Old 10th December 2017, 02:55   #1  |  Link
djarko
Deinterlaced Film or IVTC 29.97p to 23.976p?
I have a few video files that were clearly filmed at 23.976p but later telecined (apologies if I'm using the wrong term) to 29.97p using a 4th frame dupe, meaning the 5th frame is a repeat of the 4th. Not sure if it's technically a 1:1:1:2 or 2:2:2:4 cadence, technically speaking, but I think you folks understand the idea.
I'm using the file name appending feature to quickly display it at the right cadence. Currently, I'm using the "Filename deint=IVTC frameRate=23p.mp4" format (frameRate for those devices on my network that support refresh rate matching, ignored otherwise). However, I noticed that deint=Film also produces all the frames without any repeated frames which deint=Video, On, Off clearly do not.
To my eye, I can't tell the difference between deint=IVTC and deint=film in producing all the frames without any repeated frames and with no apparent interlacing. Which should it be?
Again:
-29.97p to 23.976p with 4th frame duped (not originally interlaced 29.97i)
-Format "Filename deint=IVTC frameRate=23p.mp4"
-Using DXVA2 Copy Back H/W decoding
-deint=IVTC or deint=Film?
djarko is offline   Reply With Quote
Old 10th December 2017, 04:46   #2  |  Link
Asmodian
deint=IVTC and deint=Film are synonymous, they both activate the same code.
madVR options explained
Asmodian is online now   Reply With Quote
Old 12th December 2017, 12:44   #3  |  Link
madshi
Asmodian is correct, of course. Also, if you want to know the cadence, it should be listed in the OSD (Ctrl+J).
23.976, film, interlace, interlaced, ivtc
