN & ASPECT RATION slipped my eyes... need NEW contacts badly...
FREE video clips | DVD-Rebuilder | DVDReMakePRO & MenuEdit | SHRINK | Daemon Tools | VOBBlanker Last edited by geffroman; 17th April 2004 at 05:52. |
25th June 2004, 20:38 | #47 | Link |
Hey 2Cool thanks for all of your guides. They are so helpful. I am currently working on a movie which has about 40 seconds of movie intros in the first PGC of the main movie. In this PGC is also the beginning of the movie. Since some of the beginning of the movie is contained in it, I do not want to delete the entire PGC, but only the beginning of it with the nonsense in it. If I preview the PGC in IFOEdit, I can change the entry point sector to bypass the intros at the beginning of the PGC. Is there any way to delete the beginning though or strip it out? Also since I have altered the playback time, must I also go in and adjust that value as well. I also have this situiation at the end credits where the end of the movie is located in the same PGC as the end credits, which I do not necessarily need to keep. Thanks.
Mike |
11th September 2004, 18:47 | #48 | Link |
ank You very much
You have beenon the money. The info you have given has helped out more than you know but I just have one more question. when I start to shrink. The computer ask me what program do I want too run the shrink with. which on do I pick.
Thank you |
13th September 2004, 00:12 | #50 | Link | |
2COOL |
20th October 2004, 11:27 | #51 | Link |
reMember
Hiya 2COOL,
I wanted to make a comment to your new Mock Strip guide, which I saw yesterday, and tried to locate it through your cheat sheets & guides list, but no luck... The list has not been updated with the new guide yet? As you've made so many (very useful) guides that are collected on your list, could you please write "NEW [date]" or "UPDATED [date]" after the link, so that it's easier to check back once in while to see if you've produced any new miracles since last time?! I wouldn't want to miss any, now would I!! Also it'd make it wasier to locate a new guide that I'd read as a stand alone post in this section some days ago...! |
21st October 2004, 00:53 | #52 | Link |
Hi!
You have made a great tool! Is there a way to edit the menu(s), so that the subpic turns off let's say 4 sec before the end of the menu (the subpicture doesn't starts with the menu, but 5 sec after. DVD compiled with Maestro), I mean making it invisible and inoperable with pgcedit? Thanks |
21st October 2004, 03:57 | #53 | Link | ||||
@CoNS
@Kilyan Quote:
2COOL Last edited by 2COOL; 21st October 2004 at 04:02. |
29th December 2004, 18:44 | #54 | Link |
No audio
Here is an interesting problem I hope someone can figure out. When I burn a DVD, there is no audio. It plays fine on PowerDVD when played on the computer but when I burn it or make an image file from IFOEdit, you have to manually select the sound in order to hear the audio. No sound even on PowerDVD after making an image file. Any ideas??
Thanks |
22nd February 2005, 00:53 | #56 | Link |
Congratulations... You've helped an aweful lot of people...!!!!!
FREE video clips | DVD-Rebuilder | DVDReMakePRO & MenuEdit | SHRINK | Daemon Tools | VOBBlanker |
6th June 2006, 16:27 | #58 | Link |
very new
hey i am very new at this and i looked around this site and cant find what i am looking for.
i have 3 seperate sets of ifo/vob files and i am trying to put them on one dvd using nero but it will only let me put one set. what am i doing wrong is there another program i am suppose to use i have ifoedit can i do it with that. if not can you tell me what program to use and a lil bit of instructions please. please help me |
8th June 2006, 08:53 | #59 | Link |
Country Member
Welcome to doom9 nappyreddz
Probably the easiest tool for this job is DVD Remake Pro Here is a guide - http://www.dimadsoft.com/dvdremakepro/ht_merge_full.php Regards
Les Only use genuine Verbatim or Taiyo Yuden media. |
3rd April 2008, 13:08 | #60 | Link |
How can I delay the audio from a DVD in order to sync it with the video? Is there a simple guide to this? In fact... any guide will do. thanks.
AMD Athlon 64 3000+ 2.0 GHz Nvidia GeForce FX5200, 256 MB Gigabyte nForce3 250, 512 MB RAM Maxtor 80 GB 7200rpm XP PRO 5.1 (Build 2600) SP2 TDK DVDRW882N|TEAC CD-W540E|ASUS E616 |
