Old 24th June 2007, 15:32   #1  |  Link
buzzqw
HDConvertToX author
AutoMen (Mini Mencoder Gui) 6 beta 06/10/2010)
Hi all
here the new AutoMen
Full package http://www.64k.it/andres/data/automen/AutoMen6_beta.rar
update http://www.64k.it/andres/data/automen/AutoMen_beta.exe
linux build http://www.64k.it/andres/data/autome...en6_x86.tar.gz
Source avaiable on request (Purebasic4)
Licensed on GPL3
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 24th June 2007, 21:01   #2  |  Link
DIEGO7-5
Nice tool buzzqw!
Tried to back up an episode of King of Queens with it (PAL, 25 FPS, DVD-Source, interlaced)
Add automatic deinterlacing & a queue list and i think you´re done :-) Shutdown when done would also be very welcome :-)
DIEGO7-5 is offline   Reply With Quote
Old 25th June 2007, 03:29   #3  |  Link
killerhex
doesn't encode to wmv
its starts then shuts down
killerhex is offline   Reply With Quote
Old 25th June 2007, 04:29   #4  |  Link
leiming2006
leiming2006's Avatar
good job buzzqw.
I'll try to use it to encode flv files.
leiming2006 is offline   Reply With Quote
Old 25th June 2007, 07:31   #5  |  Link
buzzqw
HDConvertToX author
Update 0.2 www.64k.it/andres/data/a/AutoMen02.exe (65.5kb)
fixed: wmv8 encoding
added: mpeg2 encoding
fixed: the encoded file name is now based on input file name+_automen (es. input file is jewel.avi -> on mp4 will be named as jewel_automen.mp4)
@killerhex
thank for the bug (but another time please say something about testing wmv8...)
BHH
Old 25th June 2007, 15:27   #6  |  Link
weaver4
I find the File Size and Video Quality parameters a little confusing.
I think I would rather see a selection that allows you to chose if you want to encode by File Size or Video Quality. If you select Video Quality it ecodes single pass and the slider sets the quantizer. If you select File Size the slider lets you set the filesize.
Encode by Filesize
--350M
--700M
--1.4G
--4.7G
--Custom....
Encode by Quality
--Poor (Small)
--Fair
--Good
--Very Good
--Excellent
I love the concept!
weaver4 is offline   Reply With Quote
Old 25th June 2007, 16:19   #7  |  Link
buzzqw
HDConvertToX author
this division is false, you could have a very big file while quality is simply trash.. and also have small file with awesome quality
I don't want to add a Quality based encoding, for this simply select quality 6 is always the "near best" settings for 1 pass encode
in next update i added queue! (a very basic queue fuction)
BHH
Old 25th June 2007, 18:59   #8  |  Link
Schrade
Schrade's Avatar
It's possible that you have left out the MediaInfo command line utility. This is exactly what happened to me when I got too eager and forgot to copy that into the AutoMEn directory.
@buzzqw:
Is there any chance we could get a choice of resolution? It's a bit more of a common sense thing when helping choose settings.
Schrade is offline   Reply With Quote
Old 25th June 2007, 19:21   #9  |  Link
buzzqw
HDConvertToX author
@Schrade
done in next update ! (thanks for the hint!)
BHH
Old 25th June 2007, 19:21   #10  |  Link
weaver4
BHH
I believe that was my point: you select either File Size and select a Size or you select Video Quality and select the quantizer.
I am not sure I know what to do with the File Size selection once I select the quality setting of 6 (one pass encoding). Or is the one pass encoding not Constant Quality?
Old 25th June 2007, 19:31   #11  |  Link
buzzqw
HDConvertToX author
no pass is crf/qp/cq or what ever constant quality encoding, all encoding are or 1 pass or 2 pass at bitrate based on final size
here the point! i haven't added fixed quant encoding (and maybe i will never add it)
choose your fixed final size, select your profile and automen (and mencoder) will be its best to reach this size, or in 1 pass bitrate based encoding or in 2 pass bitrate based encoding
BHH
Old 25th June 2007, 19:47   #12  |  Link
weaver4
BHH
Now I get it! I assumed that single pass was constant quality like avi.net, Dr Divx and autogk. Now your comment makes perfect sense.
Old 25th June 2007, 20:04   #13  |  Link
buzzqw
HDConvertToX author
@weaver4
also in next update the resize slide will fuction even with HD material, basically the first half slide is for reduction, the second half for enlarging. The step will be by 16 pixel
BHH
Old 26th June 2007, 00:03   #14  |  Link
Schrade
Schrade's Avatar
@Schrade
BHH
Very nice! Thanks.
Now I have another request which might not be in line with how you want the app to exist but I'll throw it out there anyway.
Devices like the PSP can only decode AVC at a certain level/profile. Any chance you could add something to lock AVC to certain levels/profiles? Like.. the PSP is supposed to support Main Profile now and I believe its level is 3.
Old 26th June 2007, 06:58   #15  |  Link
buzzqw
HDConvertToX author
@Schrade
done! as in AutoMKV/MeGui profile's , i set the level to 2.1
BHH
Old 26th June 2007, 14:32   #16  |  Link
buzzqw
HDConvertToX author
here the update! 0.3 http://www.64k.it/andres/data/a/AutoMen03.exe 80.5 KB
added: queue
fixed: better ff4 profile
fixed: better width management
added: dump stream
added: play queue
added: shutdown
about dump stream: copy in clipboard a link to mms/rtps stream , click on dump (the small D at bottom), mplayer will connect to internet and download it
about play queue: i have queue, i have mplayer.. whu not add playing fuction?
BHH
Old 26th June 2007, 16:19   #17  |  Link
Sirber
retired developer
Sirber's Avatar
@buzzqw
Sorry for the OT, but how do you do autocrop with mencoder? Thanks!
Detritus Software
Sirber is offline   Reply With Quote
Old 26th June 2007, 16:38   #18  |  Link
buzzqw
HDConvertToX author
i read the stdout of
mplayer.exe -ss 00:00:XX -vf cropdetect -vo null -ao null -endpos XX+5
where XX is a random time (not beginning) of playing duration
isn't perfect.. but .. i hope for no errors..
it can be reiterated with several samples...
BHH
Old 26th June 2007, 16:46   #19  |  Link
Sirber
retired developer
Sirber's Avatar
cool! so you launch mencoder only to get that info, then encode with detected values.... interresting thanks!
Detritus Software
Old 26th June 2007, 18:22   #20  |  Link
buzzqw
HDConvertToX author
yes!
it's only a 5 seconds analisys so it's fast and from my sample tested accurated
as you said from stdout i parse the vf crop values, and if not present i set it to 0 (-vf crop=0:0:0:0)
BHH
automen, ffmpeg, handbrake, mencoder, x264
