Old 22nd April 2020, 11:25   #1  |  Link
scenarist
Scenarist's DVD on VLC Media Player
I've made DVD using Scenarist SD. It plays well on every player I have except VLC Media Player. It looks like it has some problems with reading subpictures with buttons highlights because when I'm switching between the buttons, the highlight color doesn't change. Where's the problem? Am I doing something wrong or is it the program's dysfunction?
Thanks in advance for your help.
scenarist is offline   Reply With Quote
Old 22nd April 2020, 12:10   #2  |  Link
scenarist
What is more, everything works, function works. The only problem is that it doesn't display buttons highlights properly.
Old 22nd April 2020, 22:05   #3  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
1) Some software player's subpicture highlight implementation may be faulty for some builds, then be improved.
You may countercheck against MPC-HC and MPC-BE (less strict), PowerDVD, TMT (these should be more strict).
2) To react more snappy some software players may be rendering "Button Activated" subpicture colour not long enough to be recognised before executing command.
Maybe 0,25s should be a good "Button Activated" minimum showtime, but this would delay navigation execution by the same amount.
"Data reduction ? Yep, Sir. We're working on that issue. Synce invntoin uf lingöage..."
Old 23rd April 2020, 14:19   #4  |  Link
scenarist
Thanks for your help. I will check it. Do you use Scenarist SD and know how to change the "Button Acitivated" showtime?
Old 24th April 2020, 15:26   #5  |  Link
neil wilkes
neil wilkes's Avatar
Yes, I do - and you cannot change this. The speed this colour disappears is absolutely 100% down to the speed of the player, with set top boxes being the slowest & software being the fastest.
Most authors don't worry about it as it is outside of their control.
www.opusproductions.com
Multichannel Audio Productions
DVD-Audio/Video Authoring specialists
neil wilkes is offline   Reply With Quote
Old 26th April 2020, 15:14   #6  |  Link
Emulgator
Emulgator's Avatar
Yes, what Neil said.
"Button Activated" showtime is not a property of DVD authoring implementation,
I rather was hoping to suggest that this parameter be implemented properly within player logic, here applied to a software player.
dvd, scenarist, vlc media player
