12th January 2012, 19:08 | #8101 | Link |
Yes it is graphstudionext - View -> Decoder performance.
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin |
12th January 2012, 19:10 | #8102 | Link |
Brilliant. Thanks for that. 51-52fps on average with my Quad Core 8200, 5870 12.1a preview, W7 SP1 X64, using 32 bit versions of everything.
12th January 2012, 19:15 | #8103 | Link |
Too bad, i would've hoped for faster.
Here is a second try: http://files.1f0.de/lavf/LAVFilters-...-perftest2.zip You need the first version, and just replace the .ax file I increased the number of buffers from 2 to 8, apparently on my Intel GPU this gives me a significant performance boost on some samples, so who knows, maybe it does something for ATI. Otherwise, i'm not sure i know what else to try without an ATI card at hand - maybe its just everything we can get out of them...
12th January 2012, 19:18 | #8104 | Link | |
2. Because it's a guide about getting MPC-HC working with madvr... The 64-bit stuff is clearly outside its target. 3. "disable everything" <--- repeated for your benefit. It then goes on to show the ones that could be enabled without breaking the setup that the guide is trying to give you. 4. "Here's a simple guide... and if you feel like doing something slightly more advanced, here's how to configure that as well." This isn't really that complicated to understand. 5. The "quick" flash is much, much slower on some hardware (or drivers) than others. Starting a video and then having 5 seconds of black screen before it actually starts to play can be annoying. Still though (and I don't think you understand this), I'm not arguing that the guide is good/bad. Just that you were an jerk for no particularly good reason. And that you didn't actually read the post before trying to mock the poster. |
12th January 2012, 19:18 | #8105 | Link |
Nothing changed here, still ~51FPS
12th January 2012, 19:19 | #8106 | Link |
Will there be a direct rendering mode in the future? For older ATI and Intel cards.
Any plans to implement some kind of smart fallback mode that switches back to software decoding if the GPU isn't fast enough to keep up with the fps of the video? Another question, do you happen to know the minimum required version of nvcuvid.dll that is compatible with current LAV Video? Or at least the lowest version you know that is compatible.
MPC-HC 2.2.1 |
12th January 2012, 19:20 | #8107 | Link |
Thanks, nev.
Everyhthing is done on a mobility radeon 4570, 512MB. Also did a (very) quick real world testing. 1080p50 (test sample) and 1080p60, both MKV, both completely unwatchable under Zoom Player and madVR. 1080p24 seems to work fine, running smooth, though madVR's queues are a bit on the lowish side (around 7-8/12). Downloaded YouTube 1080p clip completely unwatchable (MP4). Let me know when will you need more detailed reports, I'll be glad to help. * EDIT * second test build gives similar results. Oh, I suppose it's possible the GPU simply isn't powerful enough to handle madVR at 1080p60. Last edited by adam777; 12th January 2012 at 19:42. |
12th January 2012, 19:20 | #8108 | Link |
Too bad.
If anyone feels like testing alot, you could grab VLC and test its DXVA on such a 50p or 60p clip, and see if it works better? I doubt it would, but maybe AMD hacked up the driver to do something special when VLC is detected - its certainly possible. Not of the dll, but it should work with all CUDA 2.0 and upwards version, which is around driver 190 or so.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 12th January 2012 at 19:27. |
12th January 2012, 19:24 | #8110 | Link |
As a final point, there's something important to remember about web forums...
While blexley might be the 100th in a long line of newbies asking stupid questions on doom9, it's the first time he's been on doom9 and asked a stupid question. Treating him(or anyone new) as if he is asking a stupid question for the 100th time is just being mean. |
12th January 2012, 19:39 | #8111 | Link |
A better listing includes GPU utilization as well (Perftest 1)
Progressive 8 bit Playback efficiency 1080p 60 fps (4 girl H.264) Arcsoft DXVA = ~2% CPU; GPU = ~20% Cyberlink DXVA = ~2% CPU; GPU = ~20% CoreAVC DXVA = ~4% CPU; GPU = ~20% Intel Quicksync DXVA2 = ~12% CPU; GPU = ~23% Nev Generic DXVA2 = ~17% CPU; GPU = ~24% Nev Lav Video Libav = ~25% CPU; GPU = ~25% All DXVA2 and Software results (Lav Video). Results include Parser (Lav Splitter MKV)/Audio(Lav Audio)/Renderer (EVR Custom Experimental) Overhead
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 Last edited by CruNcher; 12th January 2012 at 19:48. |
12th January 2012, 19:51 | #8112 | Link |
My results on my HD 5830 using 11.12 drivers and system in my sig benched with graphstudionext (avg 3 runs to null renderer):
Lav Video DXVA2: 52.2 fps for reference on same system: Lav Video software: 143 fps Edit: with your perftest2, same exact results as above.
MPC-HC/MPC-BE, Lav Filters, MadVR CPU: AMD Ryzen 5 1600, Video: AMD Radeon RX Vega 56 -> TCL S405 55", Audio: Audio-Technica M50S Last edited by fairchild; 12th January 2012 at 19:54. |
12th January 2012, 19:51 | #8113 | Link | |
all my compares are riddles so please try to decipher them yourselves :) It is about Time Join the Revolution NOW before it is to Late ! http://forum.doom9.org/showthread.php?t=168004 |
12th January 2012, 20:05 | #8114 | Link |
Here's results from a 7970
Here's the correct results, I guess the 280fps was too good to be true @ madshi, here's the results for your test, http://dl.dropbox.com/u/19338638/madnvtest.JPG
Windows 11 Pro, CPU: Ryzen 9 5900X, GPU: GeForce RTX 3090 /w 512.95, Audio: HDMI to Yamaha RX-A3060 (5.1) Last edited by VipZ; 12th January 2012 at 20:09. Reason: Fixed mistake |
12th January 2012, 20:06 | #8115 | Link |
Well, a slight increase, bringing it closer to NVIDIAs performance - its unsure if this may just be the decoder limiting now, though.
Interesting that madshi's test app still only shows 4 fps NV12 download though.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 12th January 2012 at 20:11. |
12th January 2012, 20:10 | #8117 | Link |
Though if you compare these results with Nvidias old cards it looks not really fast those results would be in the range of a 460 GTX if i remember right
12th January 2012, 20:11 | #8118 | Link |
Yea, well, I also game on my machine, so, you can compare the video all you want....but once you start looking looking at gaming numbers things might be slightly....different.
12th January 2012, 20:12 | #8119 | Link |
4:2:0 hater
~52fps with both builds on 1080p50 Crowdrun.
CPU usage lower than the QS decoder. 1080p60 unwatchable. 1080p50 starts with a few seconds of stuttering, then it's smooth with a few drops below 50fps here and there. But it's not LAV Video's fault, Microsoft's decoder fails too, the stuttering is a bit less pronounced but that's it. The hardware decoder itself is shit, nothing to be done about that. PS: Parkjoy is harder to decode than Crowdrun. Better benchmark material Last edited by STaRGaZeR; 12th January 2012 at 20:19. |
