Old 25th August 2020, 09:02   #1  |  Link
YaBoyShredderson
Splitting files to be encoded and then put back together
I want to know of a way to split video files up, so that i can encode them and then put them back together at the end.
I have done 2 quick tests, the first i split a 30 second clip out of a few movies, and then split them into 3 10 second clips and encoded them, put them back together after. But there was audio bugs, as i split, encoded, and stitched the audio as well as the video.
So i did a second, more worst case scenario test, and learning from the previous test, i only encoded the video, and then muxed the audio back in after i had assembled the full video. I took a movie and split it into 10 second chunks, there was 729 of these chunks which were all encoded seperatly in handbrake, all using the same settings. But when i put them back together the audio was way out of sync. I could see any particular point at which it desynced, but it seems to be right from the start, but theres no obvious reason as to why.
Im doing a more reasonable test now, splitting based on frame count rather than seconds, and only using 6 files, still without the audio.
Any tips? If i can do this, it would be incredibly useful. I have been encoding 1080p stuff in handbrake, and just waiting out the whole encode, leaving it over night etc, but with 4k stuff taking in excess of 20 hours in staxrip, its just not feasable for me to wait that long, so if i can split them into chunks that take a few hours, or over night each, which can be put back together agian, that would be very useful.
EDIT: im using mkvtoolnix to split and append the files.
YaBoyShredderson is offline   Reply With Quote
Old 25th August 2020, 09:49   #2  |  Link
tebasuna51
tebasuna51's Avatar
When you encode with Handbrake let the default VFR or you use Constant Framerate - Same as source?
Your source was already VFR?
When there are VFR involved is easy lose the audio sync when recode.
If source and encode are CFR (the full source have the same frames than the fragments) when you add the full audio to the full video recode must be in sync.
Old 25th August 2020, 09:58   #3  |  Link
YaBoyShredderson
The source is 23.976 constant from a bluray. I encoded it as same as source constant framerate.
Old 25th August 2020, 10:23   #4  |  Link
tebasuna51
tebasuna51's Avatar
If the recoded video have the same number of frames and framerate than BD source (that is the same duration), and the audio is properly extracted, must be in sync.
Explain your method to extract video and audio from BD.
Old 25th August 2020, 11:01   #5  |  Link
YaBoyShredderson
To split the video, i use mkv toolnix, deselct everything but but the video stream. The first time i selected split after output duration of 10s with unlimited files, the second, i did by parts based on frame/field numbers. I took the length of the video in seconds, multiplied by 24, divide by 6 to get 6 equal parts. Lets say its 25000 frames. It would like this "1-25000,-50000,-75000,-100000," etc
After i put the video back together, i would take the original unsplit audio from the original file, and mux it into the stitched together video.
Old 25th August 2020, 12:11   #6  |  Link
tebasuna51
tebasuna51's Avatar
mkvtoolnix-GUI can't extract audio from BD's. How do you extract the audio?
Do you load a .mpls in mkvtoolnix-GUI?
The .mpls have many .m2ts?
Or there are only one .m2ts and load the .m2ts in mkvtoolnix-GUI?
The video only can be splitted in I-frames, if you select frames to split maybe the fragments aren't contiguous.
Check if the source video have the same number of frames than the full recoded video.
Old 25th August 2020, 14:19   #7  |  Link
YaBoyShredderson
I use an mkv ripped from the bd. How do i check the number of frames? As far as i could tell they were the same, both videos were the same length.
Old 25th August 2020, 14:59   #8  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
Why don't you just use ripbot in distributed encoding mode?
Old 25th August 2020, 15:42   #9  |  Link
YaBoyShredderson
I have 1 computer.
Old 25th August 2020, 16:10   #10  |  Link
Atak_Snajpera
And so what? Is that hard to put 127.0.0.1 as IP?
Old 25th August 2020, 21:09   #11  |  Link
tebasuna51
tebasuna51's Avatar
Use MediaInfo (advanced mode) to know the 'Frame count'
Length? Maybe you want say 'Duration'
Still don't know how extract the audio.
If video source and video encoded have the same duration the audio must be in sync.
handbrake, mkvtoolnix, split, staxrip, stitchable
