27th October 2004, 16:10 | #2961 | Link |
Mr. Sandman
Installed 1.02... tonigth i'll finish to encode.
V3ULR compressibility is almost the same as Jawor's 1CD.
27th October 2004, 19:15 | #2963 | Link | |
I'm afraid we've to stop
New matrix is clearly better (and will be even more) and removegrain is a very good filter as well. The only variable that was never tested widely is resizer.
Gordian Knot Family: Gordian Knot: website, download Auto Gordian Knot: Website and download, tutorial, FAQ |
27th October 2004, 19:17 | #2964 | Link |
any Intel Centrino users here ?
Got report that RemoveGrainSSE2 crashes on it. Anyone has this issue?
27th October 2004, 19:54 | #2965 | Link | |
27th October 2004, 20:08 | #2966 | Link |
I just remembered since you mentioned a CPU specific part of AutoGK ..
http://allies.freezope.org/ host optimized builds of Xvid 1.02 for Athlon XP and Athlon Thunderbird processors that are faster than the ordinary builds. I haven't done any proper comparisons but I get really good speeds with this optimized build. |
27th October 2004, 23:39 | #2967 | Link |
Sharp Matrix not used???
I tried to reencode the movie I commented about a few replies ago, and put .sharpmatrix into the VIDEO_TS directory with the .vobs, but Autogk's log reads:
[10/27/2004 8:45:11 AM] Compressibility percentage is: 44.28 [10/27/2004 8:45:11 AM] Using softer matrix. [10/27/2004 8:45:11 AM] Chosen resolution is: 640x368 ( AR: 1.74 ) [10/27/2004 8:45:11 AM] Predicted comptest value is: 52.95 It's hard to tell what was actually used because I deleted the other encodes and can't compare. Do you think this just a logging error, or did it for some reason not use the sharp matrix even though I had the control file in place?
Cheers, The REAL Joe |
28th October 2004, 10:40 | #2968 | Link | |
Re: Sharp Matrix not used???
I'd check if the file was really there before encoding started.
28th October 2004, 10:42 | #2969 | Link | |
28th October 2004, 16:19 | #2970 | Link |
Mr. Sandman
You can't but the user can...
Xvid codec: |_ Install Xvid x.x (standard) |_ Install Xvid x.x for AMD Athlon |_ Install Xvid x.x for AMD Athlon XP with SSE
28th October 2004, 16:30 | #2971 | Link |
1) its too much to bundle
2) it might not be as reliable as koepi's (in terms of when they are compiled and continue to be compiled)
28th October 2004, 17:09 | #2972 | Link |
Mr. Sandman
Agreed. Also the speed gain is lower than 3%...
28th October 2004, 17:15 | #2973 | Link |
HKLM\\Hardware\\Description\\System\\CentralProcessor\\0 contain useful keys that will tell what type of CPU processor 0 is ( there are other entries under 1 , 2 , 3 .. depending on how many cpu's are in the system , but they should all be the same )
The optimized codec I use compresses to 206 kb .. probably would be less if it was archived with other builds of Xvid since the files look alike and can thus be compressed to a smaller overall. But download links to other good builds from AutoGK's download page would also go a long way. |
28th October 2004, 17:18 | #2974 | Link | |
Actually in reserve
Done encode on 1 source with hard compressibility to compare. Results are 8% gain for the Xp build on comptest (9.53 to 10.33fps) but marginal on first (33.55 to 33.89) and second pass (24.45 to 24.83). Hi to all
