5th April 2009, 08:05 | #3121 | Link | |
I really hope Smartlabs will release a fixed Version soon. |
5th April 2009, 11:33 | #3122 | Link |
i want to trim a TrueHD track with tsmuxer (or add a negative delay while remuxing, which essientally should be the same?)
i would like to trim it as precisely as possible (in ms), i need to trim it 3m:45s:516ms which is 223516ms, tsmuxer only accepts a 5 digit input, why is that (question to Roman) and is there any way around it? as was mentioned in the thread about my prob in the Audio encoding forum, is it correct that trimming/delaying a TrueHD stream only works when the source is already a muxed .m2ts and it doesn´t work with demuxed files? |
5th April 2009, 12:12 | #3124 | Link |
I found another Problem.
The Popcornhour cant detect (auto framerate detection) 24.000Fps Stream properly when remuxed with TSmuxer. The untouched M2ts workd fine ,MKV too. Ok, you can say that these Problems (DTS HRA Bug too) are more or less popcornhour related...sure, but these Problems are only caused by TSmuxer when (re)muxing into M2TS. |
5th April 2009, 13:44 | #3125 | Link | |
5th April 2009, 16:35 | #3126 | Link | |
So its something wrong with HRA even at 1.2.9. Going to test the original m2ts at my Tvix |
5th April 2009, 16:49 | #3127 | Link | |
Played the original m2ts file at my TviX AND there areNO SOUND either So its a firmware issue for the TVIX not the TsmuxeR |
5th April 2009, 17:40 | #3131 | Link |
6th April 2009, 09:43 | #3133 | Link | |
Its a Probhlem caused by new TSmuxer Versions !! All newer Versions are NOT working clean with DTS-HRA But the old v1.2.9 can mux DTS-HRA into M2TS and the Popcornhour and some orher SA Player can read/passtrough it @pirateburner Ive absolutly no Problem with untouched M2TS Streams on my Popcorn A110. M2TS with TrueHD/DTS-HD/HR..works perfectly fine. Only remuxed M2TS output from TSmuxer breaks the playback of DTS-HRA. Last edited by ACrowley; 6th April 2009 at 09:50. |
6th April 2009, 17:07 | #3134 | Link |
thx for the hint Dean, the 1.8.4 GUI really accepts more than 5 digits in the trim/delay box while the new 1.8.30 GUI only accepts 5 digits
@ Roman: could you please change that back in the new GUI so that more than 5 digits are allowed in the delay/trim box? tia |
6th April 2009, 23:53 | #3135 | Link | |
New version of tsMuxeR is available: http://www.smlabs.net/tsmuxer_en.html
Two new features added: Sony wave64 support and mkv chapters. Also, this version includes new experimental feature: parameter "secondary" for video streams. This options allows to mux PIP video stream. tsMuxeR centers PIP streams on the screen by vertical position. Possible this function allows to resolve problem with cropped video in future. This options available in tsMuxer only and does not provided in tsMuxerGUI. sucker Quote:
7th April 2009, 00:43 | #3138 | Link | |
edit. It extracted ok with winrar but not with window built in zip. Last edited by nwg; 7th April 2009 at 00:49. |
7th April 2009, 00:55 | #3139 | Link | |
edit: I also got it to open with winrar, but get the corrupt message trying to open it with windows zip Last edited by cavediver; 7th April 2009 at 01:09. |
tsmuxer |
