Old 18th October 2018, 16:06   #1  |  Link
activoice
MKVMerge Batch by language
This must have been asked before but I cannot find a thread for it.
When I encounter an mkv file that has more than just English Audio and Subtitles I use the MKVbatch -i command to list out the video, audio and subtitle tracks then I use the command shown below to create a new set of files using MKVMerge to merge the Audio and Subtitle track number that I need.
IE if a video file has Track 1 as English Audio, and Track 4 is English Subtitles I use this command to take the files from the source folder c:\temp and output to c:\temp2
FOR %%f IN (c:\temp\*.mkv) DO (
C:\PROGRA~1\MKVToolNix\mkvmerge -o c:\temp2\%%~nf-new.mkv --atracks 1 --stracks 4 %%~nf.mkv
Instead is there a way to do this where I would specify in the command that I want the English Audio and Subtitle tracks, and MKVMerge will look at the language itself, instead of me having to look up the track numbers beforehand?
activoice is offline   Reply With Quote
Old 18th October 2018, 21:08   #2  |  Link
sneaker_ger
Yes.
FOR %%f IN (c:\temp\*.mkv) DO "C:\PROGRA~1\MKVToolNix\mkvmerge" -o "c:\temp2\%%~nf-new.mkv" --audio-tracks eng --subtitle-tracks eng "%%~nf.mkv"
https://mkvtoolnix.download/doc/mkvmerge.html#d4e1822
Old 19th October 2018, 04:42   #3  |  Link
activoice
Wow thanks so much
audio, batch, mkvmerge, subtitles
