Old 23rd April 2011, 23:31   #1  |  Link
Ice Monkey
DVB-T2 / H264 Playback Problem
I recently got a Panasonic Freeview HD recorder and I can get HD files from it onto my computer using AnyDVD.
Thing is, the recorder produces a DR file that is just a copy of the transmission stream. When copied across, the only player that will play it is VLC and in that player, the audio keeps on fading in and out. VLC reports the following codec info:
Video: H264 AVC (Part 10)
Audio: MPEG AAC (mp4a) 3F2R/LFE, 48kHz
Windows Media Player and Media Player Classic both play the video, but no audio. GOM just dies.
Ideally, I would like to sort the audio problem as these files are awesome. Just recorded Dr Who (for the kids ofc) and the file is about 40% smaller than converting it to another HD format the recorders supports for output, yet the file has normal audio, an audio description track and subtitles!
If I convert the track, the 2.3Gb file goes up to 3.8Gb but I lose the second audio track and the subtitles. It will however play in GOM, WMPC and in VLC, the audio stops fading in and out. The converted file has the same video, but the audio reports as:
A52 (aka AC3)
I have fiddled around with FFDShow, but the audio problem is always there in VLC and nothing else will play the audio in the original file.
Suggestions would be very welcome!
Cheers,
Dave
Ice Monkey is offline   Reply With Quote
Old 24th April 2011, 00:22   #2  |  Link
kieranrk
Post a sample.
kieranrk is offline   Reply With Quote
Old 24th April 2011, 02:02   #3  |  Link
setarip_old
setarip_old's Avatar
@Ice Monkey
Hi!
What is the model number of your Panasonic Freeview HD recorder?
setarip_old is offline   Reply With Quote
Old 24th April 2011, 19:11   #4  |  Link
Ice Monkey
Hi Guys, thanks for the replies.
@kieranrk: I am having difficulty getting a clip under 10MB, is it okay to post files that big to this board?
@setarip_old: It's a DMR-EX77
Old 24th April 2011, 19:23   #5  |  Link
kieranrk
Post it on a site like mediafire.
Old 25th April 2011, 19:17   #6  |  Link
Ice Monkey
Hi kieranrk,
Thanks for the suggestion, I have uploaded a clip from BBC1 HD recorded this afternoon.
The link to the file is:
http://www.mediafire.com/?93223kyo7vy23wm
Thanks in advance for any suggestions on how to sort the sound problem!
Cheers,
Dave
Old 25th April 2011, 20:52   #7  |  Link
kieranrk
I can reproduce the issue in VLC. The file does play in mpc-hc when lavfsplitter and lavcaudio are used.
Old 27th April 2011, 19:28   #8  |  Link
Ice Monkey
Thank you so much kieranrk, I will give lavfsplitter and lavcaudio a go!
Much appreciated,
Dave
audio, dvb-t2, h264, vlc
