Old 11th January 2011, 06:14   #1  |  Link
GG-Xtreme
Converting a .m2ts containing VFR AVC into mp4/mkv
I feel like an idiot when it comes to this stuff. After sorting out my other issues, I came across an odd video file: a 4GB, 1080p .m2ts that contained a variable-framerate H.264 stream and an AC3 track. The video plays fine in VLC (although seeking and time are completely broken, video appears as 00:00:00 in length and dragging the seek bar has no effect), and even plays fine in Windows Media Player (seeks fine and shows correct length).
I can't figure out how to turn this into a CFR mp4 or mkv. Every .m2ts converter I've tried seems to be looking for a large Bluray-format video stream and fails to load the file. Demuxing the .m2ts only gives me a raw .h264 file without timecodes or anything--useless, as I can only specify constant framerates when muxing.
I tried loading the .m2ts directly into MeGUI to convert to constant-framerate, and it loads fine...using DirectShowSource, which has been so-far useless to me, since the encoded files do not seek or play properly on Android phones or in MPC. Attempting to use FFmpegSource with the file just crashes MeGUI. Is there any other method of turning this .m2ts file into any constant-framerate format?
GG-Xtreme is offline   Reply With Quote
Old 11th January 2011, 17:04   #2  |  Link
roozhou
Why do you need to convert VFR to CFR?
roozhou is offline   Reply With Quote
Old 11th January 2011, 22:07   #3  |  Link
GG-Xtreme
Because my Android phone can't play VFR with hardware acceleration without going way out of sync (seems to be a limitation in the hardware or firmware). Not to mention that it can't play .m2ts files anyway.
Old 11th January 2011, 23:49   #4  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Where exactly did you get that kind of file?
Old 12th January 2011, 00:15   #5  |  Link
Selur
Selur's Avatar
A sample would be nice. I have never seen such a stream would probably like some other users have a look at it.
btw. did you try to feed it directly to x264 with '--force-cfr' activated?
Notice: Since email notifications do not work here any more, it might take me quite some time to notice a reply to a thread,..
Old 12th January 2011, 00:34   #6  |  Link
sneaker_ger
If the source really is VFR this would destroy the sync (assuming all this option does is to make x264cli generate the timecodes itself?). But I have to admit that I have never come across a VFR m2ts myself.
What I find strange is that he says that using DirectShowSource will make the output not seek or play properly while the source filter used in an AviSynth script shouldn't have any impact on things like these at all.
Old 13th January 2011, 20:02   #7  |  Link
GG-Xtreme
I had a friend at my dorm rip some of my Blurays for me and put them on my external hard drive, since I don't have a PC Bluray drive for ripping stuff myself. I should ask him what the hell he did.
How would I get a sample of this file? (I'm have no idea how to convert it, much less trim it) I didn't try the --force-cfr option, I'll look into it.
I think this is weird myself. However, testing on 2 different PC's for encoding and 2 different phones for playback, the same exact source video had serious playback and seek issues if encoded with DirectShowSource, but had no problems if encoded with the same settings (H.264, resolution, quality, framerate, etc.) using FFVideoSource instead. The problem remained for any source videos I tried (and I tried a good 20 or so videos before I realized that using FFVideoSource resolved the problems).
convert, demux, h264, m2ts, vfr
