Go Back   Doom9's Forum > General > Linux, Mac OS X, & Co
Old 20th January 2007, 03:04   #21  |  Link
shevegen
Moitah, could you list the downloads in your FIRST post, if possible please?
Its a lot easier to keep track of the latest version.
Or link to a little webpage that lists them. Thanks
OS: Paldo (Linux)
AviSynth for Linux, go go go!
shevegen is offline   Reply With Quote
Old 5th February 2007, 11:08   #22  |  Link
nickrout
I am getting this error in mono:
[nick@bilbo ~/mpeg4modifier]$ mono MPEG4Modifier.exe
Mono System.Windows.Forms Assembly [$auto_build_revision$]
Keyboard: United States keyboard layout (phantom key version)
Could not set X locale modifiers
KDE colorscheme read
** (MPEG4Modifier.exe:36789): WARNING **: Missing member add_Shown in type Form, assembly /usr/local/lib/mono/gac/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
Unhandled Exception: System.MissingMethodException: Method not found: 'System.Windows.Forms.Form.add_Shown'.
in <0x00000> <unknown method>
in <0x00015> JDP.frmMPEG4Modifier:.ctor (System.String[] args)
in (wrapper remoting-invoke-with-check) JDP.frmMPEG4Modifier:.ctor (string[])
in <0x00028> JDP.Program:Main (System.String[] args)
Anyone got an ideas on how to diagnose and fix this?
nickrout is offline   Reply With Quote
Old 8th February 2007, 18:46   #23  |  Link
Moitah
@nickrout: Try Mono 1.2.3 which was just released yesterday. It now supports the Form_Shown event. I was able to run MPEG4 Modifier 1.4.4 in Mono 1.2.3 in Windows without any changes.
moitah.net
Moitah is offline   Reply With Quote
Old 24th April 2007, 17:23   #24  |  Link
bollstedt
I need a batch program for windows like the one which is shown in the entry posting. But I don't want to change the packet bitstream stuff in my avis.
Aspect Ratio is my problem! I want to batch the Pixel AR to 4:3 PAL with the aid of a command line batch program. I've tried to replace the "unpack" string into --par<43pal>, but it didn't work.
So, may somebody help me with the command lines and the synthax?
Thanks
bollstedt is offline   Reply With Quote
Old 24th April 2007, 19:30   #25  |  Link
ilovejedd
insane college undergrad
ilovejedd's Avatar
Change --unpack to --par 43pal.
ilovejedd is offline   Reply With Quote
Old 24th April 2007, 20:22   #26  |  Link
bollstedt
it works!!
thanks a lot
Old 4th May 2007, 11:59   #27  |  Link
olnima
olnima's Avatar
Originally Posted by likeatim View Post
maybe you could make that an option?
cause for some weird reason, my standalone player plays everything (even packed bitstream) if the userdata is set to "DivX999b000p"
also, an option to delete or overwrite the original file would be tha bomb...
thanks for the great tool!
I'm working on another GUI-batch-mode-version right now.
Is everything still playable if You just add "DivX999b000p"
to the existing (or not) UserData? That shouldn't be too difficult to implement for batch-mode. If this isn't a solution there won't be another one I think, because You can have 0, 1 or multiple Userdata-strings and in batch-modus, You do not know if You should add or edit (in second case which one) the string(s).
Olnima
P.S.: ...or maybe I could give You the ability to enter a string (like "DivX999b000p") which is added (if no UserData exists) or replaces the first UD-entry.
olnima is offline   Reply With Quote
Old 25th May 2007, 16:51   #28  |  Link
subspawn
subspawn's Avatar
See In-place search & replace (ipsr) on this forum as well Tiny lean & mean C prog for in-place manipulation of UserData in xvid's. Works great in Batch mode
Btw: MPEGModifierCL & GUI both rock The unpack functionality is great and I've learned many things from it's code
subspawn is offline   Reply With Quote
Old 30th May 2007, 17:34   #29  |  Link
mkgordon
MPEG4 Modifer-Mac-batch-Any Terminal whizzes out there?
