Old 3rd May 2020, 18:14   #1  |  Link
scenarist
Setting GPRM to return playback to submenu
I'm using Scenarist SD. In User Guide you can read:
"You could set a GPRM that returns playback to a submenu, instead of the root menu, when the viewer presses the Menu button on the remote control. You would do this if you wanted the viewer, who likely would want repeated access to the submenu, not to have to access it always through the root menu."
But there's no more information about how to do it. Could you help me and give some tips how to do it?
Thanks in advance
scenarist is offline   Reply With Quote
gprm, menu, playback, scenarist sd, submenu
