Old 5th September 2008, 01:10   #1  |  Link
wst
Is there a more *correct* way to IVTC? I can't seem to find one.
Hello friends - long time reader, first time poster; I'll try to keep this short. And though I have scoured the forums, I apologize in advance for my poor scouring skills if this has already been covered.
Legit TV-show DVD. DGIndex reports the VOB is NTSC, interlaced, 29.97 footage - however, inspecting frame-by-frame reveals a 3:2 (p,p,p,i,i,) pulldown in the video.
[Tangential confusion: Please correct me if this is wrong, but I was under the impression that pulldown should be seen in telecined material from a 24p source, and threrefore the frames should be flagged as such (just like a movie, or other 24p TV shows like Arrested Development that do get recognized as film in DGIndex), so it should be fairly trivial to get back the 24p source. Confused, I chose the IVTC route.]
Very straightforward IVTC script...
video=MPEG2source("episode_honor-flags.d2v")
audio=NicAC3Source("episode_honor-flags.ac3")
audiodub(video,audio)
Telecide()
Decimate()
...and I'm noticing some occasional combing (mostly scene changes), and regular residual combing on smaller scene details. I increased combing sensitivity with Telecide(vthresh=40) (default is 50) - this mostly eliminated scene-change artifacts, but I still see the residual combing in frames.
Main confusion: So the output looks pretty good, but what I guess I don't understand is why I had to make that adjustment at all - for example, what will a DVD player hooked up to a progressive TV (basically every HDTV) do? This is a very common setup and I've never noticed combing artifacts when viewing this way. Does it just *know* better than Telecide() how to handle the interlaced parts of the video? And if the source was really 24p, why is this non-trivial? Am I just missing something?
The final output will be on an HDTV (eventually one that supports native 24p) through some kind of HTPC/streaming setup that I haven't decided on yet. Is there a more recommended way do what I'm trying to do?
Thanks!
wst is offline   Reply With Quote
Old 5th September 2008, 01:16   #2  |  Link
thetoof
Sleepy overworked fellow
Looks like hard pulldown to me.
AnimeIVTC(mode=1)
AnimeIVTC() - v2.00
-http://boinc.berkeley.edu/-
Let all geeks use their incredibly powerful comps for the greater good (no, no, it won't slow your filtering/encoding :p)
thetoof is offline   Reply With Quote
Old 5th September 2008, 01:34   #3  |  Link
You need to post a link to an unprocessed source sample of a problematic section if you want us to do anything other than guess.
Old 5th September 2008, 03:43   #4  |  Link
wst
Good point, neuron2 - how many frames is enough? 100 okay?
Old 5th September 2008, 03:47   #5  |  Link
thetoof
More than enough. Simply provide us the section that is the trickiest to IVTC.
AnimeIVTC() - v2.00
Old 5th September 2008, 04:51   #6  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
I'm waiting for the sample
But, without seeing it - here's my brute-force filterchain that usually works perfectly:
TFM.Vinverse.TDecimate
Vinverse comes from the DLL, not the older version that was part of MVBob (I think???)
~MiSfit
Old 5th September 2008, 04:58   #7  |  Link
wst
I'm actually remote to my main computer and was having cutting the VOB, so pardon the 10MB file - best I could do quickly:
http://www.mediafire.com/?aibkmretaek
thetoof, it was difficult to make cuts remotely connected, so i'll have to repost in the morning if this doesn't provide anything useful. so this desn't include the clearly noticeable artifacts i mentioned, but i bet the peoples' faces in the crowd have minor combing artifacts if you ivtc look closely. i know that's splitting hairs, but if this was telecined from a 24p source, shouldn't it *always* IVTC perfectly back to 24p?
Old 5th September 2008, 07:13   #8  |  Link
thetoof
As I thought, it's hard telecine.
From this (kinda old, but still very useful) guide: "Hard" 3:2 pulldown. 3:2 pulled down field pattern but encoded as interlaced (pulldown was applied prior to MPEG encoding). Often you have a complete movie that is hard pulldowned; it can be IVTC'ed after doing non-FORCE FILM, but cannot be FORCE FILM'ed.
mpeg2source("wonky_telecine.d2v")
animeivtc(mode=1,aa=0)
AnimeIVTC() - v2.00
Old 5th September 2008, 09:01   #9  |  Link
Blue_MiSfit
Any particular reason to use AnimeIVTC versus plain old TFM.Vinverse.TDecimate?
It worked perfectly fine on this sample
~MiSfit
Old 5th September 2008, 12:21   #10  |  Link
Nightshiver
Quality Freak
Because it works? Any particular reason to use TFM.Vinverse.TDecimate versus AnimeIVTC? It's a matter of preference, so everyone should be entitled to give whatever explanation they want instead of a universal one. Variety is good.
Nightshiver is offline   Reply With Quote
Old 5th September 2008, 12:47   #11  |  Link
martino
masktools2 (ab)user
martino's Avatar
I think he was asking for actual reasons why one should use a over b and not a counter question...
