Old 18th April 2009, 15:52   #21  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
index.bdmv defines how many titles you will have, what will happen when you insert the disc (first play#) and where is your menu (top menu#). In case of no menu (as in tsmuxer), top menu has a jump title 1 to play your movie.
It is not really important now - it is good that your little tool works fine with tsmuxer's output as of ver. 1.9.9 (and probably with BD-Rebuilder "movie-only" mode).
Old 18th April 2009, 16:10   #22  |  Link
rotty
Ok Deank
And thanks for ALL your help
rotty is offline   Reply With Quote
Old 18th April 2009, 17:22   #23  |  Link
nwg
clown_bd is useful to automatically force a subtitles when demuxing/muxing to a movie only. It will force the first subtitle if there is more than one so, put the one wanted first (can change the order).
http://forum.slysoft.com/showthread.php?t=25818
nwg is offline   Reply With Quote
Old 18th April 2009, 17:31   #24  |  Link
deank
deank's Avatar
The idea was to use a tool after a compilation/folder is already created. To ease the steps of opening BDedit and doing it yourself.
Old 2nd May 2009, 16:02   #25  |  Link
rotty
Have put the download for the simple program as first txt in this thread. The program also auto detects where to place the "repeat/no repeat play" command.
