Old 19th August 2011, 20:32   #1  |  Link
xosuitehearts
any way to keep Handbrake from resizing picture?
Is there any way to keep Handbrake from resizing the video Im converting's picture?
xosuitehearts is offline   Reply With Quote
Old 19th August 2011, 23:18   #2  |  Link
nurbs
Using the "strict anamorphic" setting in handbrake should do that, unless your source resolution is higher than what your encoding profile supports.
Old 20th August 2011, 02:02   #3  |  Link
xosuitehearts
I'm batch encoding some mkv files from anime series' that I want to retain the picture size so if I need to add subs.
Are you sure strict anamorphic will do that?
I set it to None before
will that do? or no?
Old 20th August 2011, 08:41   #4  |  Link
nurbs
I'm not sure because I haven't used Handbrake in years, but that's what the manual says.
Old 20th August 2011, 19:25   #5  |  Link
JohnAStebbins
Since we know very little about your source, it's hard to give advice. An activity log of a scan of your source would tell all.
If your source has black borders, then HandBrake will crop those unless you tell it not to. So you may need to also set crop to 0.
JohnAStebbins is offline   Reply With Quote
handbrake, picture, resizing
