1st February 2007, 12:39 | #361 | Link |
it would be nice if we can choose the mpa + the mpv directly on the computer, (i've delete the original evo... and i no longer have the HDdvd to have a new one) ?
It'll be very great (possible to have batman working with sound with this method ? :S) |
1st February 2007, 14:07 | #363 | Link |
Take your time , it's good i've refind the evo , but i'm still interested but what i said ^^, moreover i've remux batman, and no problem with the frame ! very good !, i've also chosen an audio track but can't hear any sound..., i think i've chosen the french track and it's not the default track... so if you can put in your program the possibility to change the default track, u are a champion
I confirm what i said, i've now chosen the audio track 0 and it work fine !, i'll try with a playlist to watch i can choose the french track... but can you watch if it's possible to change an audio track to a default track ? i'll tell you more in few hours about my tests Last edited by CptAlex; 1st February 2007 at 14:15. |
1st February 2007, 14:55 | #364 | Link | |
Coder
Download from here: http://pel.hu/down/EVOdemux.exe Please test it. Last edited by Pelican9; 3rd February 2007 at 00:22. |
1st February 2007, 22:14 | #367 | Link |
You need to add a 'b' after 53
Pelican, could you included an option to slice output to 4.7GB or 8.5GB? And the default destination should not be what the XPL file is at, as sometimes I just read it from the dics directly. Last edited by tonyp12; 1st February 2007 at 22:17. |
1st February 2007, 22:52 | #368 | Link | |
Coder
There was, I swear...
default destination: Options/Output folder |
2nd February 2007, 03:42 | #369 | Link |
i've been trying this with varying degrees of success since this thread started. i've been able to demux avc video (equilibrium) and mux to mp4, then to mkv as seen here. . this plays back perfectly in mpc with coreavc (fps specified in yamb)
vc1 vids (e.g supes returns) i have to re-encode due to probs with sonics codecs (with them being registered i cant play back avc video as they mess other codecs around). i tried microsofts vc1 decoder (linked to in another thread - no joy, back to sonics). this works (after some messing around due to a lack of a frame count). the main issue is getting sound. the method in the link above works but can result in getting the soundtrack or a commentary. i figured demuxing all would be the best bet. now the problem is still the sound. video, whether avc or vc1 i can control to a point, but nothing will let me deal with the audio tracks. graphedit wont even recognise the dd+ file and wont let my try to set it up to be played with the sonic codecs. anyone else in the same position? |
2nd February 2007, 12:37 | #374 | Link |
i can't renumber the stream...
I have rebuilt the evo of batman, now i have a .evo file of 18go, with the english track by default (i can't have the french track by default...) and it work well. (video and english sound perfect) |
2nd February 2007, 14:13 | #375 | Link |
@all,
I know, this is not exactly the topic of this thread, but I am desperately looking for some answers and really beg for your help. What exactly is a fully hd-dvd compliant structure ? I am asking because, I would like to do the following: 1) Demux .evo file 2) Bring a normal DD5.1 audio track lipsync 3) Rebuild the .evo file 4) Split the .evo file to 8,5GB parts to fit on DVD-DL 5) Reauthor every 8,5GB part as an independent HD-DVD 6) Watch the backup on XBox360 HD-DVD drive Any chance this would be possible ? Thank you all very much in advance. |
2nd February 2007, 15:18 | #376 | Link |
the furthest i've gotten so far with the audio (thanks to windvd) is to be able to play it back in graphedit and play via avs in mpc. problem is, whether the source is an evo file or the demuxed audio track - the length is 24 minutes roughly.
the same for the uncompressed wav written in an attempt to extract a usable audio track. bizzare |
2nd February 2007, 15:47 | #377 | Link | |
2nd February 2007, 16:54 | #378 | Link | |
Coder
Do you have the latest version? EVOdemux 0.54b makes a .pts file for every subtitle (It contains the timing information for the subtitle stream). I've made another tool to process the demuxed subtitles (it's need the .pts file too). It can make an .srt file, looks like this: Code:
0:01:14,046 --> 0:01:18,608 line 1 2 0:01:18,684 --> 0:01:21,210 line 2 3 0:01:21,286 --> 0:01:24,586 line 3 ... Last edited by Pelican9; 2nd February 2007 at 17:18. |
2nd February 2007, 16:56 | #379 | Link |
Long time lurker, first time poster. I have solved the E-AC3 audio problem for now by using this graphedit flow:
FEATURE_1.EVO -> Intervideo Demultiplexer -> Intervideo Audio Decoder Then I use bepipe.exe, which calls an avisynth script that does a Directshowsource() on the .grf; the 2 channel wav output is piped into aften.exe and re-encoded as normal AC3. So, it's only 2 channel for now, but the sound quality is very good, and if you setup the Intervideo Audio Decoder correctly I believe it will Pro Logic encode the surround sound. Note that the Intervideo demultiplexer retrieves the primary audio stream, which generally is the one you want. You can also substitute in the Sonic Demux and it will usually demux the audio commentary track. It will be nice to have Pelican9's stream re-numbering in the EVO since there is no direct control over which audio is demuxed in Graphedit, and there is no way to decode a demuxed E-AC3 file directly. Last edited by enantiomer; 2nd February 2007 at 18:14. Reason: added more details |
