Old 17th December 2008, 09:19   #41  |  Link
Floatingshed
Well, I had a good play around with this last night and I'm very impressed, the script worked very well on a section of telerecording from 1963.
The main problem now is the inherant film faults, which are suddenly much more noticeable.
Does anyone know what to use to remove film dirt & spots? I've tried the various filters but the results were not great. Software that allows manual "cloning" of a small area of picture from one frame to another would be ideal as most problems are on one frame but not the next.
Thanks, Andy.
Floatingshed is offline   Reply With Quote
Old 17th December 2008, 09:55   #42  |  Link
steptoe
steptoe's Avatar
You could have a look at MCTemporalDenoise or MCSpuds
Both use motion compensation to try and remove just noise or grain but are incredibly slow as they use a lot of external filters and functions to achieve the results but if quality is what you want give them a try
They also both use Removegrain and FFT3DFilter which a lot of people recognise as being pretty good at what they achieve along with various despot and other noise/grain filters
http://forum.doom9.org/showthread.php?t=139766
http://forum.doom9.org/showthread.php?t=131279
steptoe is offline   Reply With Quote
Old 17th December 2008, 11:09   #43  |  Link
2Bdecided
I asked about that before. It didn't seem to exist. The BBC have something called scratch box that does exactly what you say - you draw over the bad areas and it copies them from the previous/next frame. You'd think it would be trivial on a PC (compared to the kind of processing AVIsynth does), but I haven't found the software yet!
Cheers,
David.
2Bdecided is offline   Reply With Quote
Old 17th December 2008, 12:38   #44  |  Link
Floatingshed
Originally Posted by 2Bdecided View Post
You'd think it would be trivial on a PC.
Precisely. Hopefully some clever chap will come up with something. I'd much rather manually clean things up than leave a filter doing it automatically for a week or two!
Old 17th December 2008, 13:28   #45  |  Link
Floatingshed
JohnMeyer said: Restore the sound. I do this for a living and there are lots of tricks to add "life" to muddy sound.
I could do with some pointers here too! Sorry!
I use cooleditpro for most audio operations and I know my way around it very well (a career in radio helped with that!) but production not restoration is my forte.
These kinescopes/telerecordings have very poor optical (mostly 16mm) sound which has a very harsh middley sound with excessive muddy bass and loads of distortion. Lovely.
What do you do with the sound?
Old 17th December 2008, 18:15   #46  |  Link
johnmeyer
Look for my username and "despot." I think I posted my script before. It will give you some good starting points. Here's a "before" clip:
Before Dust Removal
and after:
After Dust Removal
Ignore the dust on the first two seconds of the "after" clip (long story). As you'll see, this technique gets rid of about 80% of the dust (and without removing the tennis ball!).
As for sound, if you have Nero, you probably have the wave editor. The key tool to try is "Band Extrapolation."
Old 20th December 2008, 16:44   #47  |  Link
Floatingshed
Hello again,
i'm still trying to understand this script...
What is going on here:
#use undegrained clip for final output
last.MVFlowFps(backward_vec, forward_vec, num=50, den=1)
Is the comment correct and if so why wouldn't you use the degrained clip?
Sorry to sound stupid but its all very new.
Thanks,
Andy.
Old 20th December 2008, 20:05   #48  |  Link
AnnaFan777
I wonder how could you video geeks still use 60i instead of 30i ?
24p = 24 progressive frames per sec. (film)
30i = 30 interlaced frames per sec = 60 fields interlaced (ntsc)
60p = 30i Bobbed (mostly likely)
where did the 60i come from?
60i = 120 field interlaced.
I'm sure you don't mean that.
AnnaFan777 is offline   Reply With Quote
Old 20th December 2008, 20:30   #49  |  Link
Wilbert
Some people use 60i to denote 60 fields a second (like the original poster), while others use 30i for that.
Old 21st December 2008, 04:59   #50  |  Link
AnnaFan777
60fd might be better.
