Old 6th August 2020, 22:28   #1  |  Link
kutjong
kutjong's Avatar
Any way to IVTC or restore this (animation)?
Here's a sample: https://gofile.io/d/jPpcsd
I've tried field matching with TFM(), but there are some combing artifacts (or blending artifacts, I'm not sure of the difference). Is there any way to get a clean IVTC out of this material or some sort of restoration?
kutjong is offline   Reply With Quote
Old 7th August 2020, 09:00   #2  |  Link
manono
TFM is about all you can do. Or all that I can do. It's phase-shifted, but there's a whole lot of chroma out of place. Maybe someone else has dealt with this sort of thing before.
Old 7th August 2020, 09:31   #3  |  Link
magnetite
There's a parameter in TFM called slow. Default is 1, but 2 is slower and more effective.
magnetite is offline   Reply With Quote
Old 11th August 2020, 14:53   #4  |  Link
kutjong
kutjong's Avatar
No great luck playing around with TFM, chroma issues still persist. Maybe AnimeIVTC could be of help...?
I actually have the material also in NTSC, which does not have these issues, but unfortunately the transfer is otherwise of lesser quality, as seen here:
NTSC
PAL
Old 11th August 2020, 15:07   #5  |  Link
real.finder
you can take Luma from PAL after go to 24 and chroma from NTSC after go to 24 (not 23.976)
See My Avisynth Stuff
ivtc
