8th August 2009, 23:29 | #221 | Link |
May be this error happens due to my OS (Vista)?
I do not see NVBeta6 URL o neuron2.net. Why? I had no such problem with NVbeta4. == Edit 1== With NVBeta6 the same problem. I found NVBeta6 there http://neuron2.net/dgavcdecnv/NVbeta6.zip Last edited by prokhozhijj; 8th August 2009 at 23:43. |
9th August 2009, 07:53 | #223 | Link |
Just change the link you get from the site, replace the 5 by a 6 and you can download it..
PC specs for bug reports: Intel Core i7-4790K @4Ghz Win10(Linux VM) PCI express NVIDIA RTX 2060 SUPER graphics card http://twitter.com/cwebdesign |
9th August 2009, 21:05 | #224 | Link | |
With NVBeta4 I have no such issue. I've tried to reinstall NVidia drivers (190.38 International for Vista32, this is latest version for my video card 8800GTS) but it did not help. |
14th August 2009, 19:53 | #228 | Link | |
After this error arised your application can generate index file but after that I can not legally shutdown the program (through menu or window button "Close"). I've checked my Avisynth version. I wrote already that I have the latest stable official release. This is 2.5.8 AFAIK. But I've reinstalled Avisynth JIC. The second problem still occured when I do not see anything when using avs-script. Are others guys have Windows Vista 32 SP2? May be problem in operating system difference (Xp SP3 and Vista SP2)? == Edit 1 == I found old version nvcuvid.dll in this folder C:\Windows\System32\DriverStore\FileRepository\nv_disp.inf_df3f64cf. In others folders (C:\Windows\System32 and C:\Windows\System32\DriverStore\FileRepository\nv_disp.inf_12c1d22e) there is newest version of this dll. I think that old version of this library saved by OS for possibility to rollback in case when new drivers installed incorrectly. == Edit 2 == Version of DGDecodeNV.dll in NVBeta7.zip is 1.0.2.0. The same version of this library in plugins Avisynth folder. I rewrote this dll in plugins folder from NVBeta7.zip archive. Last edited by prokhozhijj; 14th August 2009 at 21:07. |
14th August 2009, 20:51 | #229 | Link | |
14th August 2009, 21:49 | #231 | Link | |
I did not load nvcuvid.dll from the past. I wrote which dll's from NVidia I have and where they located. Please read my posts carefully. I've noticed that when I firstly close the project than I can to close DGMPGIndexNV.exe legally. Issue happens with all VOB files. Last edited by prokhozhijj; 14th August 2009 at 22:02. |
14th August 2009, 22:12 | #233 | Link |
But did you test your soft on Vista 32 SP2? I did not found any restriction (except for deinterlacing) about Vista using. And may be you'll make your application with extended logging? It may help. I see that you just do not want to investigate my problem. All advices comes to "just reinstall your soft". How you can make conclusion about anything without any logs? Last edited by prokhozhijj; 14th August 2009 at 22:27. |
15th August 2009, 16:17 | #234 | Link |
I believe somewhere on your system is an old version of something, probably something associated with the NVidia drivers.
Be aware that NVidia used to have a large control panel/control suite called nView that was bundled with older versions of their drivers. They removed nView support for GeForce cards in the drivers starting several months ago, nView is for Quadro cards only now. If you had older nVidia drivers on the system when you upgraded to 190.38, nView may have stayed behind, and it will cause problems with the latest drivers. My recommendation: 1. Remove your nVidia drivers. 2. Remove nView if it is listed in the Add/Remove programs control panel. 3. Do a search on the Windows directory for all nVidia-related DLLs, especially nvcuvid.dll, and delete if any are found. 4. Delete C:\Program Files\nVidia if present. 5. Remove all versions of DG's NV tools from your system, including any DGNV-related DLLs present in C:\Program Files\Avisynth\plugins (like DGDecode.dll) 6. Restart and reinstall nVidia drivers 190.38. 7. Download and unzip the latest DGNV Beta 7 from neuron's site. 8. Try your steps again. If this does not work, I'm not sure where else to go. Many other people here are running DGNV Tools beta 7 under XP SP3, Vista 32, Vista 64, and Win 7 with no issues. Edit: Just saw in the other thread that you discovered that your GeForce card may not have sufficient hardware support for the NV Tools. If this turns out to be the case, please disregard.
- SomeJoe Last edited by SomeJoe; 15th August 2009 at 16:20. |
29th August 2009, 19:56 | #235 | Link |
Hi neuron.
Sorry in advance if i've missed something since i've been away for a while. I have DGMPGNV 1.0.2.0. I have this system: Here is the MediaInfo report of the original VOB: And here is the sample rar including log, original VOB and dgm files: http://rapidshare.com/files/273106157/DG.rar.html 1) Log is empty. 2) Created dgm is slow-motion. 3) Even MediaInfo says the original is progressive and even more "enable purevideo deinterlacer" is selected in "double rate", interlacing artifacts are very clear. What's wrong with me? |
30th August 2009, 00:59 | #237 | Link |
The logs were broken. I have just updated beta 9 with the fix for the logs.
Regarding your interlacing, the stream is hosed. Turn off deinterlacing, serve the video with SeparateFields() to look at the source fields. See what I mean? I don't know what you mean by the dgm is slow-motion. Please redownload beta 9 and try with that, and if there is an issue tell me what you do to make it happen. |
30th August 2009, 01:14 | #238 | Link |
neuron,
i've already done. No problem left here. Sorry, but i haven't been realized DGTools beta until now. I was dreaming this morning a software which makes HW decoding-resizing on the fly like SimHD and now i found it. Thanks neuron. Here are my test results: aviscrypt: Code:
LoadPlugin("C:\users\rica\desktop\Tools\DGNVTools\DGDecodeNV.dll") DGSource("C:\users\rica\desktop\Copy\DG_Newest\output_newest.dgm", resize_w=1280, resize_h=720) WMP: GraphEdit: GraphStudio: Thanks again Last edited by rica; 30th August 2009 at 01:24. |