Doesn't "i" indicate "interlaced"?
I remember a few years back, people still used "30i/29.976i" (from the textbook)
I think "60i" starts from those Sony/JVC specs
They think 60i is sexier, more impressive than 30i for end users.
now this is confusing, sony's 60i means interlaced ntsc video,
but 60i here apparently refers to progressive materials.
and both are wrong
Old 21st December 2008, 13:15   #51  |  Link
Wilbert
Yes, indeed.
No, it means interlaced.
Old 23rd December 2008, 01:09   #52  |  Link
Mug Funky
interlace this!
Mug Funky's Avatar
you could say "60" refers to the timebase in Hz rather than the framerate.
then the p or i denotes whether this timebase is expressed in fields per second or progressive frames per second.
60i is the standard way of saying 30fps, interlaced. it's not just marketing bunk either, as the EBU and SMPTE standards also use this terminology.
@ johnmeyer: the last bit of kine i transferred must have been done on a newer machine. fields were visible when i zoomed in my TK, but i didn't have enough time alone with the film to try to line it up perfectly. also, there was natural blurring, probably in the lens used (it was gaussian-ish). weave isn't too bad on modern cameras, and not a problem at all with pin-registered scanners (unless the film is still soft from cleaning). but of course not much kine has been done with modern cameras the most recent bit of kine i can think of is the TV series "Frontline", where the documentary-style bulk of the program was shot on hi8 and kine'd to 16mm, then TK'd back to beta SP... sort of like a very expensive deinterlace.
Old 23rd December 2008, 02:26   #53  |  Link
NerdWithNoLife
NerdWithNoLife's Avatar
Instinctively, I want to disagree (I was trained to think that 30i is 30 interlaced frames per second), but I can see how after using double weave for example, it's kinda sorta 60i, though it should effectively be the same as 30i. But if you were to separate the fields of double weaved "60i" it would be 120 fields per second, with every 4 being identical. And fields aren't interlaced, right? So calling it 60i while referring to fields is a bit odd to me. You've destroyed my education - I don't know what to think anymore!
f=33
NerdWithNoLife is offline   Reply With Quote
Old 23rd December 2008, 03:01   #54  |  Link
johnmeyer
I'm not sure whether anything has been transferred via the Kinescope process since the early 1970s. There are definitely a LOT of movies being shot on video and then transferred to film, but those video to film transfers (including those done from earlier formats like Hi8) are NOT done using a Kinescope. Instead, they are transferred using a film recorder. This device is similar to those used years ago to make 35mm slides for presentations. The usual method is to first resample (from 29.97 to 24) and then deinterlace the video (if you didn't shoot 24p or 25p). Then, each frame is displayed on the film recorder screen, and a photograph is made onto 16mm or 35mm film. Thus, the deinterlacing and frame decimation are done in software. The film recorder display is not a raster display, so there will be no raster lines.
As for the gate weave, it is still pretty obvious even in modern Hollywood movies. If you look at a static title, you'll see it bounce around. If you ever watch the old movies on the TCM channel, they all exhibit gate weave, even though they have been transferred to video from film using a Rank scanner, which provides near-perfect registration. The problem is that the cameras don't have the luxury of advancing the film slowly, but instead have to run at 24 fps. There is just too much stretch, pull, wobble, bounce, etc. in that process, and it only takes a fraction of a millimeter to result in fairly significan movement up there on the big screen.
Raster lines should not be evident in kinescopes because back when this technology was used, a "wobble" was added to each scan line to make it vary up and down slightly. This had the effect of erasing the lines between fields. There were other techniques used, but this is the one most commonly mentioned.
Old 24th December 2008, 09:58   #55  |  Link
mikeytown2
Resize Abuser
mikeytown2's Avatar
Here's a post I made on this subject
http://forum.doom9.org/showthread.ph...19#post1213819
mikeytown2 is offline   Reply With Quote
24p, 60i, ivtc, kinescope, mvtools
