Old 20th January 2019, 15:39   #21  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Originally Posted by Asmodian View Post
x265, with its 2x larger block sizes, actually hits that limit earlier. For 1080p I run two encodes at once on my i9 7900X.
Yes, there's a clear difference between CTU 64 and 32 what comes to parallel processing in the encoder. Of course, if you do extensive processing in Avisynth or better yet, Vapoursynth before feeding data into the encoder, the general utilization level should be higher by default.
Old 20th January 2019, 15:51   #22  |  Link
asarian
^^ Thx, guys. Good to know.
Gorgeous, delicious, deculture!
asarian is offline   Reply With Quote
Old 20th January 2019, 15:56   #23  |  Link
asarian
Why?! When I do heavy denoising stuffz, vspipe takes ca. 11-22% of the CPU. So, from that point of view, I can see why you would try and run multiple of those. The rest of the CPU is then usurped by the x264/x265 process.
So, what I don't understand then is how running two x265 processes concurrently lowers the amount of threads each uses. Or is that something you can actually set?
Old 20th January 2019, 16:45   #24  |  Link
mparade
Originally Posted by asarian View Post
On that matter -- if allowed here -- back in the day, for x264, it was said too many cores (= threads) would deteriorate the quality. Wasn't particularly relevant at the time, but nowadays (I'm thinking of getting an i9 9980XE myself, with 18 cores) the question may actually become pertinent again.
So, is this still an issue for x265? And, if so, at how many cores should we start to worry?
I am not using x265 for 1080p content just because x264 is able to provide the quality I want in the size interval I am aiming at keeping menus as well and very fast using my processor even with preset slower, however, I have to divide the content into chunks for a better processor utilization to reach.
For HD and SD res. I maximalize threads and lookahead threads to 12&4 and 6&2 correspondingly.
mparade is offline   Reply With Quote
Old 20th January 2019, 16:55   #25  |  Link
asarian
Okay, thx. I'll look into that.
Old 20th January 2019, 18:57   #26  |  Link
Stereodude
Wait, you mean the devs of x265 didn't make its threading resolution aware as to not have it degrade image quality by spawning excess threads (by default)? I know x264 has that problem, but I thought I read that x265 was smarter about threading...
Stereodude is offline   Reply With Quote
Old 21st January 2019, 03:10   #27  |  Link
Asmodian
It is something you can set with --pools and/or --frame-threads.
It is smarter, in that WPP helps, but it still allocates a thread for each logical core. By default it will also start using more frame threads, which hurt quality, as core count goes up.
"The number of frame threads used is auto-detected from the (hyperthreaded) CPU core count"
Cores: Frames
> 32: 6..8
>=16: 5
>= 8: 3
>= 4: 2
Source
madVR options explained
Old 21st January 2019, 13:07   #28  |  Link
Stereodude
Cores: Frames
> 32: 6..8
>=16: 5
>= 8: 3
>= 4: 2
Source
I've read that before. Maybe I'm misunderstanding it, but what I get out of that is that x265 will spawn a lot of threads on a high core count system, but they won't degrade image quality because they may largely sit idle waiting. They can impact determinism. Also, don't bother manually increasing the threading.
There certainly is no warning (or even a vague suggestion for that matter) to limit threading manually based on the input resolution for the sake of quality. In fact there's pretty much a statement to the opposite.
When frame threading is disabled, the entirety of all reference frames are always fully available (by definition) and thus the available pixel area is not restricted at all, and this can sometimes improve compression efficiency. Because of this, the output of encodes with frame parallelism disabled will not match the output of encodes with frame parallelism enabled; but when enabled the number of frame threads should have no effect on the output bitstream except when using ABR or VBV rate control or noise reduction.
Old 21st January 2019, 19:21   #29  |  Link
Asmodian
What I understand from this is that restricting the number of threads in a pool is pointless when running one encode but setting --frame-threads 1 can improve compression efficiency. I believe "no effect on the output bitstream" means all the frames are the same types and it can be decoded the same way, not that there is no loss of compression efficiency.
