1st October 2005, 05:19 | #42 | Link |
Which is better??? MPEG2DEC3DG.DLL or DGDecode.dll ????
[*] Next, you must have a copy of installed on your computer. At the time of this writing it is contained in a ZIP file DECODEFIX100.ZIP, in the AviSynth plugin list, linked above. Extract that file into a directory called "plugins" under the AVISYNTH directory (created in step 1). Usually it is "C:\Program Files\AviSynth 2.5\plugins\". New Versions of DVD Rebuilder can also use Donald Graft's DGDecode.dll. It comes with the DGMPEGDec package. |
1st October 2005, 13:02 | #43 | Link |
Ridendo Castigat Mores
Use the Installer and you'll be alright
DGDecode is a newer version of MPEG2DEC3DG.
None is as blind as those that don't listen. www.dvdrebuilder.com RME Rockas Software |
21st October 2005, 12:23 | #45 | Link |
I know some builds of 2.5.6 are working fine with DVD-RB... but I also know that there are some that don't... 2.5.5 is the stable one but you can try the others... at your own risk
10th November 2005, 04:18 | #46 | Link |
I looked for a while to see if someone else covered this point and didn't find anything. I hope this is a good thread to bring it up.
My point is this: I am using DVD-RB Pro (glad to pay for it) and have added several tweaks to my rebuilder.ini file that allow me to change the file size of the final .iso based on the runtime of the video and my own judgment as to the amount of motion in the video. When I install new versions of DVD-RB, it asks me if I want to replace the rebuilder.ini file. I select no, so that I don't lose my tweaks. Am I missing out on any features or fixes by not replacing the rebuilder.ini file with every new version? Can you let us know when there have been revisions to the rebuilder.ini file so that I will know to copy my old .ini file and manually add the tweaks to the new .ini file? Thanks. |
10th November 2005, 13:22 | #47 | Link |
@mnfesq
No... you are not loosing anything that you can't select on the Menus of DVD Rebuilder The default "Rebuilder.ini" file only contains a basic "default" config for "first time" users. keep it UP
7th January 2006, 00:30 | #48 | Link |
Grammar correction in installer
I don't mean for this to be critical but I noticed a couple grammar mistakes (most likely due to translation, which I understand). The attached image shows what I mean.
First line correction: "... and it's needed for DVD Rebuilder's process (or processes)" Third line correction: "Click "OK" to have it installed." |
20th January 2006, 10:23 | #49 | Link |
DVD-RB_v1.06Pro.exe Problem
after I installed the latest Pro version I naturally wanted to run it, I then got the attached error, which I have never experienced before. I tried to reinstall an earlier version to see if it too would have a problem, but it would not install as it stated that it was an old version! |
20th January 2006, 13:34 | #50 | Link |
Check if you have mswinsck.ocx on yout Rebuilder's installation folder... if you don't... download the "update only" zip file (the link is on the e-mail sent by jdobbs) and extract the ocx file into rebuilder's folder.
20th January 2006, 14:20 | #51 | Link |
My guess is that you did your installation from the "Updates Only" zip file. That file is not meant for installing DVD Rebuilder for the first time. It normally only includes the files that have changed since the last update. Please download the Full Installer version and use that for installation.
@Everyone Please remember that the "Updates Only" zip file is targeted for those folks who have limited bandwidth on their internet connection. It gives you a way to update to the next version with only a small file down load (about 1.5MB for v1.06). If bandwidth isn't an issue -- please download and use the Full Installer package (about 5.75MB for v1.06) for installations and updates. You will save yourself a lot of possible headaches by doing so. |
21st January 2006, 06:24 | #52 | Link |
@Rockas
The file mswinsck.ocx was installed into the directory. The CRC32 of the file that I have is d75759be. I did what you asked anyway but that didn't work. I then did a full install of the update file, still no other result. @jdobbs I always download the full installer, but thanks for the input. Let me know if you need any other info, etc on my system to make things easier to diagnose for you. |
21st January 2006, 10:08 | #53 | Link |
Hmmm... you must have an outdated DLL somewhere. Try this (assuming you installed in "C:\Program Files\DVD-RB Pro"):
1. Push START/RUN, and type in "CMD" and push ENTER. 2. A command window will pop up. 3. Type the following (include the quotes): regsvr32 "C:\Program Files\DVD-RB Pro\mswinsck.ocx" 4. Push ENTER Then try running DVD-RB again. [Edit] Fixed the mistyped file name. Last edited by jdobbs; 29th January 2006 at 13:00. |
29th January 2006, 09:26 | #54 | Link |
I have since downloaded and installed DVD-RB_v1.061Pro and the same error has come up, so I have done what you suggested (I didn't see your reply until after I installed the new version) and I get the attached error, when I looked, the file you specefied is not in the directory.. So I tried the file "MSWINSCK.OCX" instead, which appeared to work, but more importantly, DVD-RB Pro is now up and running once again..
21st May 2006, 12:45 | #55 | Link |
Hi everybody,
maybe this is a stupid question...but I have problems getting my keyfile for dvd-rb (of course I'm a registered user ). The site key.dvd-rb.com which rebuilder contacts when attempting a web download doesn't answer. Jdobbs, is it possible that some server has crashed? Thank you for your help and of course for this wonderful tool, Rocko |
14th June 2006, 22:26 | #58 | Link |
I've created DVD-ReBuilder Easy Installer.
Now even momma can install and copy DVD movies |
17th June 2006, 09:13 | #59 | Link |
Country Member
zilexa - please don't cross post. See rule 8.
http://forum.doom9.org/showthread.php?t=112394 Regards
Les Only use genuine Verbatim or Taiyo Yuden media. |
4th October 2006, 22:21 | #60 | Link |
Hi BluTach,
I see you are all over the places. Q1: Have you folks tested Zilexa "EasyInstaller" yet? And is it Clean? Q2: Is there a "Dummy Proof" Set up & installation Guide for DVDRB and the Tools used with it???? I have installed the DVDRB 0.98 and I am having difficulty following the guide from AD Forum or this one to set up my CCE Free version ... Thanks, G! |
