Old 11th July 2020, 19:16   #601  |  Link
hubblec4
Matroska find' ich toll
chapterEditor(cE) rev1.24 is available.
Windows
Linux
A few bugs have been fixed and a new feature for Disc2mkv is available.
Change chapterEditor
added    &
fixed    *
improved #
changed  %
rev1.24 2020-07-11
// chapterEditor
* double quotes have not been removed from file names, only Windows
// Chapter naming
# Chapter names in the combo box now begin with capital letters
// Disc2mkv
& Automatically delete temp folder (settings)
  - MKV file must not be created in the temp folder
  - if there were errors when muxing, the temp folder is not deleted
  - Gray state of the checkbox: the temp folder is only deleted if there was no warning
* Illegal characters in file names have not been removed
// DVD2mkv
* mkv file could not be created if no audio track was selected
* mtxcfg file
   - was not always created in the temp folder
   - MKV paths were not correct for menu titles
chapterEditor || Matroska-Playback || hSplit || DiscShare
hubblec4 is offline   Reply With Quote
Old 19th July 2020, 09:40   #602  |  Link
tormento
Acid fr0g
tormento's Avatar
Is there the capability to add custom Chapter translation?
I would like to add 章 (japanese for chapter).
@turment on Telegram
Old 20th July 2020, 04:08   #603  |  Link
hubblec4
Hi tormento
Yes you can set your own chapter names via Text Favorites (the button with the yellow star).
Old 21st July 2020, 08:39   #604  |  Link
tormento
Acid fr0g
tormento's Avatar
Hi tormento
Thanks!
Old 3rd August 2020, 04:46   #605  |  Link
darksen
Hey hubblec4 I found a problem with a Blu-ray, actually I found this problem before with a couple of other BDs but I can't remember exactly which ones.
When I try to remux one playlist that contains two m2ts files of which one is pure video (some seconds I think) and the other is the full movie I get this error:
mkvmerge v49.0.0 ('Sick Of Losing Soulmates') 64-bit
'V:\BDMV\STREAM\00043.m2ts': Using the demultiplexer for the format 'MPEG transport stream'.
'V:\BDMV\STREAM\00002.m2ts': Using the demultiplexer for the format 'MPEG transport stream'.
'V:\BDMV\STREAM\00043.m2ts' track 0: Using the output module for the format 'AVC/H.264 (unframed)'.
'V:\BDMV\STREAM\00043.m2ts' track 2: Using the output module for the format 'AC-3'.
'V:\BDMV\STREAM\00043.m2ts' track 3: Using the output module for the format 'DTS'.
'V:\BDMV\STREAM\00043.m2ts' track 4: Using the output module for the format 'HDMV PGS'.
'V:\BDMV\STREAM\00043.m2ts' track 6: Using the output module for the format 'HDMV PGS'.
'V:\BDMV\STREAM\00002.m2ts' track 0: Using the output module for the format 'AVC/H.264 (unframed)'.
Warning: 'V:\BDMV\STREAM\00002.m2ts': A track with the ID 3 was requested but not found in the file. The corresponding option will be ignored.
Warning: 'V:\BDMV\STREAM\00002.m2ts': A track with the ID 2 was requested but not found in the file. The corresponding option will be ignored.
Warning: 'V:\BDMV\STREAM\00002.m2ts': A track with the ID 4 was requested but not found in the file. The corresponding option will be ignored.
Warning: 'V:\BDMV\STREAM\00002.m2ts': A track with the ID 6 was requested but not found in the file. The corresponding option will be ignored.
Error: The file no. 1 ('V:\BDMV\STREAM\00002.m2ts') does not contain a track with the ID 2, or that track is not to be copied. The argument for '--append-to' was invalid.
And cE doesn't output any file. I tried loading the playlist into MKVToolNix directly to see what happens (I was thinking on requesting this to bunkus as I thought it was mkvmerge's problem) and it successfully remuxed the file, this is the log:
--- Output of job 'Multiplexing to file "00100.mkv" in directory "J:\Vids\mickeys"' started on 2020-08-02 22:32:54 -05:00 ---
Scanning 2 files in 1 playlist.
Done scanning playlists.
'V:\BDMV\STREAM\00003.m2ts': Using the demultiplexer for the format 'MPEG transport stream'.
'V:\BDMV\STREAM\00003.m2ts' track 0: Using the output module for the format 'AVC/H.264 (unframed)'.
'V:\BDMV\STREAM\00003.m2ts' track 1: Using the output module for the format 'AC-3'.
'V:\BDMV\STREAM\00003.m2ts' track 2: Using the output module for the format 'AC-3'.
