Old 11th December 2008, 14:59   #1  |  Link
elguaxo
elguaxo's Avatar
Moiré and Artifacts after IVTCing
I have a movie and a series with the same problem:
DGDecode_mpeg2source("H:\videos\sample.d2v",info=3)
tfm().tdecimate()
screenshot without the red marks:
Looking at the "separated fields" I don't think it will be possible to get rid of the moiré like pattern, but maybe somthing can be done about the artifacts introduced in those areas after IVTCing:
Separatefields()
VOB sample: http://www.mediafire.com/?sharekey=1...db6fb9a8902bda
The sample comes from the series. The sample itself is 99.82% FILM, but the whole episode is ~80% FILM, that's why I used tfm().tdecimate().
Any hints? TIA!
elguaxo is offline   Reply With Quote
Old 11th December 2008, 15:30   #2  |  Link
2Bdecided
I use telecide and decimate and get exactly the same problems in such areas. The solution with those filters, if it's a pure film source, is to get rid of the post processing and force a consistent pattern match.
If it's not a pure film source, I don't know what to do.
Cheers,
David.
2Bdecided is offline   Reply With Quote
Old 11th December 2008, 15:44   #3  |  Link
Yes, it's the post processing detecting the stripes as interlacing. For Telecide, set post=0. Or use an override on that section to disable it.
Old 11th December 2008, 16:01   #4  |  Link
elguaxo
elguaxo's Avatar
it works!
I haven't tried Telecide, but tfm(pp=0).tdecimate() works fine.
thanks again!
artifacts, ivtc, moiré
