Old 14th November 2003, 18:27   #521  |  Link
Sirber
retired developer
Sirber's Avatar
RVX will be RV9 + EHQ?
Detritus Software
Sirber is offline   Reply With Quote
Old 14th November 2003, 21:52   #522  |  Link
RadicalEd
Not too sure. I had the privelage of coming across Karl's roommate in a random IRC chat one day, so I got a bit of a personal Q&A. I asked about RV10 and Karl said they weren't really focused on it yet because RV9 with EHQ was so much better and almost like a completely different codec.
It's anybody's guess I suppose :]
RadicalEd is offline   Reply With Quote
Old 15th November 2003, 08:21   #523  |  Link
RadicalEd
There seems to have been an update allowing for EHQ in milestone 8.
https://distribution.helixcommunity....ginated_page=4
[edit]scratch that, the update was just karl's twopass updates. Stevemc screwed up :P[/edit]
Old 15th November 2003, 08:31   #524  |  Link
karl_lillevold
karl_lillevold's Avatar
yes, updates made too late at night without enough communication can sometimes result in not very useful results. Producer M7 + VBR fix is still the recommended encoding combination.
EDIT:
i created another erv4 (RV9) encoder DLL to replace the patch, that
remaps and corrects the complexity levels such that
M8 complexity notation -> M7 complexity notation
high -> very-high
medium -> normal
low -> fast
in this way, Milestone 8 with this patch, now allows for both the
latest 2-pass VBR improvements + very high encoding complexity.
Notes:
without this patch, the complexity levels in M8 are like this
high (default) -> normal
medium -> fast
low -> fast
This information is provided "AS IS" with no warranties, grants no rights, and reflects my personal opinion.
karl_lillevold is offline   Reply With Quote
Old 15th November 2003, 13:51   #525  |  Link
iwod
That was beocz i was boring and spread a bit of rumors. I do believe Rv10 should be in development ( at least on paper ) but i really don't think they would come out so soon.
Considering that there are other little improvement hopefully karl said b4 that is coming up. I belive Rv9 still has some time b4 it goes.
To me, i am very happy with my anime rips with VBR fix and EHQ at my current bitrate. And with some of the upcoming enhancement i believe Rv9 's best has yet to be seen.
( And with Gabest ' MPC and Mkv format Rv9 is simply the best. )
iwod is offline   Reply With Quote
Old 19th November 2003, 00:25   #526  |  Link
phrentec
waprout?
phrentec's Avatar
When encoding using producer.exe i get the error
"Warning: Channel 0 clips moderately."
What does that mean and how can I stop it from happening?
@Sirber: Is there a link to the most current binary of SurrealUI.exe because the link at http://sirber.no-ip.com/~sirber/SurrealUI.exe seems to be down.
phrentec is offline   Reply With Quote
Old 19th November 2003, 00:39   #527  |  Link
karl_lillevold
information from producer mailing list, where this question was just asked:
Those messages are warning from one of the audio checks producer does.
We call these audio watchdogs. You can find more information about the
audio watchdogs in the Producer help page by typing 'producer -m' and
looking at the "-daw" option and reading about the 4 audio watchdog
checks that producer does.
In particular, it looks like your audio signal is too loud and is
clipping.
Old 19th November 2003, 01:20   #528  |  Link
phrentec
waprout?
phrentec's Avatar
thanks for the reply
sorry but what is meant by "clipping"?
Old 19th November 2003, 02:08   #529  |  Link
Sirber
retired developer
Sirber's Avatar
IIRC, sound goes out if it'S range, like if you normalize too much.
Detritus Software
Old 19th November 2003, 02:14   #530  |  Link
karl_lillevold
clipping is a well known digital audio problem when the levels are too loud. Imagine a nice smooth sine wave getting clipped off, ending up with square form instead. This sounds very bad. As long as you are encoding from a file, don't worry about this warning, especially, when it's only "moderate". Producer has a gain control pre-filter with a high quality limiter, if you need to reduce the input levels before compression.
Old 22nd November 2003, 05:53   #531  |  Link
karl_lillevold
ICL 7.1
in other news, upcoming RV9 encoder DLLs (erv4.dll) will be compiled with the Intel Compiler (ICL) version 7.1, which we have now finally fully integrated in our build system. Previously, only certain files were compiled with this compiler, since MSVC 6.0 did not support the required inline asm code.
Since all CPU intensive code is already fully assembler optimized, the improvement is around 5%. Still, worth including, just by changing the compiler (anything to switch from [...])
There is also some good news about the RV9 encoder speed on new hyper-threaded CPUs from Intel, but more about that later.
Old 3rd December 2003, 05:42   #532  |  Link
Sirber
retired developer
Sirber's Avatar
[joke]
Any news about AMD 3DNOW implementation?
[/joke]
I can't wait to try it
Detritus Software
Old 3rd December 2003, 20:12   #533  |  Link
karl_lillevold
No specific AMD improvements, but since AMD without SSE2 is slower in EHQ mode than a P4, this improvement should be very useful:
RV9-EHQ with fast 1st pass : http://forum.doom9.org/showthread.php?s=&threadid=66132
Old 5th December 2003, 01:21   #534  |  Link
Sirber
retired developer
Sirber's Avatar
OGM --> RMVB bug
Hi
the splitter from the first pass isn't closed, so there is 2 splitter loaded in the second pass.
[edit]
With RealAnime, I can't encode 2-3 OGM in a row. Producer IDLE coz old splitter are still active.
Detritus Software
Old 9th December 2003, 13:56   #535  |  Link
Sirber
retired developer
Sirber's Avatar
Bug report
producer fail to encode a file with "&" in it's name
[edit]
about the last OGM bug, I'll use AVISynth so everything will be ok.
Detritus Software
Old 9th December 2003, 21:07   #536  |  Link
slavickas
I'm Shpongled
slavickas's Avatar
Re: Bug report
i think it's present all the time, i noticed and forgot it about year ago
slavickas is offline   Reply With Quote
Old 21st December 2003, 02:44   #537  |  Link
Sirber
retired developer
Sirber's Avatar
@Karl
Could it be possible to have settings for:
1) Force "keep high freq"
2) Force minimal bitrate
Thanks!!!
Detritus Software
Old 22nd December 2003, 23:09   #538  |  Link
karl_lillevold
@Sirber: that's a good suggestion... I will maybe not add exactly those settings, but perhaps a new "high bitrate" mode, where the codec's adaptivity is less aggressive, specifically for B frames, and choice of quantizers. This adaptivity was previously tuned for medium to low bitrates.
Old 1st February 2004, 15:09   #539  |  Link
Sirber
retired developer
Sirber's Avatar
Producer 10 doc
128 Kbps Stereo Music - RealAudio 10 raac 0 44.1 kHz RealPlayer 8
64 Kbps Stereo Music - RealAudio 10 raac 0 44.1 kHz RealOne Player
Might be a bug, cause Codec Flavor is the same for 2 different setting...
Detritus Software
Old 2nd February 2004, 20:43   #540  |  Link
damrod
damrod's Avatar
i think it's normal since producer.exe is a cmdline soft no?
when i launche producer i use " in my cmdline
"c:\producer\producer.exe" -i "c:\test;avs" -o "c:\test.rmvb" ....
Projects :
(dev stopped) DamBatch, MBatch
(generate mkv/mp4 files with aac(+)/vorbis/mp3 and x264/xvid/real or simple avi with h264/mp3 for fast reencoding using mencoder)
Website : Damrod.com
damrod is offline   Reply With Quote