Old 21st January 2019, 20:49   #30  |  Link
Stereodude
I took "no effect on the output bitstream" to mean no loss in visual quality because the encode is still deterministic (unless you use things that inherently break determinism).
Old 21st January 2019, 22:36   #31  |  Link
Asmodian
The first sentence in your quote doesn't make any sense then.
It cannot both sometimes improve quality when disabled and not impact quality when enabled. I think the second sentence is contrasting frame level parallelism against slices as a way to allow parallelism, slices change the bitstream.
Old 22nd January 2019, 03:39   #32  |  Link
Stereodude
Well, I didn't write it. It's ambiguous on both ends.
Old 22nd January 2019, 15:55   #33  |  Link
asarian
Why not?! Leaving a feature disabled can sometimes improve quality; and sometimes having the feature enabled will not impact quality.
Old 22nd January 2019, 22:24   #34  |  Link
Asmodian
For one, the second sentence does not say sometimes.
It also does not make sense technically. If you do not wait for all previous frames to be encoded sometimes you cannot chose what would have been the best reference block because it isn't available yet.
Also, what would the bold mean if "no effect on the output bitstream" means "no effect on quality"?
Edit: Maybe it is saying that once --frame-threads = 2 more frame threads should have no effect? I find this hard to believe, because more incomplete frames seems like it has to mean fewer reference blocks available, but it might be what is meant and I don't know how the details of reference block selection interacts with frame parallelism.
Old 22nd January 2019, 22:34   #35  |  Link
benwaggoner
I read it as saying that frame-threads on/off can make a difference, but if frame threading is being used, the number of threads being used doesn't impact output quality.
This is not true with different number of frame-threads (with quality going down as the number goes up, although not nearly the impact it was in prior years). It might be true when frame-threads is constant but the number of threads in general varies.
Ben Waggoner
My Compression Book
Old 22nd January 2019, 22:51   #36  |  Link
Asmodian
But it explicitly says "the number of frame threads should have no effect on the output bitstream" which really doesn't seem like it could be true if it means size v.s. quality.
Oh wait, it means the number of threads working on each frame, not the number of frames being worked on at once?
Old 23rd January 2019, 01:03   #37  |  Link
benwaggoner
That is the only thing I thought it could mean that would make sense. The number of threads per frame go up with frame size. You can get quite a lot of cores going at once at UHD resolutions with high quality settings.
Ben Waggoner
My Compression Book
Old 6th March 2019, 16:54   #38  |  Link
jlw_4049
Wow, last I checked no one had responded to this. I appreciate all the information here!! Thanks!
jlw_4049 is offline   Reply With Quote
Old 7th March 2019, 23:35   #39  |  Link
blublub
lol.
Here is what I use:
1080P for high quality:
CRF: 17 to 19 - depending on the movie type / image noise
no-sao
frame-threads=3 to 4
ctu=32
merange=27
me=3
subme=4
rd=4
deblock=-1;-1
no-strong-intra-smoothing
bframes=4
ref=4
psy-rd=3.0
aq-mode=2 / aq=3 for dark movies
level-idc=51
high-tier
qcomp=0.63
vbv-maxrate=75000
vbv-bufsize=75000
4K HDR:
CRF 17 to 19 - same as above
--profile main10
--output-depth 10
--no-sao --frame-threads=3
--pme
--hdr-opt
--colorprim bt2020
--ctu=32
--qcomp=0.7
--no-strong-intra-smoothing
--aq-mode=2
--deblock=-1:-1
--level-idc=51
--high-tier
--qg-size=16
blublub is offline   Reply With Quote
Old 26th April 2019, 07:31   #40  |  Link
Nico8583
I tried some settings and some encodes but I can see every time x265 lose a lot of details, even with a high bitrate (2 pass 35 MBits, CRF16...)
Do you have some tricks to encode ?
Thank you !
Nico8583 is offline   Reply With Quote
handbrake, hevc, x265
