Old 29th July 2020, 21:33   #21  |  Link
manolito
manolito's Avatar
Thanks for the fix, works nicely now...
I will probably stick with dmMediaConverter for my audio conversion needs. It has fewer codecs, but also some nice features which can make my life easier. For example Peak Detection for helping users to adjust the gain. And it does video, too, no need to learn a different software for video and audio.
Old 29th July 2020, 21:43   #22  |  Link
jlw_4049
I understand, as I use StaxRip for a large portion of my needs.
However, I wanted to learn to code and so I just went with it.
Im constantly improving it so if you have features you're looking for to make it better feel free to let me know.
I really built the app for convenience when I'm muxing a movie and decide I want the audio changed.
I generally encode my video and manually mux later. Depends on the situation really.
However, I have a lot more plans for it, batching etc eventually. Still learning every day.
Sent from my SM-G986U1 using Tapatalk
jlw_4049 is offline   Reply With Quote
Old 3rd August 2020, 20:22   #23  |  Link
jlw_4049
Updating Release: v2.5
New Features:
* Added support for Windows 7 x64 to Windows 10 x64
* Added Batch Encoding
Update:
* Added every codec to the batch encoder that was supported in main program
* Added a bunch of optional extensions, if you use common it will support most if not all extensions most people use. You have all files as an option, but this could break the batch program if you have a file with an extension that is something that doesn't belong. (.jpg or anything else that isn't audio/video)
* Cleaned up the UI for the Batch Window
* Linked the drop down menu in main program where you can select "Debug" if you need to
* Added the ability to see all the command line options in batch form, in the batch window
* Added folder drag and drop (for the batch window). You can drag and drop a folder into the 'Open Directory' button or into the
Entry Box to the right of it
* I adjusted 'Save Directory' to default to the folder that was opened for encoding instead of root of the program
* On the main GUI I removed the 'MediaInfo' button, it is replaced by the "Batch Process" button. However, I added a tools option in the menu bar, that will still allow you to use this feature like it was before. (If you have an input file opened, it will still open the program with that file automatically, if you don't it'll open the program up to where you can do what ever you like)
Old 21st August 2020, 19:31   #24  |  Link
jlw_4049
Updating Release: v2.7
New Features:
* Added "Time Modification" - This is supported for both batch encoding as well as single file encoding
This was a requested feature
Old 17th September 2020, 17:01   #25  |  Link
jlw_4049
Updating Release: v2.8
Minor Update:
* Added FLAC input
Old 21st September 2020, 19:05   #26  |  Link
jlw_4049
Updating Release: v2.9
New Features:
* Added 'FLAC' encoder to the main gui program
* Added 'FLAC' to the batch encoder gui
Old 23rd September 2020, 04:05   #27  |  Link
jlw_4049
Updating Release: v2.9.1
New Features:
* Added 'ALAC' encoder to the main gui program
* Added 'ALAC' to the batch encoder gui
* Fixed some bugs that was on the batch side of the program
Old 25th September 2020, 21:24   #28  |  Link
Romaryu
A very useful application does not recognize the missing E-AC-3 codec input add please thanks
Romaryu is offline   Reply With Quote
Old 25th September 2020, 22:01   #29  |  Link
jlw_4049
Updating Release: v2.9.2
New Features:
* Added MPV Player to listen to selected tracks
You can control the volume with keys '9' and '0' (VolDown and VolUp) when viewing/listening to video/audio
* Added E-AC3 to the extension list for both main GUI and batch GUI
Thanks for the feedback and added eac3 extension in latest release.
Old 26th September 2020, 11:39   #30  |  Link
Romaryu
Old 7th October 2020, 05:59   #31  |  Link
jlw_4049
Updating Release: v2.9.3
New Features:
* Added a new custom youtube-dl GUI
This is based off of youtube-dl CLI, current functions are downloading audio/basic audio encoding/full quality video/audio download from links
* This program is a standalone program packaged with FFMPEG Audio Encoder
* You can open this either from inside the FFMPEG Audio Encoder folder or by using the Tools menu in the main GUI
Update:
* Updated qaac to latest version
Old 7th October 2020, 21:18   #32  |  Link
jlw_4049
Updating Release: v2.9.4
Major Changes to the code:
* Broke up the code between Main Gui, Batch Gui, and YoutubeDL Gui (This will make managing all of them a lot easier)
* Changed how the File -> Exit button functions, this was required for each individual window with the new code
* QAAC encoder had some major bugs on any setting that was not 'True VBR.' This has been fixed for both the batch encoder and the single file encoder
* YoutubeDL Gui is now built into the main GUI, instead of being a separate executable/script. (I will still update/release standalone versions of this) You can access this via the 'Tools' menu at the top of the GUI
Old 19th October 2020, 00:56   #33  |  Link
jlw_4049
Updating Release: v2.9.6
* Added '.aax' extension to the program
* Removed 'NEW_' from the batch side of the program, since the program automatically puts new files into a new directory. This makes it easier for the user not to have to go batch edit a bunch of new files in case they didn't want 'NEW_' included in the filename
* Added a license to the program (GPL-3.0 License)
* Updated 'ffmpeg.exe' to the latest version
* Program will now 'Auto Download' required apps, instead of them being in the repository
* The 'Auto Downloader' will check to see if the file exists, if it doesn't it'll download it for you
* Program will no longer ship with FFMPEG automatically, this makes the program lighter and will check your system 'PATH' for existing installations before downloading one on it's own
* Changed the way closing the program behaves. It will now prompt you to be sure you want to close it
Old 20th October 2020, 20:51   #34  |  Link
jlw_4049
Updating Release: v2.9.7
Updates:
* Program now checks for for existing folders in the 'Apps' directory, if they aren't there, it creates them.
* Added static links for the downloadable app, I got as many of these links to pull directly from the source for the latest versions
* Added a progress bar to the 'App Download' window
* Updated 'Youtube-DL-Gui' to the latest beta (v1.4) Check Youtube-DL-Gui github for changes (https://github.com/jlw4049/Youtube-DL-GUI)
* Program now checks for both ffmpeg.exe and youtube-dl.exe on your system path, before attempting to download them directly to the program
* Some minor bug fixes
audio, encoder gui, ffmpeg, ffmpeg audio
