Old 21st July 2012, 12:24   #41  |  Link
ozok
TEncoder, TX264, TAC
ozok's Avatar
@pintcat
1. Yes it is. Only Bitrate should have been disabled.
2. It passes "-vcodec huffyuv" parameter.
ozok is offline   Reply With Quote
Old 21st July 2012, 19:46   #42  |  Link
pintcat
Are you sure? The resulting video is a little smaller than the general Huffyuv version. Also, MediaInfo tells me that the video codec is FFVH.
pintcat is offline   Reply With Quote
Old 21st July 2012, 20:09   #43  |  Link
ozok
ozok's Avatar
@pintcat Mencoder is selected when you choose huffyuv as video codec, try changing it to FFMpeg. I've change FFMpeg as default Huffyuv encoder.
Old 22nd July 2012, 06:44   #44  |  Link
privatehun
@ozok
have u ever consider mix Tx264 with this one. I like constant quality Factor option than bit rate base option.
privatehun is offline   Reply With Quote
Old 22nd July 2012, 07:52   #45  |  Link
pintcat
Yep, works great. Thanx for clarifying.
Old 23rd July 2012, 02:30   #46  |  Link
ozok
ozok's Avatar
No. These are very different tools.
Old 23rd July 2012, 07:43   #47  |  Link
LigH
LigH's Avatar
The original Huffyuv codec by Ben Rudiak-Gould did not support YV12 natively. This had been added by the libavcodec project (ffdshow VfW Codec), along with a few more fixes for large resolutions.
New German Gleitz board
Old 23rd July 2012, 18:11   #48  |  Link
ozok
ozok's Avatar
Then that explains file size differences.
Old 10th September 2012, 07:01   #49  |  Link
pintcat
Encountered a small issue...
I was trying to convert a QuickTime (MOV) video into a common MP4. The video stream was already h.264, the audio stream was PCM/uncompressed. So here is what I did:
1. Set video to Direct Stream Copy
2. Set audio to be encoded with AAC
3. Chose MP4 as output container
For some reason the resulting video was .MOV again. Apart from that TEncoder did everything I wanted it to do: Copied the video and encoded the audio with AAC. I tried both, FFMPEG and MEncoder with the same result. If I set it to encode both streams, video AND audio, TEncoder gives me the container of my choice, but not with direct stream copy.
Old 10th September 2012, 10:54   #50  |  Link
ozok
ozok's Avatar
Isn't that the expected behavior?
Old 10th September 2012, 12:08   #51  |  Link
LigH
LigH's Avatar
Of course it is expectable that the selected target container will be used when the video stream is recoded.
But if the source video format is compatible with the target container, then it should be possible to change (re-multiplex to) the container format even without recoding the video stream.
Old 10th September 2012, 14:05   #52  |  Link
ozok
ozok's Avatar
Update:
-Added: Video "Direct Stream Copy" is going to use selected container
-Added: A few minor UI changes
-Fixed: Selecting Huffyuv disabled all video settings (thx to pintcat)
-Fixed: Huffyuv resizing, aspect ratio etc problems with FFMpeg
-Fixed: FFMpeg is default encoder for Huffyuv now (thx to pintcat)
-Fixed: Audio extraction may not work properly in some cases
-Improved: Audio codec detection
-Updated: AlphaControls to 7.68
-Updated: FFMpeg to git-070b0e1
Old 10th September 2012, 18:54   #53  |  Link
pintcat
So it was supposed to not change the container if the video was just copied? Never noticed that. Anyway, thanx for the update.
Old 10th September 2012, 19:16   #54  |  Link
ozok
ozok's Avatar
Well, that was what i thought. But what you and LigH say makes more sense now.
Old 11th September 2012, 19:46   #55  |  Link
pintcat
One small suggestion: I noticed that the option for adjusting the aspect ratio is greyed out if 'Direct Stream Copy' is chosen for the video stream. The setting of the aspect ratio is usually part of the container and not the encoder so this option should stay enabled.
Everything else seem to work fine (made only a few tests so far).
Old 23rd September 2012, 11:27   #56  |  Link
ozok
ozok's Avatar
Update:
-Added: Support for Speex (FFMpeg only)
-Added: About 840 device presets (old presets will not work!)
-Added: several new skins
-Added: Support for rmvb files as input
-Fixed: Encoding failed if aspect ratio was forced with some video codecs
-Fixed: TEncoder crashed if "Close TEncoder" was selected as post-encode option
-Fixed: Settings weren't saved if "Close TEncoder" was selected as post-encode option
-Fixed: Video and audio summary problems
-Improved: Audio codec detection (FLAC)
-Updated: MediaInfo to 0.7.60
-Updated: FFmpeg to git-cb3591e
Old 23rd September 2012, 11:28   #57  |  Link
ozok
ozok's Avatar
Actually aspect ratio option is passed directly to the encoders so it makes sense to disable it.
Old 23rd September 2012, 14:27   #58  |  Link
pintcat
I can't speak for all containers, but at least MP4 and MKV support PAR adjustment (without actually changing the video data). Isn't that what your aspect ratio option does?
Otherwise, which PAR would be used on DirectStreamCopy? Simply 1:1 or is it copied from the source video?
Old 23rd September 2012, 17:16   #59  |  Link
ozok
ozok's Avatar
Aspect ratio values are used if video is encoded. Otherwise video streams are just copied. I don't know FFmpeg or Mencoder writes aspect ratio info to container properly. But AFAIK we can say it is also copied from source if video stream is copied as well.
Old 26th September 2012, 20:15   #60  |  Link
ozok
ozok's Avatar
Update:
-Added: User will be warned if given bitrate values are not numeric
-Fixed: Some presets caused size edits and size list to show invalid values
-Fixed: Audio track selection was ignored if "None" video codec was selected
-Fixed: A few UI problems (thanks to Zoni)
-Fixed: In rare cases, TEncoder could not be minimized
-Fixed: Default skin was wrong for portable version
-Updated: AlphaControls to 7.70
-Updated: FFmpeg to git-bbe9fe4
ffmpeg, gui, mencoder, multithreaded, subtitle