My x264 builds (win32 only up to rev965) and useless AviSynth functions -- use at your own risk
martino is offline   Reply With Quote
Old 5th September 2008, 15:50   #12  |  Link
wst
Okay, so it's definitely a hard pulldown - thank you for the confirmation. So a hard pulldown will never have flags.
Can you guys give some more current feedback, or opinions based on your own experiences with different IVTC algorithms? A lot of the info floating around is dated and fairly limited (most of what I read said Decomb IVTC was the most advanced) - or specefic to anime.
Bonus: Does anyone know what DVD playing hardware will do with hard pulldown'd content? Like, does it IVTC? My crappy old DVD player seems to be smart enough to get good enough looking output to my progressive HDTV.
Thanks again for the feedback. I'm going to run some tests with your recommended IVTC algos and post the results.
Old 5th September 2008, 16:34   #13  |  Link
um3k
I think most progressive DVD players do IVTC the hard way regardless of hard or soft pulldown. So hard pulldown will give the same results as soft pulldown. Of course, my cheap Coby DVD player just dumb-bobs everything, but anyways...
um3k is offline   Reply With Quote
Old 5th September 2008, 18:01   #14  |  Link
wst
um3k, what does it mean to IVTC the "hard way"? By bobbing?
thetoof, your animeIVTC filter looks excellent. Though it took a while to get it working (my plugins are in a networked location so I can't autoload) - think you used enough plugins? Either way, it automatically handled the areas I was having problems with - thanks! (I assume aa is only on for anime?)
Does animeIVTC do anything with noise - like, is there any reason to not deblock (cpu=4) when ingesting the d2v and/or a light STMedianFilter(5,10,3,6) at the end? I think whoever encoded these DVDs added gaussian noise to the source to prevent gradient/low-freq blocking on their crappy encoder - I'm trying to filter some of that out, and I don't want to lose a lot of detail by accident if your script is filtering as well.
Blue, I'm going to try out your suggestion and see how it stacks up to animeIVTC.
Thanks again for all the info.
Old 5th September 2008, 20:38   #15  |  Link
wst
Blue's suggestion, TFM.Vinverse.TDecimate, also performs swimmingly in comparison to my original script, and automatically nabbed all of the problem areas. Thanks! I'm actually having trouble telling the two IVTC's outputs apart. So, I now have the opposite problem: two ways to do this. I know this is often a personal preference, but - CPU performance aside - are there any advantages/disadvantages to using one of these two IVTC strategies over the other?
Old 5th September 2008, 21:09   #16  |  Link
Blue_MiSfit
My reason for asking was simply speed. AnimeIVTC is a great script, and it's extremely powerful and easy to use for more demanding IVTC.
But, why bother with all that overhead. I assume it's slower than simple TFM.Vinverse.TDecimate (though I don't really know).
What matters is that you got good results in the end!
~MiSfit
Old 6th September 2008, 14:43   #17  |  Link
thetoof
Main reason why to use AnimeIVTC? It often leads to a better output, though it's slower than the usual methods (12 secs vs 8 secs to process your sample).
aa is for anti-aliasing (not needed for your clip)
It does nothing with noise (but aa=4 will in the next version)
MiSfit's suggestion is a tad worse than animeivtc(mode=1,aa=0,precision=0) and what I suggested you does this + kill the combing that could have gone through with vinverse.
It's true that the output is very similar, but when you compare some tricky frames, you'll see a difference.
This is frame #249 (after IVTC):
tfm().vinverse().tdecimate()
animeivtc(1,aa=0)
AnimeIVTC() - v2.00
Old 6th September 2008, 19:56   #18  |  Link
Blue_MiSfit
Hmm.. It's a mixed bag for me.
While I prefer AnimeIVTC's output, it doesn't seem true to the source.
From an IVTC perspective, there's less aliasing on the light panel on the ceiling (very cool, how was that accompllished?)
But, your version is darker and seems to be slightly denoised.
I prefer the result, visually, but it seems less accurate.
~MiSfit
Old 7th September 2008, 03:42   #19  |  Link
thetoof
nnedi and tdeint are the big helpers here against aliasing
Actually, I find animeivtc's output more accurate... look how the two lines of writing on the door become a big white sploch with tfm.vinverse.tdecimate
For the "denoising" (I see it more as deblocking for this clip), I think it's due to tdeint that blends the frames of the internally bobbed clip, but still, it helps detail recovery from a frame infested by blocks, so I don't see it as a bad thing.
Yes, it's darker (could also be due to the blending of two frames in a section where luma changes a lot bewteen every one of 'em), but it looks very good temporally... (nothing ugly comes out during playback)
AnimeIVTC() - v2.00
Old 7th September 2008, 06:53   #20  |  Link
Blue_MiSfit
I'm not saying it looks bad!
I think it looks fantastic!
The issue (to me) is that I think IVTC should just be IVTC. Deblocking and so forth should happen in separate steps. Just me
NNEDI+TMM+TDeint are fantastic in this scenario!
~MiSfit
dvd, interlaced, ivtc, ntsc, pulldown
