Old 5th September 2020, 21:07   #1701  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
LameXP v4.19 Beta-2
https://sourceforge.net/projects/lam...8.exe/download
Changes between v4.18 and v4.19 [unreleased]
* Updated Vorbis encoder to OggEnc v2.88 (2020-07-07), using libvorbis v1.3.7 with aoTuV beta-6.03
* Updated Monkey's Audio binary to v5.54 (2020-08-24), compiled with ICL 19.1 and MSVC 15.9
* Updated mpg123 decoder to v1.26.3 (2020-07-16), compiled with GCC 10.1.0
* Updated MediaInfo to v20.08 (2020-08-11), compiled with ICL 19.1 and MSVC 15.9
* Updated cURL to v7.72.0 (2020-08-19), with libcurl v7.72.0 and OpenSSL v1.1.1g
* Added command-line switch --no-splash, which can be used to hide the "splash" screen at startup
Old 10th September 2020, 10:05   #1702  |  Link
tormento
Acid fr0g
tormento's Avatar
Originally Posted by LoRd_MuldeR View Post
LameXP v4.19 Beta-2
Couple of days the service is unavailable on downloading.
Strange enough, only one mirror has the download file.
Can you please provide a mirror? Binary expired here
@turment on Telegram
Old 10th September 2020, 11:08   #1703  |  Link
manolito
manolito's Avatar
SourceForge downloading can be a bit unreliable...
What always works here is to click on "Problems Downloading?" and then choose the "Direct Link". Just checked for the latest Beta-2, no problems.
Old 10th September 2020, 15:04   #1704  |  Link
LoRd_MuldeR
Software Developer
Just checked, and all of the 16 update mirrors seem to be up and synchronized, so you should always be able to get the latest version via "auto-update" function:
https://pastebin.com/6vhtLuZi
As far as problems with SourceForge.net downloads are concerned, there is not much I can do about this, but I just downloaded the latest version from SourceForge.net without any problem.
Old 21st September 2020, 21:25   #1705  |  Link
LoRd_MuldeR
Software Developer
LameXP v4.19 Beta-3
https://sourceforge.net/projects/lam...0.exe/download
* Updated LAME encoder to v3.100.1-SVN (2020-08-25), compiled with ICL 19.1 and MSVC 15.9
LAME v3.100.1 Release
This is a point release that includes NO changes to the encoding libraries.
This release replaces the previous mpglib decoding library with the libmpg123 decoding library.
Old 16th October 2020, 21:23   #1706  |  Link
MrVideo
MrVideo's Avatar
I notice while starting the program on my XP-32 box, it warns that dwnapi.dll is missing. Doing a little bit of research, I find out that its use starts with Vista. OK, but the strange part is that versions for XP-32 can be found and downloaded.
Is dwmapi really needed and what is it used for with regards to LameXP? I'm guessing that it isn't really important, since the program runs just fine without it.
Old 16th October 2020, 22:58   #1707  |  Link
LoRd_MuldeR
Software Developer
Some Windows API functions are only available in newer Windows versions. If we linked these functions statically, then the executable would no longer be able to run on "old" Windows versions.
The workaround is to import these "optional" functions dynamically, at runtime, via LoadLibrary() and GetProcAddress(). This way, we can use the new API functions where available, but still continue without them otherwise.
Specifically, the DWM (Desktop Window Manager) is only available in Windows Vista an later. LameXP uses DwmEnableBlurBehindWindow() from Dwmapi.dll to enable fancy "Aero" effects on support OS versions.
Old 17th October 2020, 22:16   #1708  |  Link
MrVideo
MrVideo's Avatar
Thanks for the update. Certainly doesn't bother me that blur effects are missing.
Old 22nd October 2020, 01:50   #1709  |  Link
MrVideo
MrVideo's Avatar
Slight problem... the beta has expired. I know, it keeps working. That is why it is slight.
Another slight problem... when trying to check for a new version, the beta says that my internet connection is broken. It isn't.
Old 7th November 2020, 00:09   #1710  |  Link
LoRd_MuldeR
Software Developer
Not quite sure. Nothing about the update check should have changed recently
Can you can press F11 in the update window to show the log?
Old 8th November 2020, 01:41   #1711  |  Link
MrVideo
MrVideo's Avatar
Here is the result:
Checking your Internet connection...
Connecting to host: www.ebay.com
ERROR: Terminated with unknown code -1073741515
Connecting to host: www.gnu.org
Connecting to host: bandcamp.com
Connecting to host: neocities.org
Connecting to host: www.avidemux.org
Connecting to host: support.proboards.com
Connecting to host: www.oxford.gov.uk
Connecting to host: www.jd.com
Connecting to host: marknelson.us
Connecting to host: www.libav.org
Connectivity test has failed: Internet connection appears to be broken!
Just a subset of the list. All sites exit with the some code. I have no clue has to how you are trying to connected to these locations. A simple ping of 8.8.8.8 would be a great test.
Old 8th November 2020, 01:52   #1712  |  Link
nevcairiel
-1073741515 is C0000135, which means "DLL not found". Some component involved in the connection process is not present.
Old 8th November 2020, 13:49   #1713  |  Link
LoRd_MuldeR
Software Developer
Here is the result:
Well, it would indicate that cURL process failed to start, apprently because of a missing DLL.
If I remember correctly, you are one of those diehard Windows XP users. Not that we should care at this point, but for me the cURL binary that ships with LameXP works fine on my Windows XP (with SP-3) VM:
You could try opening the "lxp_curl.exe" form the LameXP "temp" directory with Dependency Walker and see if it reveals anything...
aac, aotuv, flac, lame, lamexp, mp3, mp4, ogg, oggenc, opus, vorbis
