15th February 2009, 19:31 | #8261 | Link | |
I'm trying to demux the blu-ray 'While She Was Out'. This is what ea3to tells me about the stream:
eac3to v3.08 command line: "E:\TVIX\eac3to\eac3to.exe" "R:\" 1) 1: "D:\DEMUX\New\Chapters_1.txt" 2: "D:\DEMUX\New\Video_2.*" -slowdown 4: "D:\DEMUX\New\Audio_4_English.AC3" -slowdown 3: "D:\DEMUX\New\Audio_3_German.AC3" -slowdown -LOG="D:\DEMUX\New\eac3to_PASS3_LOG.LOG" ------------------------------------------------------------------------------ M2TS, 1 video track, 2 audio tracks, 1 subtitle track, 1:22:24, 50i 1: Chapters, 17 chapters 2: VC-1, 1080i50 (16:9) 3: DTS Master Audio, German, 5.1 channels, 16 bits, 48khz (core: DTS, 5.1 channels, 16 bits, 1509kbps, 48khz) 4: DTS Master Audio, English, 5.1 channels, 16 bits, 48khz (core: DTS, 5.1 channels, 16 bits, 1509kbps, 48khz) 5: Subtitle (PGS), German Creating file "D:\DEMUX\New\Chapters_1.txt"... [a04] The ArcSoft and Sonic decoders don't seem to work, will use libav instead. [a04] The libav DTS decoder doesn't decode the full DTS-HD information. <WARNING> [a03] The ArcSoft and Sonic decoders don't seem to work, will use libav instead. [a03] The libav DTS decoder doesn't decode the full DTS-HD information. <WARNING> [v02] Extracting video track number 2... [v02] Writing new framerate "24fps /1.001" to bitstream. [a03] Extracting audio track number 3... [a03] Extracting DTS core... [a03] Decoding with libav/ffmpeg... [a03] Remapping channels... [a03] Changing FPS from 25.000 to 23.976... [a04] Extracting audio track number 4... [a04] Extracting DTS core... [a04] Decoding with libav/ffmpeg... [a04] Remapping channels... [a04] Changing FPS from 25.000 to 23.976... [a03] Encoding AC3 <640kbps> with libAften... [a04] Encoding AC3 <640kbps> with libAften... [v02] Creating file "D:\DEMUX\New\Video_2.vc1"... [a03] Creating file "D:\DEMUX\New\Audio_3_German.AC3"... [a04] Creating file "D:\DEMUX\New\Audio_4_English.AC3"... [a04] The original audio track has a constant bit depth of 64 bits. [a04] The processed audio track has a constant bit depth of 64 bits. [a03] The original audio track has a constant bit depth of 64 bits. [a03] The processed audio track has a constant bit depth of 64 bits. Video track 2 contains 123601 frames. eac3to processing took 20 minutes, 43 seconds. Done. However the resulting VC1 stream is 48000/1001, even if I give '-stripPulldown' the resulting stream still has the interlaced flag. Is this normal ? Quote:
15th February 2009, 19:38 | #8262 | Link | ||
AFAIK Blu-Ray does not support 1080p25 content. If you want PAL framerate, you have to use 1080i50. Don't ask me why the Blu-Ray companies have made such a stupid decision... |
15th February 2009, 19:39 | #8263 | Link |
eac3to v3.09 released
http://madshi.net/eac3to.zip Code:
* added support for MKV "SRT/UTF8", "SRT/ASCII", "ASS" and "SSA" subtitles * increased some internal buffers to avoid AC3 overflow in the "thd ac3 joiner" * fixed: frame counting didn't work for MKV video tracks * fixed: video tracks FPS change was sometimes declined * fixed: video tracks with "strange" FPS were sometimes handled incorrectly * fixed: clipping removal 2nd pass was executed even for "stdout" * fixed: "eac3to -test" displayed an outdated Nero download link * fixed: specifying a specific playlist still used default playlist's chapters |
15th February 2009, 19:51 | #8264 | Link | |
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 15th February 2009 at 19:53. |
15th February 2009, 19:59 | #8265 | Link |
the 1080i50 is a shop bought blu-ray. i guess it's tsMuxeR that's wrecking it, but thankfully a straight copy of the main stream onto my TVIX HDD is playable.
tsMuxeR GUI doesn't even reckognise the VC1 stream, and the CLI accepts it and chews it up. I'll try again with manually setting the framerate to see if that helps. |
15th February 2009, 20:14 | #8267 | Link | |
as to identifying which title/playlist is the "right" title, I wouldn't know how to figure that out programatically, I guess the easiest way for now is just manually, i.e. to try the disc in a standalone player or software player and see what the chapters are there and then see which title eac3to identifies that matches presumably, to do this programatically, you'd have to do what a player does and navigate through the disc's playback logic, taking into account user menu choices and such-like along the way - no doubt far more than eac3to was ever envisioned as doing! - I think the way it is right now is perfectly fine!! |
15th February 2009, 20:15 | #8268 | Link | |
Aging Video Hobbyist
Thanks madshi for the update! |
15th February 2009, 20:47 | #8269 | Link | |
oops, no languages with 3.09
15th February 2009, 21:47 | #8271 | Link |
Hmm, this is odd. I retested and it is "not working correctly" in versions 3.06 through 3.09 but with earlier versions it "works fine". The problem is not just in reporting either as it actually falls back to libav/ffmpeg.
