Old 11th June 2003, 17:30   #41  |  Link
zedude
@ karl :
i registered the new keys but these keys override any further settings in audience, true ? (in fact, if i register complexity at 80 and ask for 70 in audience , producer will still encode at 80 ? )that's what i realized.
so i might guess i have to delete keys in registry ?
@ nah :
<UseThread> markup will also be deleted from rmfactory in next release. About avi ( now avs too ) input , give me please some ideas on how to improve it : i can't read in users mind , neither can they in mine ( i 'really' should write some docs )
pardon my frenglish...
zedude is offline   Reply With Quote
Old 11th June 2003, 17:32   #42  |  Link
Sirber
retired developer
Sirber's Avatar
Originally posted by zedude
[B]so i might guess i have to delete keys in registry ?
Don't do that
Detritus Software
Sirber is offline   Reply With Quote
Old 11th June 2003, 17:36   #43  |  Link
DaWolf
RV9 Fan
Indeed.
A nicer, simpler way is to have a reg-file for the different settings. That way you can switch from one to the other simply by clicking on the appropriate reg-file.
Ruud
"In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move."
DaWolf is offline   Reply With Quote
Old 11th June 2003, 19:23   #44  |  Link
RadicalEd
Originally posted by Sirber
What's the point in decompressing RMVB?
psnr :\ and compare/subtract scripts in avisynth.
Also people always ask on amv.org how to convert RM to something else and I think I remember karl saying that EO uses a crappy renderer or something to decode, but that's what I've always used and recommended because it's like the only thing that works.
RadicalEd is offline   Reply With Quote
Old 11th June 2003, 20:50   #45  |  Link
karl_lillevold
karl_lillevold's Avatar
PSNR calculations can sometimes be very inaccurate. For instance, we have a built-in filter that removes potential capture noise along the edge of the video. Even though the resulting compressed video looks better than the original for those areas, it will significantly degrade a PSNR number, which just looks at pixel for pixel differences. I have no idea how a program like EO video will affect PSNR when it saves RM files as AVI files. By using the proper audience settings it is possible to disable this noisyEdgeFilter though, and there are also some other settings which can be used, but I will leave it as an exercise for the reader to check the producer documentation for these options. Even then there could be problems with rate control and dropped frames. So it is possible to get accurate numbers, but a little complex.
This information is provided "AS IS" with no warranties, grants no rights, and reflects my personal opinion.
karl_lillevold is offline   Reply With Quote
Old 11th June 2003, 20:54   #46  |  Link
karl_lillevold
@ karl :
Actually, since you are using an audience file, it would be best to not touch the registry. You should place these options in the audience (or job) file.
The registry settings are meant to enable this mode in the old GUI Helix Producer and other tools which have not (yet) included the ability to set this mode in the audience file
Or it is nice for those that always want to use encoderComplexity=80, and not have to worry about remembering to enable this in whichever tool they use. And then it would be bad if your tool decided to delete these keys. They are meant to always over-ride whichever setting would otherwise have been chosen.
Old 11th June 2003, 21:30   #47  |  Link
zedude
yes karl, i deleted the keys in registry and now i can choose complexity for each encoding
Old 12th June 2003, 00:19   #48  |  Link
BigPapaSmurf
Some results with the EHQ-mode:
1 pass, quality 85, 132Kbps sound.
Clip 1: 1162 frames, 25fps, 448x336 (Bright, medium motion, clean);
Complexity 65: 1957Kbps, 10.9MB, ~1799Kbps video (.478 b/p)
Complexity 80: 1558Kbps, 8.68MB, ~1406Kbps video (.374 b/p)
Clip 2: 1446 frames, 25fps (Bright, high motion, noisy at times);
448x336 complexity 65: 3139Kbps, 21.8MB, ~2965Kbps video (.788 b/p)
448x336 complexity 80: 2603Kbps, 18MB, ~2436Kbps video (.647 b/p)
512x384 complexity 65: 3846Kbps, 26.7MB, ~3662Kbps video (.745 b/p)
512x384 complexity 80: 3161Kbps, 21.8MB, ~2987Kbps video (.608 b/p)
Oh, and hi ppl!
BigPapaSmurf is offline   Reply With Quote
Old 12th June 2003, 01:02   #49  |  Link
Sirber
retired developer
Sirber's Avatar
Welcome to the world of Real Video
Detritus Software
Old 12th June 2003, 04:18   #50  |  Link
wing1
MaxStartupLatency=60 makes my day I am seeing the most quality increase using this option.
wing1 is offline   Reply With Quote
Old 12th June 2003, 12:32   #51  |  Link
Sirber
retired developer
Sirber's Avatar
Does it increase the "time to encode"?
Detritus Software
Old 12th June 2003, 13:58   #52  |  Link
uaco72
How can you encode with a prefixed quality percentage?
uaco72 is offline   Reply With Quote
Old 12th June 2003, 17:02   #53  |  Link
31 Flavas
RV10 Nerd
You have to ehit the .rpad or the .rpjf. Change the encoding type to vbrquality I believe. Also change the quality to what ever you want.
<encodingType type="string">vbrBitrate</encodingType>
<quality type="uint">95</quality>
31 Flavas is offline   Reply With Quote
Old 12th June 2003, 17:13   #54  |  Link
karl_lillevold
hmm, perhaps you meant
<encodingType type="string">vbrQuality</encodingType>
<quality type="uint">85</quality>
vbrQuality instead of vbrBitrate. Note that the <maxBitrate type="uint">99999999</maxBitrate> has an effect when vbrQuality is used, so if you want a very high quality, make sure to set maxBitrate high enough.
Also note that RV9's quality levels are very different from other codecs, so for instance RV9 at 85 is not the same as 85 for any other codec.
@BigPapaSmurf: hilsen til Norge fra Seattle! Those bitrate reductions are similar to what I have seen.
Old 13th June 2003, 03:03   #55  |  Link
karl_lillevold
what's next for EHQ
Right now I am looking into speeding up 1st pass to faster than default (complexity 50), while 2nd pass runs at normal complexity 80 speed. I am not sure it will be complete for Producer 9.2 - we shall see, but in any case a temporary build can always be made available from helixcommunity.
Old 13th June 2003, 03:11   #56  |  Link
Sirber
retired developer
Sirber's Avatar
Great news Thanks Karl
1-pass is usualy for live capture, while 2-pass is for file2file encoding. What if I set Complexity higher than 80? Will I get better results?
Detritus Software
Old 13th June 2003, 03:16   #57  |  Link
karl_lillevold
better quality for complexity > 80? No, (not yet).
(just in case there was a misunderstanding: what I meant was that for 2-pass encoding, I am trying to make the 1st out of the two passes run much faster than the 2nd pass)
Old 13th June 2003, 14:46   #58  |  Link
Sirber
retired developer
Sirber's Avatar
Ha!
I was misunderstanding .
Detritus Software
Old 13th June 2003, 14:50   #59  |  Link
wing1
@sirber
no it does not increase encoding time.
I am using 1-pass encoding all the time with RV9, and I found that it is good enough already. Filesize wise, it is perfectly acceptable with 1-pass encoding
Old 13th June 2003, 15:06   #60  |  Link
Sirber
retired developer
Sirber's Avatar
Originally posted by wing1
@sirber
On low-motion scene (anime):
CBR: 300kbps
VBR: 30kbps
On high-motion scene (anime):
CBR: 300kbps
VBR: 800kbps
Same output filesize
2-pass VBR is the best, it's long, but the overal quality is better IMO.
[edit]
I'd like to use max startup latency in Helix GUI...
Detritus Software
