Old 13th February 2018, 00:32   #41  |  Link
sneaker_ger
A few versions ago mkvextract was changed:
1. Now it's "mkvextract timestamps_v2 file.mkv 0:output.txt
2. output.txt:
# timestamp format v2
0
42
83
(mkvmerge should accept old and new format)
Need additional changes?
Old 13th February 2018, 00:33   #42  |  Link
FortMax
Getting some different errors now.
[path]>vfr.py -i "VTS_01_1b T80 2_0ch 384Kbps DELAY 0ms.aac.m4a" -o Exceedraft_05.mka -f 24000/1001 Exceedraft_05.avs
Traceback (most recent call last):
  File "C:\Program Files (x86)\cmdpgms\vfr.py", line 730, in <module>
    main(argv[1:])
  File "C:\Program Files (x86)\cmdpgms\vfr.py", line 166, in main
    o.verbose, o.test)
  File "C:\Program Files (x86)\cmdpgms\vfr.py", line 706, in split_audio
    if delay or ret else None)
NameError: global name 'tid' is not defined
FortMax is offline   Reply With Quote
Old 13th February 2018, 00:34   #43  |  Link
RiCON
RiCON's Avatar
Probably not? vfr.py doesn't use mkvextract.
@FortMax: fixed
RiCON is offline   Reply With Quote
Old 13th February 2018, 01:07   #44  |  Link
sneaker_ger
But it uses the timecode files it outputs, right?
Old 13th February 2018, 01:16   #45  |  Link
FortMax
@RiCON:
That seems to have fixed my issue. Only difference from earlier performance is that it only outputs one file, rather than splitting it into multiple chunks.
Old 13th February 2018, 01:26   #46  |  Link
RiCON
RiCON's Avatar
It's been this way since at least mkvmerge 5.6.0 and --merge? Long as it's still the proper output should be fine.
Old 13th February 2018, 02:06   #47  |  Link
FortMax
Wouldn't that need the -m flag, or am I completely reading this wrong?
Old 13th February 2018, 02:29   #48  |  Link
RiCON
RiCON's Avatar
-m or --merge, yes.
Old 13th February 2018, 02:39   #49  |  Link
FortMax
My command line isn't using either of those, though. On some stuff, I found it useful when vfr.py output the stuff before x and after y for trim(x,y).
Old 13th February 2018, 11:35   #50  |  Link
RiCON
RiCON's Avatar
--merge rejoins the split audio that matters.
--remove removes the split audio segments after merging.
The audio in-between hasn't been there since mkvmerge 5.6.0 because of the type of --split used.
Old 14th February 2018, 03:59   #51  |  Link
FortMax
Thanks for that. That pointed me in the right direction on what I needed to change to bring back the old --split behavior, as I had some use for the stuff that was trimmed off.
chapters, helper script, python, vfr