15th February 2009, 22:18 | #8272 | Link | |
A while ago I tested the Nero decoder by feeding it an E-AC3 test frame. Then I thought about adding support for the Nero 9 AC3 decoder, which however can't decode E-AC3, anymore, but only AC3. So I changed the Nero decoder test to decode an AC3 test frame. But in the meanwhile I've decided that adding Nero 9 decoder support doesn't make much sense without E-AC3 support, so I recently switched back to testing E-AC3 decoding instead of AC3 decoding. I don't remember exactly in which version I changed that (it's not in the changelog, I think), but it could have been v3.06. So my best guess would be that AC3 decoding works on your PC, but E-AC3 decoding does not produce the expected results. Don't ask me why, though. As I said, on my PC it works just fine. |
15th February 2009, 22:21 | #8273 | Link |
eac3to v3.10 released
* Blu-Ray title listing now includes chapter information * fixed: v3.09 didn't show track languages for Blu-Rays |
15th February 2009, 22:38 | #8276 | Link |
Microsoft Windows [Version 6.0.6001] Copyright (c) 2006 Microsoft Corporation. All rights reserved. C:\unzipped\eac3to>eac3to.exe "Z:\Movies\Chungking Express\Chung Hing sam lam.mkv" -logmkv EBML DocTypeId: "matroska" DocTypeVersion: 1 DocTypeReadVersion: 1 Segment Meta Seek Information Seek SeekID: (binary, len: 4) SeekPosition: 4099 Seek SeekID: (binary, len: 4) SeekPosition: 4249 Seek SeekID: (binary, len: 4) SeekPosition: 13110584910 Seek SeekID: (binary, len: 4) SeekPosition: 13110552269 Void: (binary, len: 4025) Segment Information TimecodeScale: 1000000 MuxingApp: "libebml v0.7.7 + libmatroska v0.8.1" WritingApp: "mkvmerge v2.4.2 ('Oh My God') built on Jan 18 2009 17:30:28" Duration: 1:42:56.160 DateUTC: 2/2/2009 3:48:18 AM SegmentUID: (binary, len: 16) Track Track Entry TrackNumber: 1 TrackUID: 1 TrackType: video FlagEnabled: 1 FlagDefault: 1 FlagForced: 0 FlagLacing: 0 MinCache: 1 TrackTimecodeScale: 1 MaxBlockAdditionID: 0 CodecID: "V_MPEG4/ISO/AVC" CodecDecodeAll: 1 CodecPrivate: (binary, len: 41) DefaultDuration: 41708299 Language: "chi" Video PixelWidth: 1800 PixelHeight: 1080 FlagInterlaced: 0 DisplayWidth: 5 DisplayHeight: 3 Track Entry TrackNumber: 2 TrackUID: 707616952 TrackType: audio FlagEnabled: 1 FlagDefault: 1 FlagForced: 0 FlagLacing: 1 MinCache: 0 TrackTimecodeScale: 1 MaxBlockAdditionID: 0 CodecID: "A_DTS" CodecDecodeAll: 1 Language: "chi" Audio SamplingFrequency: 48000 Channels: 6 Track Entry TrackNumber: 3 TrackUID: 4182481851 TrackType: subtitle FlagEnabled: 1 FlagDefault: 1 FlagForced: 0 FlagLacing: 0 MinCache: 0 TrackTimecodeScale: 1 MaxBlockAdditionID: 0 CodecID: "S_TEXT/ASS" CodecDecodeAll: 1 CodecPrivate: (binary, len: 912) Language: "eng" Void: (binary, len: 1024) Cluster MKV, 1 video track, 1 audio track, 1 subtitle track, 1:42:56, 24p /1.001 1: h264/AVC, Chinese, 1800x1080 23.976p 2: DTS, Chinese, 5.1 channels, 24 bits, 1509kbps, 48khz 3: Subtitle (ASS) v01 The video bitstream is encoded in a non-standard framerate. C:\unzipped\eac3to> |
15th February 2009, 22:41 | #8277 | Link | |
1st is 3.10, 2nd - 3.08
15th February 2009, 22:49 | #8279 | Link |
eac3to v3.11
* fixed: MKV subtitle track language wasn't shown |
eac3to |