'V:\BDMV\STREAM\00003.m2ts' track 3: Using the output module for the format 'DTS'.
'V:\BDMV\STREAM\00003.m2ts' track 4: Using the output module for the format 'HDMV PGS'.
'V:\BDMV\STREAM\00003.m2ts' track 5: Using the output module for the format 'HDMV PGS'.
'V:\BDMV\STREAM\00003.m2ts' track 6: Using the output module for the format 'HDMV PGS'.
The file 'J:\Vids\mickeys\00100.mkv' has been opened for writing.
'V:\BDMV\STREAM\00003.m2ts' track 0: Extracted the aspect ratio information from the MPEG-4 layer 10 (AVC) video data and set the display dimensions to 1920/1080.
Appending track 0 from file no. 1 ('V:\BDMV\STREAM\00002.m2ts') to track 0 from file no. 0 ('V:\BDMV\STREAM\00003.m2ts').
'V:\BDMV\STREAM\00002.m2ts' track 0: Extracted the aspect ratio information from the MPEG-4 layer 10 (AVC) video data and set the display dimensions to 1920/1080.
The cue entries (the index) are being written...
Multiplexing took 5 minutes 0 seconds.
Can you please look into this?
Thanks!
darksen is offline   Reply With Quote
Old 3rd August 2020, 12:31   #606  |  Link
hubblec4
Hi darksen
Yes such playlists are "bad", because in the first (and/or last) m2ts is a video stream only.
You can ignore such m2ts files. When you load such a playlist in BD2mkv you have the option to ignore the m2ts files.
cE can ignore such m2ts files automatically: in the settings yon can set a duration for such files.
Mostly is the duration less then a second. The default duration is 2 seconds.
I'm not sure if mkvmerge can handle such playlist correctly.
It would be nice if you can share with me a chunk of this disc. You can use my DiscShare tool.
Old 6th August 2020, 19:04   #607  |  Link
darksen
Hi darksen
MKVToolNix did remuxed the playlist fine, and supposedly -because I haven't precisely compared the times of all the files to see if the ms that the second m2ts file lasts had been added to the final file- it appended the second m2ts file (as per the log).
Here I used the -F param on DiscShare and 7-ziped the files: https://www.dropbox.com/s/iy3d4d6ayv...mickey.7z?dl=0
With the option to ignore the last m2ts I'm able remux it (I don't know how I overlooked that option).
Thanks!
Old 7th August 2020, 14:12   #608  |  Link
hubblec4
Hi darksen
Thanks for the disc chunk. Like you said, with the ignore option of the last m2ts it works.
Old 25th September 2020, 12:49   #609  |  Link
hubblec4
I got an email from my chapter database provider:
Belegung: 972,7 MB (194,5%)
Limit: 500 MB
** Deine MySQL-Zugänge werden ab dem 15.10.2020, 0:00 keine Schreibrechte (INSERT, UPDATE) mehr haben, sofern der Speicherplatz zu diesem Zeitpunkt noch immer überschritten wird. **
That means the database will work until 15.10.2020.
I work on a fix so fast as I can.
I have 3 options
option 1: buy a web hosting package with monthly payment
option 2: compress the data
option 3: find a free hoster with more sql space
monthly payment is not the way I want to go
Old 28th September 2020, 23:13   #610  |  Link
hubblec4
Here is a Windows and Linux test version (cE.exe only).
I have compressed the chapters and tags files. This should reduce the database more than 80% and decrease the download time vastly.
Please let me know if everything works as expected.
Old 4th October 2020, 22:24   #611  |  Link
hubblec4
chapterEditor(cE) rev1.25 is available.
Windows
Linux
After a little while there is another update.
The database became too big and therefore had to be compressed.
On 10.10.2020 I will delete the uncompressed files,
this means that older cE versions no longer have access to the database.
added    &
fixed    *
improved #
changed  %
rev 1.25 2020-10-04
// chapterEditor
& MKVToolNix (MTX): --disable-language-ietf (settings: external programs)
   - MTX will no longer automatically generate IETF language elements
// Chapter database
# Chapters and Tags files compressed
   - Older cE versions can no longer access the database
# When changing film information, the title name check is no longer carried out because it is unnecessary
Old 7th October 2020, 02:43   #612  |  Link
Masutin
chapterEditorCLI is no longer there. Can you pack it with the next version of CE?
Masutin is offline   Reply With Quote
Old 7th October 2020, 12:43   #613  |  Link
hubblec4
Here are two download links which works.
Videohelp
Gleitz-forum
bluray backup, chapter editor, dvd2mkv, matroska menu, metadata, multi-edition-mkv, xml tag
