Old 16th December 2013, 12:40   #101  |  Link
Masutin
Is there a tool that can shift the times of all or selected chapters (in TXT for MKV or other) by a specified value?
Masutin is offline   Reply With Quote
Old 3rd January 2014, 11:18   #102  |  Link
szabi
Hi
I have Celltimes.txt input file and I need time based output.
Source:
0
9300
20750
33925
56351
59993
104350
120150
124094
Result:
00:00:00.000
00:06:27.887
00:14:25.448
00:23:34.955
00:39:10.306
00:41:42.208
01:12:32.265
01:23:31.256
01:26:15.754
02:02:29.425
02:22:31.626
But if you check, the calculation is not correct.
This is the correct one:
0:0:0.0
0:6:12.0
0:13:50.0
0:22:37.0
0:37:34.1
0:39:59.18
1:9:34.0
1:20:6.0
1:22:43.19
1:57:28.10
2:16:41.9
2:23:35.6
Of course framerate not changed.
What is the reason for deviation?
EDIT: Now it is ok.
Order of settings was the solution.
szabi is offline   Reply With Quote
Old 12th January 2014, 23:02   #103  |  Link
Masutin
Perhaps you can help and point where else to ask. What entry can be used in the CHAPTERxxNAME field to represent an empty title? If you leave it empty or use a space or a tab, the time code will be the title. However I've seen chapters without titles.
Old 15th January 2014, 02:27   #104  |  Link
nfm
MAGIK
Hello. Is there way to extract chapter position timestamps along with the names of the chapters that you see in a root menu? Currently when I repack the blu-rays into MKV container to stream them using DLNA I have to manually name the chapters. Is there a way to automate?
nfm is offline   Reply With Quote
Old 17th January 2014, 04:07   #105  |  Link
Masutin
nfm, I never used the BD structure, but if you can copy the times and titles in any form, e.g. using MediaInfo, I can write a regular expression to automate conversion into chapters suitable for MKV.
Old 3rd August 2014, 00:24   #106  |  Link
jfcarbel
Programmer
shon3i - Any change you can release the project to google code so some of us can contribute to it.
jfcarbel is offline   Reply With Quote
Old 13th August 2014, 18:45   #107  |  Link
bennynihon
Originally Posted by shon3i View Post
Yes it's possible, it will happen in near future, just be patient.
Has the offset feature been implemented yet?
bennynihon is offline   Reply With Quote
Old 1st December 2015, 21:39   #108  |  Link
chompy
I've just updated to Windows 10 and now I cannot longer drag & drop playlists to ChapterGen, it's only me or anybody else is having the same issue?
chompy is offline   Reply With Quote
Old 20th December 2015, 12:04   #109  |  Link
jpsdr
If i convert a txt muxman file to an OGG file using the program windows interface, the first line/chapter is "CHAPTER00".
If i do the same thing but using the CLI (in a bat file), the first line/chapter is "CHAPTER01".
Old 21st September 2016, 22:50   #110  |  Link
Masutin
Aside from ChapterGen. As with CUE files for some audio files, is a similar approach possible for other media files, i.e. providing timestamps and optional titles in a separate file?
Old 31st December 2018, 01:27   #111  |  Link
Masutin
Which value for -f is needed for the text format used in MKV, to avoid the error Type Mismatch? Tried them all.
Old 31st December 2018, 13:39   #112  |  Link
manolito
manolito's Avatar
The -f OGG parameter should do this, but I found that chaptergen is very picky about the input formats. For me it does works with the "Celltimes.txt" format (IFOEdit frame numbers), but for other formats I often get the Type Mismatch error. What is your input file format?
Since ChapterGen has long been abandoned by its author, I would recommend you check out chapterEditor by hubblec4. It does not have a command line interface, though.
Cheers
manolito
Old 6th January 2019, 20:21   #113  |  Link
jfcarbel
Programmer
Cheers
manolito
Great tool, I wish the source would have been at least put out there for others to update as I would have been open to contributing.
Will have to check out hubblec4 tool.
