Old 19th September 2014, 16:28   #21  |  Link
mdalacu
mdalacu's Avatar
Originally Posted by GodRealm View Post
In Mediainfo tool appears rc: abr and no rc: 2 pass.
I'm enabling 2 pass mode. But after I finish work, I'll check with Mediainfo, is displayed information --rc as abr and not as 2 pass.
In my opinion this is the way it should work. 2 pass is necessary for creation of an efficient abr file with a size restriction. If you look at Output tab it will see that ffmpeg is using 2 pass...
mdalacu is offline   Reply With Quote
Old 31st October 2014, 19:17   #22  |  Link
mdalacu
mdalacu's Avatar
New, big release: v1.5.0!
Changelog:
- Parallel jobs - you can run multiple jobs in the same time
- Initial job progress implementation
- Split UI improvements
- Running under WINE is more robust now (Mac Os)
- Internal code rework
- Some bugs fixed
- Updated FFmpeg binary with latest version
I hope you like it and please provide feedback!
Old 6th November 2014, 18:44   #23  |  Link
manolito
manolito's Avatar
Very nice, I already like it better than Handbrake...
I think this thread is in the wrong section, it belongs under MPEG-4 Encodcer GUIs.
Can a mod please move it?
Cheers
manolito
Old 7th November 2014, 08:03   #24  |  Link
mdalacu
mdalacu's Avatar
Cheers
manolito
I am glad that you like it . Thank you.
And, i also think that this thread can be moved by a moderator in MPEG-4 Encodcer GUIs.
Old 17th November 2014, 10:46   #25  |  Link
mdalacu
mdalacu's Avatar
Thanks for moving the thread.
Old 24th November 2014, 09:05   #26  |  Link
CommonMortal
This is very useful, specially the video copy feature! One question please. What's the format i must put other parameters? I mean, the way i must put "subme 9" for example? I get failure message.
Another thing. It would be nice, if there was a way to save my encoding preferences. It seems when you launch again, it all turns to auto and default settings and you have to put again manually everything.
CommonMortal is offline   Reply With Quote
Old 24th November 2014, 13:07   #27  |  Link
mdalacu
mdalacu's Avatar
Hi, Thank you for your kind words.
You can use "subme=9" entered in the Params field.
You can not save encode settings, but you can create video and audio profiles and the apply them using right click (a very fast way). I can not create an a profile with whole settings (video, audio, subs) because i don't know in advanced the number of streams for it to be applied to....
Did it work for you?
Thx.
Old 26th November 2014, 08:08   #28  |  Link
CommonMortal
Thx.
Thank you. You already had a tip in the GUI, how dumb of me. Yes, it worked fine. Oh, any chance you can put audio in AC3 DPLII, like Handbrake does? Also, it would be nice to have an option like "anamorphic none" for DAR in Handbrake. It's the only way i don't mess with DAR... But i know, this way it would become a Handbrake clone i guess... Still, the video copy is useful for me. So thanks.
Old 27th November 2014, 15:04   #29  |  Link
mdalacu
mdalacu's Avatar
For "anamorfic none" you can empty the DAR box and the program will not make any aspect ratio modifications or if you want you can write 1:1 to force an square pixel format.
As for DP2 i don't know if or how to do it yet...
Old 27th November 2014, 18:39   #30  |  Link
CommonMortal
Thanks! Yeah only Handbrake i 've seen uses Dolby Prologic II, so it must have a support for such encoder that i guess it's not easy to find. Thanks anyway, it's useful.
Old 6th February 2015, 07:36   #31  |  Link
mdalacu
mdalacu's Avatar
Version 1.6.0 is up! :-)
Minor release:
- Added checkup for not overwriting the source file.
- You can assign dmMediaConverter to open media files. (ex. Right clik on file and "Open with..." dmMediaConverter's executable). You can use it like media info.
- Now bitrate will be shown in kbit/s for better readability.
- Small UI fixes
- Updated FFMpeg binary with latest version
http://dmsimpleapps.blogspot.ro/2014...converter.html
Old 6th February 2015, 14:32   #32  |  Link
manolito
manolito's Avatar
Thanks! Working fine...
Cheers
manolito
Old 12th February 2015, 17:06   #33  |  Link
Bozotheclown
try this app today, few of my suggestion:
- the help on first run is good idea, can you also add balloon tips when mouse is on important options (enable, copy, etc.)
- when I uncheck enable checkbox the copy checkbox is still active
- add subtitle preview
Bozotheclown is offline   Reply With Quote
Old 13th February 2015, 08:17   #34  |  Link
mdalacu
mdalacu's Avatar
Thank's for your suggestions.
1. it could be done
2. it greys out when you uncheck enable. Has nothing to do with copy.
3. i don't think that i can do it.
Old 26th February 2015, 18:36   #35  |  Link
ziemlichdunkel
Seems perfect Alternative to VidCoder, but please add auto Bitrate Calculation for 2pass (Input in MB)...
Thank you in advance...best regards.
ziemlichdunkel is offline   Reply With Quote
Old 22nd May 2015, 14:34   #36  |  Link
mdalacu
mdalacu's Avatar
Version 1.7.0 is up
- Burn text based subtitles (not yet picture based).
- Now you can manually specify additional FFMpeg filters (More) for audio and video streams.
- On linux it removes automatically "'" from metadata. Workaround for MKVToolNix generated files.
- Added option for auto add subtitle file (only *.srt for now).
- Small UI fixes and bugfixing
Old 16th September 2015, 14:20   #37  |  Link
mdalacu
mdalacu's Avatar
#dmMediaConverter
Version 1.8.0 is up
- Watermark. Double click on image to quickly position the logo.
- First Mac OSX native build. Soon available on Amazon for 5$.
- Estimate encoded stream size if the encoding type is CBR. @ziemlichdunkel
- Small UI fixes and refinements.
- Small bugs fixes.
- Updated FFMpeg binary with latest version.
Old 17th September 2015, 12:50   #38  |  Link
mdalacu
mdalacu's Avatar
I have implemented this, it shows an estimate of the encoded stream size if the encoding type is CBR.
Is it ok for you?
Old 17th September 2015, 16:40   #39  |  Link
manolito
manolito's Avatar
Thanks for the new version...
One thing: The output status window does not scroll any more as it did with the previous version. It always goes back to the top and causes an annoying flicker.
//EDIT//
Please disregard the above. Completely overlooked the new "Follow" checkbox at the bottom right of the output window.
Cheers
manolito
Old 18th September 2015, 09:22   #40  |  Link
mdalacu
mdalacu's Avatar
//EDIT//
Cheers
manolito
Yes, i have done this because on Windows XP i had some problems with large Output text and updating the last line.
ffmpeg, frontend, gui, handbrake, linux
