Old 2nd April 2010, 12:19   #1  |  Link
Dyomich
Codec Analysis Expert
MSU H.264 Codec Testing and DivX H.264
Dear doom9 community,
Moscow State University performs annual H.264 codec comparison as usual. And this year we have extended number of participants.
When we add codec in comparison we work with its developers to find optimal parameters and presets for encoding. Due to many user requests we have added DivX H.264 codec (DivX plus), but WE CAN NOT CONTACT ITS DEVELOPERS. We have written to support of DivX and other contacts, but do not have any answers.
We perform comparison and want to provide feedback about it to DivX, Inc.
Could you help us get contact with DivX H.264 developers?
Thank you!
P.S. You can find more information about our comparison here:
http://www.compression.ru/video/code...codecs_10.html
http://www.compression.ru/video/code...4_2009_en.html
http://www.compression.ru/video/code.../index_en.html
Best regards,
Dr. Dmitriy Kulikov,
Head of Video Codec Testing team,
Graphics&Media Lab,
Dyomich is offline   Reply With Quote
Old 2nd April 2010, 15:02   #2  |  Link
poisondeathray
I think "DigitAl56K" works for DivX , perhaps you could PM him or use instant messaging. Contact info is in his profile
http://forum.doom9.org/member.php?u=21264
Old 2nd April 2010, 17:01   #3  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Minimum 40 fps for "High Quality" preset
Old 2nd April 2010, 17:26   #4  |  Link
ChronoCross
Does it really matter?
ChronoCross's Avatar
Originally Posted by LoRd_MuldeR View Post
Does that really surprise you? Their test has pretty much always been a joke IMO.
ChronoCross is offline   Reply With Quote
Old 2nd April 2010, 18:02   #5  |  Link
Dyomich
For the test machine: this requirement is easily met by 2-pass x264 with preset "slow". So by our opinion it is quite normal requirement.
Old 2nd April 2010, 18:04   #6  |  Link
Dyomich
Could you explain or argue your statement? What do you think is incorrect in MSU video codec comparisons?
Old 2nd April 2010, 18:05   #7  |  Link
Dyomich
Thank you - I will try to contact him as long report draft will be ready.
Old 2nd April 2010, 18:36   #8  |  Link
ChronoCross
Measuring quality in relation to speed of the codec isn't a very good qualitative measure and is completely dependent on the the power of the machine your using, the optimization of the code, etc. because if x264 can use 16 reference frames and get 40fps but DivX can only use 2 reference frames and still get 40fps then the quality will be skewed in the direction of x264.
Speed can be used in a test to chart the exact tradeoff of quality/speed rather than comparing it for absolute quality which is what your test is supposedly meant to measure.
Old 2nd April 2010, 18:45   #9  |  Link
LoRd_MuldeR
Software Developer
If that's true (for both passes, not only for the fast first pass), then I'm surprised by the performance of those Core-i7's! And it's "only" the 920 you are using.
I get ~12-15 fps (less than the half speed) for 4CIF content with "slow" preset. That's on my Core2 Quad, which is running only very slightly slower (2,44 GHz -vs- 2,67 GHz)
Old 2nd April 2010, 18:56   #10  |  Link
IgorC
IgorC is offline   Reply With Quote
Old 2nd April 2010, 19:12   #11  |  Link
poisondeathray
IgorC - perhaps adding background information to that graph would help .e.g source dimensions , encoding settings etc... otherwise the graph alone is less useful
Old 2nd April 2010, 19:46   #12  |  Link
RunningSkittle
Skittle
RunningSkittle's Avatar
High Quality encodes should not be dependent on speed?! Of course its interesting to see the speed, but to make such a high requirement kills the performance of x264. for example: No veryslow preset.
Making a floor fps requirement might be good though, 1fps is not very useful in most applications! Perhaps make it something more reasonable like 5-10fps.
it would also be interesting to see the speed/vs quality on fastest settings.
RunningSkittle is offline   Reply With Quote
Old 2nd April 2010, 19:54   #13  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
Oh come on, it's not unreasonable to require a speed threshold for each comparison.
I do agree that they overcompensated this year; the previous year had ridiculously low speed thresholds, so this year they made them an order of magnitude higher.
Old 2nd April 2010, 20:21   #14  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
Indeed. I consider ~12fps (half realtime for 24p) to be quite usable for most scenarios.
High volume transcoding really does need high speeds though. 48 to 72fps is not unreasonable.
x264 can probably slaughter the competition at this threshold, but I'm always interested to see updated codec comparisons. I'll be doing my own comparison soon, between Rhozet Carbon Coder (Mainconcept) and x264 at 50mbps 1080p for mezzanine file purposes.
~MiSfit
Old 2nd April 2010, 20:28   #15  |  Link
IgorC
Or just add one preset more. Fast, Normal, High, Highest.
Old 3rd April 2010, 01:39   #16  |  Link
DigitAl56K
Hi Dmitriy,
By "DivX H.264 encoder" I assume you are referring to the beta released at DivX Labs last year. This was a sample application based on an older version of the SDK designed specifically to provide a DivX Plus HD-compliant reference in terms of bitstream constraints, HRD model and so forth. Although it serves as a fully functional and free encoder it is a feature constrained for-purpose application and doesn't represent the capabilities of the latest MainConcept encoder. Sorry if this hasn't been clearly communicated to you previously.
I had heard that you were in touch with our MainConcept team regarding their encoder. If I can help you further or if you need help contacting the MainConcept group you can write me directly at amayo (at) divxcorp [dotcom].
DigitAl56K is offline   Reply With Quote
Old 5th April 2010, 18:09   #17  |  Link
Dyomich
Originally Posted by DigitAl56K View Post
Hi Dmitriy,
Hello!
Thank you for answer!
Yes, we are using beta from DivX Labs.
About MainConcept - we have a contact with developers and testing newest MainConcept encoder.
And due to the fact that DivX H.264 encoder is present as separate encoder comparing to MainConcept we test it too.
Next year we plan to make a new use-case - only for encoders with РВК model. So we look forward to include your encoder (DivX Plus) in next comparison.
Also I have a question - what e-mail address can we use to contact DivX developers this time and next year? Yours?
Old 6th April 2010, 00:35   #18  |  Link
DigitAl56K
Dmitriy,
Send me an e-mail so that I have your address and we can talk further.
I hope so!
Old 7th April 2010, 18:34   #19  |  Link
bob0r
Pain and suffering
bob0r's Avatar
Dyomich, i have prepared this graph for you:
bob0r is offline   Reply With Quote
Old 9th April 2010, 15:01   #20  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
The flat parts are amazing, feeling calm.
"Data reduction ? Yep, Sir. We're working on that issue. Synce invntoin uf lingöage..."
codec testing, divx, h.264, msu
