Old 25th October 2014, 11:25   #261  |  Link
SuLyMaN
Hi. Just gave the program a try and while selecting 'Codec options' for MPEG4 I tried using CRF instead of bitrates. It asked me for bitrate and used the bitrate I specified instead of using CRF. How do I change this behaviour? Thanks
SuLyMaN is offline   Reply With Quote
Old 25th October 2014, 15:02   #262  |  Link
LigH
LigH's Avatar
CRF is only available for MPEG4 AVC/H.264 (TEncoder calls it "H264", will probably use the x264 library), not for MPEG4 ASP (TEncoder calls the generic ffmpeg implementation "MPEG4", it is similar to Xvid).
New German Gleitz board
Old 25th October 2014, 18:32   #263  |  Link
SuLyMaN
@ligh: Lovely. Thank you Sir!
Old 31st October 2014, 11:14   #264  |  Link
ultramarine7
First, thanks for the great program.
may I ask how to do this.
I have many mkv file which are interlaced. How do I de-interlace ?
Again, I have many mkv files. I want to mass convert them to mp3 so I can listen to them in the car. It works but the mp3 is CBR. How do I make them ABR ?
thanks!
ultramarine7 is offline   Reply With Quote
Old 16th May 2015, 10:52   #265  |  Link
mike23
How do I crop a video when re-encoding it with TEncoder?
Assume I got a video with black letter box around it.
I want to re-encode the video but crop the black parts. Other tool offer an (auto-)crop function.
How do I do this with TEncoder?
Thx
Mike
mike23 is offline   Reply With Quote
Old 17th May 2015, 09:53   #266  |  Link
mike23
...and another question:
How do I tell TEncoder to use another directory for storing the fat files *.log and *.mbtree?
Currently these files are stored in installation directory but I want to have D:\temp\ folder instead.
Old 18th May 2015, 03:25   #267  |  Link
Honeyko
Honeyko's Avatar
Ozok, a new feature suggestion: Add PAL<>NTSC (25fps<>23/976fps) retiming options with two checkboxes (for video and audio). This will re-encode audio to the new time and re-stream video (if also checked) to the desired frame-rate. (Including video-restreaming would save users an additional step with MKV Merge.)
Honeyko is offline   Reply With Quote
Old 13th March 2016, 13:42   #268  |  Link
Magik Mark
Does tencoder supports 10bit x265 and filters?
Asus ProArt Z790 - 13th Gen Intel i9 - RTX 3080 - DDR5 64GB Predator - LG OLED C9 - Yamaha A3030 - Windows 11 x64 - PotPlayerr - Lav - MadVR
Magik Mark is offline   Reply With Quote
Old 13th March 2016, 14:03   #269  |  Link
LigH
LigH's Avatar
Checking TEncoder 4.10: Nope; already "preset" is an "advanced" x265 option for TEncoder.
Old 26th March 2016, 00:47   #270  |  Link
ntropy
ntropy's Avatar
My conversion from an .m2ts Blu-ray file to ProRes .mov resulted in sideways video -- 1920 became 1080 and vice versa. How do I figure out how to correct this?
Update: I tried remuxing the .m2ts with tsmuxer into new files rather than using the raw blu-ray .m2ts files and the remuxes come through sideways as well.
Update: Nevermind. I found the rotate settings.
ntropy is offline   Reply With Quote
Old 29th January 2017, 17:40   #271  |  Link
royia
Drazick
Hello,
Anyway to use Intel QuickSync using TEncoder?
Is there any other GUI which can handle the task of trans coding many files at once hand has support for QuickSync?
Thank You.
royia is offline   Reply With Quote
Old 29th January 2017, 18:08   #272  |  Link
LigH
LigH's Avatar
Do you need QuickSync for encoding (to which video format, AVC?) or decoding?
As TEncoder is based on ffmpeg or mencoder, and you may be able to compile ffmpeg with some QuickSync support, it may be possible; but I believe to remember that other authors had issues, not easily understanding how to handle such a build.
Hybrid by Selur offers support for some QuickSync accelerated tools, and should also support batch encoding.
Old 31st January 2017, 11:48   #273  |  Link
royia
Drazick
@LigH, Thank You.
I wished for Out of the Box experience form TEncoder.
I will give Hybrid a try.
ffmpeg, gui, mencoder, multithreaded, subtitle
