Old 13th April 2010, 20:00   #621  |  Link
Midzuki
Unavailable
Midzuki's Avatar
Originally Posted by MasterNobody View Post
I added pseudologarithmic slider for ABR with bitrate from 1 to 999999 kbit/s. Hope this would be enough for anyone .
Now all that we need is an 8192x4608 video source.
Midzuki is offline   Reply With Quote
Old 14th April 2010, 06:42   #622  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
Thank you!! MUCH appreciated!!
~MiSfit
Old 14th April 2010, 06:55   #623  |  Link
Blue_MiSfit
why not use crf 0 ? (or 1 or 2...)
BHH
You run into the default --qpmin 10 anything below CRF12 in most cases from my experience. Beyond this is really more than is needed for anything but the finest mastering quality. I'm using this as a mezz file to generate everything between ~600kbps 480p and ~9mbps 1080p, and doing this on a massive scale.
So, in my case it's more important to have a predictable output filesize while still keeping good quality. ~50mbps 1080p24 or 1080i60 ABR gives excellent results in the tests I've conducted, with no visible artifacting even when peeked at with the revealing Histogram(mode="luma") in AviSynth. This is all using rather fast settings as well (something close to --tune veryfast).
Thanks again for tweaking the behavior! This overpriced Digital Rapids box just got a lot more useful to me
~MiSfit
Old 25th April 2010, 17:15   #624  |  Link
Midzuki
Unavailable
Midzuki's Avatar
x264vfw r1564 by Komisar has been released:
http://komisar.gin.by/
UPDATE:
x264vfw r1583 has been released
(2010/May/08)
Old 30th May 2010, 00:43   #625  |  Link
MasterNobody
I think it is the time for beta-testing of new GUI for x264vfw with preset/tuning/profile support.
Build: x264vfw_beta_1613bm_23386.exe
P.S. Beta-period would be one week so please report about found bugs and suggestions earlier.
MasterNobody is offline   Reply With Quote
Old 30th May 2010, 01:22   #626  |  Link
Blue_MiSfit
SWEET
This just keeps getting better and better.
Trying now.
Derek
Old 30th May 2010, 01:28   #627  |  Link
Blue_MiSfit
One suggestion - I personally liked having the other tabs for VUI etc. Maybe add a second tab with some of these settings, along with VBV values and other things that are independent from preset / profile / tune
~MiSfit
Old 2nd June 2010, 23:41   #628  |  Link
MasterNobody
Updated beta2: x264vfw_beta2_1629bm_23430.exe
Sorry, but I don't suggest adding more options to new GUI currently because all other options (in my opinion) are for advanced users only so they can use extra command line.
Old 17th June 2010, 22:01   #629  |  Link
MasterNobody
Release is little bit delayed so here is beta3: x264vfw_beta3_1649bm_23639.exe
Old 27th June 2010, 15:02   #630  |  Link
MasterNobody
Official release of new GUI:
x264vfw_23_1659bm_23819.exe
x264vfw64_23_1659bm_23819.exe
Old 29th June 2010, 09:54   #631  |  Link
buzzqw
HDConvertToX author
thanks MasterNobody!
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 5th July 2010, 21:18   #632  |  Link
Midzuki
Unavailable
Midzuki's Avatar
x264vfw r1666 gets out of the oven
Old 6th July 2010, 11:58   #633  |  Link
komisar
komisar's Avatar
--mbtree/--no-mbtree
from Current Patches, Where to get them, How they affect speed/output thread:
Originally Posted by D3C0D3R
2 komisar - your crazy devil x264vfw build sets mb-tree=0 when use Command line option is off.
Originally Posted by komisar
D3C0D3R, yes... mb_tree=0 because [warning]: lookaheadless mb-tree requires intra refresh
if you known what you do -- add needed options to "Extra options:"-box...
2 komisar - i always place in extra textbox something like "--rc-lookahead 120" and had in 1659 mb-tree=1, but in 1666 i didnt see any warnings and mb-tree=0
AFAIK this is no other way to turn on MB-Tree only to off it ))
in extra options: "--mbtree --rc-lookahead 100" work... try it...
..::[I am live here]..::..[My x264 CLI/VFW builds and tools]::..
komisar is offline   Reply With Quote
Old 5th August 2010, 11:02   #634  |  Link
Amdh
Hi there,
I've really enjoyed x264 VFW ability to output to mkv, however I'm experiencing a problem using that feature. Here's what I've done :
I've edited my video as usual, making the needed filtering and I've set x264 VFW to output to mkv, I've added that to VirtualDub's Joblist and I've executed it right from the Joblist. To my surprise, VirtualDub outputed the Fake AVI file and not the MKV. What's wrong ? Please help.
NB. I'm using VirtualDub 1.9.9 and x264 VFW r1688 KMod
MhX Digital - An Old Fan Of x264
Amdh is offline   Reply With Quote
Old 5th August 2010, 11:10   #635  |  Link
MasterNobody
Do you use full or relative path for mkv output? If relative than may be your looking for resulting MKV in wrong directory. As for Fake AVI it is always created except when you use "Run video analysis pass"
Old 5th August 2010, 11:46   #636  |  Link
Amdh
Could you please explain me the difference between full and relative path ?
I just write -o moviename.mkv and it encodes the MKV to VirtualDub's Folder .. how can I change that ? And by the way, how can I make it output automatically to the same folder as the fake AVI ?
Thanks again for your help.
Old 20th August 2010, 17:22   #637  |  Link
komisar
komisar's Avatar
Amdh
full path: "-o c:\my_video\encoded.mkv" (this works always)
Old 25th August 2010, 06:34   #638  |  Link
Midzuki
Unavailable
Midzuki's Avatar
r1703 is ready
Old 5th September 2010, 04:30   #639  |  Link
Midzuki
Unavailable
Midzuki's Avatar
r1713 has been released:
http://sourceforge.net/projects/x264vfw/files/
Old 5th September 2010, 10:10   #640  |  Link
MatLz
I often say "maybe"...
MatLz's Avatar
With more features, also here :
MatLz is offline   Reply With Quote
