Old 11th May 2020, 21:29   #1  |  Link
scenarist
Back to specific button in scenarist
Hi, I'm using Scenarist SD. I have one main menu which consists of 3 buttons to 3 submenus. Is it possible to go back from first submenu (by clicking "Back") to the first button in menu (to highlight it), from second submenu to second button in menu and from third submenu to third button in menu? If it's possible, how to do it?
scenarist is offline   Reply With Quote
Old 12th May 2020, 00:14   #2  |  Link
mp3dom
Essentially, the main menu need to have no forced selected button, then there are at least 3 different ways to return to the main with a different selected button. The easiest and less elegant way is to jump to a dummy pgc that in its precommand have an highlight button and jump to the main.
Old 12th May 2020, 10:51   #3  |  Link
scenarist
Thank you. I get it. What are the other 2 ways? Could you give me some advices?
Old 12th May 2020, 12:59   #4  |  Link
mp3dom
The other two ways is to store the highlight button value in a GPRMs and use it for highlight the buttons, while the other method is to use the postcommand of the actual submenu.
back, button, scenarist sd