Greetings,
I have a bunch of AVI files on an external Firewire drive. I'd like to run them through the --unpack process, prior to burning the files to a DivX disk so I can eventually watch them on my DivX enabled DVD player.
I tired just now to use the CLI version of 1.4.4 via Mono 1.2.3 to do this.
I used the following code:
Machine-iMac-G5:/volumes/400Gig/FolderName mike$ for i in 'ls'; do mono /Users/me/Desktop/MPEG4ModifierCLFolder/mmcl.exe --unpack $i converted_$i;done
This code always works well when I used it on files on my main hard drive. But I keep on getting errors when I try it on files on my external drive.
Error: Source file doesn't exist
MPEG4 Modifer CL v1.4.4
http://www.moitah.net/
But when I run it on a single file on my external drive, it works fine:
Machine-iMac-G5:/volumes/FolderName mike$ mono /users/mike/Desktop/MPEG4ModifierFolder/mmcl.exe --unpack /Volumes/400Gig/FolderName/Filename1.avi /users/mike/Desktop/MPEG4ModifierFolder/mmcl.exe --unpack /Volumes/400Gig/FolderName/Filename1.unpack.avi
Loading: 100.0%
Aborting: Video already has the desired format.
Any suggestions? If you don't know, can you refer me to someone?
Cheers,
Mike
mkgordon is offline   Reply With Quote
Old 2nd June 2007, 00:54   #30  |  Link
shevegen
This weekend I finally have the time to test this all
more thoroughly so hopefully I can provide some feedback soon
OS: Paldo (Linux)
Old 13th November 2007, 00:10   #31  |  Link
intellimoo
Moitah:
Do you have a version of MPEG4 Modifier CL in callable library form, like a .dll or .ocx? I would love to be able to use this from a program "natively" rather than shelling the .exe, e.g. (especially just for the unpacking ability).
intellimoo is offline   Reply With Quote
Old 13th November 2007, 00:20   #32  |  Link
Moitah
@intellimoo: No, but if your code is .NET also it would be easy to compile it into a class library and use the classes yourself. Or just compile the .cs files right into your project if it's C#.
moitah.net
Old 30th November 2007, 09:49   #33  |  Link
intellimoo
Ah, darn, vb.net for me. Hopefully I can figure something out....
If anyone is willing to make just the --unpack function (with an --always-write option) into a class I can use in vb.net, that would rock.
Old 31st March 2008, 21:27   #34  |  Link
plugh
A hollow voice says
Per-frame quant info would be useful, I might look into it.
Just ran into a situation where being able to --frame-list the frame quants would be extremely helpful. Are you taking requests?
plugh is offline   Reply With Quote
Old 4th February 2009, 01:41   #35  |  Link
J-Wo
This batch file is great! But instead of unpacking them to another folder, can I write the new files in the same folder as the originals only with the word "unpack" at the end of the file name?
J-Wo is offline   Reply With Quote
Old 6th February 2009, 10:28   #36  |  Link
halsboss
likes to tinker
hello. is there a non .NET version ?
halsboss is offline   Reply With Quote
Old 6th February 2009, 13:55   #37  |  Link
kypec
User of free A/V tools
kypec's Avatar
Try this:
@ECHO OFF
FOR %%I IN (*.avi) DO "C:\Program Files\MPEG4 Modifier\mmcl.exe" --unpack "%%~fI" "%%~nIunpack%%~xI"
kypec is offline   Reply With Quote
Old 23rd February 2009, 14:29   #38  |  Link
halsboss
likes to tinker
One of the best programs ever. Kills the "non packed bitstream .AVI returning frames out of order under certain circumstances" issue dead... http://forum.doom9.org/showthread.ph...22#post1244222
Pity about the .Net requirement, but there you go.
Old 21st March 2009, 00:26   #39  |  Link
halsboss
likes to tinker
Thinking of trying to convert this to non .Net ... any hints or suggestions, or even better has anyone else had a go ?
Old 21st April 2009, 11:27   #40  |  Link
Nexin
Please do,do,do dah da,da,da Convert it not to use .NET then let us have it spread everywhere for us to use. Maybe then Moitah will appreciate the need for non .NET tools.
Nexin is offline   Reply With Quote