Having a problem with AutoGK? Read & use the FAQ & MORE FAQ first Want to exchange on AutoGK? try doom10.org In reserve (inactive) for an undefined period of time. |
28th October 2004, 18:36 | #2975 | Link | ||
Gordian Knot Family: Gordian Knot: website, download Auto Gordian Knot: Website and download, tutorial, FAQ Last edited by len0x; 28th October 2004 at 18:41. |
28th October 2004, 18:42 | #2976 | Link | |
Actually in reserve
Re: Re: Re: Subjective Quality Test (1 movie, v-1.60 vs 1.70)
Hello Taurus & Lenox
New to the forum, autogk and encoding I was wondering if the lanczos4/lanczos question applies to my problem ? Quote:
The result is medium to better but I have distorded lines (jaggies?) in the original and the encode (see pics). I believe it comes from the interlaced material (see log) and tried to change the kerneldeint treshold to 3 or 30 with no improvement. I have no other clue on the problem and hope you have good suggestions to offer. Enclosed pictures from the original (mpg2 720w) and the avi (xvid 512w) Also the log of one of my trials encode: [24/10/2004 17:27:47] AutoGK 1.70b [24/10/2004 17:27:47] OS: WinXP (5.1.2600).2 [24/10/2004 17:27:47] Job started. [24/10/2004 17:27:47] Input dir: F:\FILMS\DVDVOLUME\VIDEO_TS [24/10/2004 17:27:47] Output file: F:\FILMS\DVDVOLUME\Mariage Heydy.avi [24/10/2004 17:27:47] Audio: Unknown language [24/10/2004 17:27:47] Subtitles: none [24/10/2004 17:27:47] Codec: XviD [24/10/2004 17:27:47] Target size: 1493Mb [24/10/2004 17:27:47] Custom resolution settings: minimum width of 560 pixels [24/10/2004 17:27:47] Custom audio settings: VBR MP3 with average bitrate: 128Kbps [24/10/2004 17:27:47] Started encoding. [24/10/2004 17:27:47] Demuxing and indexing. [24/10/2004 17:29:57] Processing file: F:\FILMS\DVDVOLUME\VIDEO_TS\VTS_01_PGC_01_1.VOB [24/10/2004 17:29:57] Processing file: F:\FILMS\DVDVOLUME\VIDEO_TS\VTS_01_PGC_01_2.VOB [24/10/2004 17:29:57] Processing file: F:\FILMS\DVDVOLUME\VIDEO_TS\VTS_01_PGC_01_3.VOB [24/10/2004 17:29:57] Processing file: F:\FILMS\DVDVOLUME\VIDEO_TS\VTS_01_PGC_01_4.VOB [24/10/2004 17:29:57] Processing file: F:\FILMS\DVDVOLUME\VIDEO_TS\VTS_01_PGC_01_5.VOB [24/10/2004 17:29:57] Source aspect ratio: 4:3 [24/10/2004 17:29:57] Source resolution: 720x576 [24/10/2004 17:29:57] Found PAL source. [24/10/2004 17:29:57] Analyzing source. [24/10/2004 17:37:55] Source has percentage of interlacing in motion areas: 72,82 [24/10/2004 17:37:55] Source is considered to be interlaced. [24/10/2004 17:37:55] Found 145848 frames [24/10/2004 17:37:55] Encoding audio. [24/10/2004 17:38:11] Audio size: 1,855,488 bytes (1.77 Mb) [24/10/2004 17:38:11] Overhead: 5,833,984 bytes (5.56 Mb) [24/10/2004 17:38:11] Video size: 1,557,834,496 bytes (1485.67 Mb) [24/10/2004 17:38:11] Running compressibility test. [24/10/2004 17:38:11] Writing the following script to F:\FILMS\DVDVOLUME\agk_tmp\Mariage Heydy_comptest.avs =========================================================== LoadPlugin("C:\PROGRA~1\AutoGK\DGMPGDec\DGDecode.dll") LoadPlugin("C:\PROGRA~1\AutoGK\filters\autocrop.dll") LoadPlugin("C:\PROGRA~1\AutoGK\filters\RemoveGrain.dll") LoadPlugin("C:\PROGRA~1\AutoGK\filters\kerneldeint.dll") movie = mpeg2source("F:\FILMS\DVDVOLUME\agk_tmp\Mariage Heydy.d2v") cropclip = autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=10,aspect=0,threshold=34,samplestartframe=0) fixed_aspect = 1.06666666666667 c_width = width(cropclip) c_height = round(height(cropclip) / fixed_aspect) input_par = float(c_width)/float(c_height) input_par = input_par > 1.4 ? input_par : (4.0/3.0) out_width = 704 out_height = round(float(out_width) / input_par) hmod = out_height - (floor(out_height / 16 ) * 16) out_height = (hmod > 4) ? (out_height + (16 - hmod)) : (out_height - hmod) new_aspect = (float(out_width) / float(out_height)) / fixed_aspect KernelDeInt(movie,order=0,sharp=true) autocrop(mode=0,wmultof=4,hmultof=4,samples=10,aspect=new_aspect,threshold=34,samplestartframe=0) Lanczos4Resize(out_width,out_height) RemoveGrain(mode=2) SelectRangeEvery(300,15) =========================================================== [24/10/2004 17:58:12] Duration was: 20 minutes 0 seconds [24/10/2004 17:58:12] Speed was: 6,07 fps. [24/10/2004 17:58:12] Compressibility percentage is: 45,15 [24/10/2004 17:58:12] Chosen resolution is: 576x432 ( AR: 1,33 ) [24/10/2004 17:58:12] Predicted comptest value is: 67,45 [24/10/2004 17:58:12] Running first pass. [24/10/2004 17:58:12] Writing the following script to F:\FILMS\DVDVOLUME\agk_tmp\Mariage Heydy_movie.avs =========================================================== LoadPlugin("C:\PROGRA~1\AutoGK\DGMPGDec\DGDecode.dll") LoadPlugin("C:\PROGRA~1\AutoGK\filters\autocrop.dll") LoadPlugin("C:\PROGRA~1\AutoGK\filters\RemoveGrain.dll") LoadPlugin("C:\PROGRA~1\AutoGK\filters\kerneldeint.dll") movie = mpeg2source("F:\FILMS\DVDVOLUME\agk_tmp\Mariage Heydy.d2v") cropclip = autocrop(movie,mode=0,wmultof=4,hmultof=4,samples=10,aspect=0,threshold=34,samplestartframe=0) fixed_aspect = 1.06666666666667 c_width = width(cropclip) c_height = round(height(cropclip) / fixed_aspect) input_par = float(c_width)/float(c_height) input_par = input_par > 1.4 ? input_par : (4.0/3.0) out_width = 576 out_height = round(float(out_width) / input_par) hmod = out_height - (floor(out_height / 16 ) * 16) out_height = (hmod > 4) ? (out_height + (16 - hmod)) : (out_height - hmod) new_aspect = (float(out_width) / float(out_height)) / fixed_aspect KernelDeInt(movie,order=0,sharp=true) autocrop(mode=0,wmultof=4,hmultof=4,samples=10,aspect=new_aspect,threshold=34,samplestartframe=0) Lanczos4Resize(out_width,out_height) RemoveGrain(mode=2) =========================================================== [24/10/2004 19:37:17] Duration was: 1 hour, 39 minutes 5 seconds [24/10/2004 19:37:17] Speed was: 24,53 fps. [24/10/2004 19:37:18] Expected quality of first pass size: 61,90 [24/10/2004 19:37:18] Running second pass. [24/10/2004 21:51:27] Duration was: 2 hours 14 minutes 9 seconds [24/10/2004 21:51:27] Speed was: 18,12 fps. [24/10/2004 21:51:27] Job finished. I am very fond of autogk and do appreciate all the efforts improving it. All the best Did Oops... the original mpg2 pic is missing, new attachment: Edit2: no luck with the mpg2 picture
Having a problem with AutoGK? Read & use the FAQ & MORE FAQ first Want to exchange on AutoGK? try doom10.org In reserve (inactive) for an undefined period of time. Last edited by BigDid; 23rd August 2006 at 02:07. |
28th October 2004, 18:50 | #2977 | Link | |
Re: Re: Re: Re: Subjective Quality Test (1 movie, v-1.60 vs 1.70)
(and for DV sources its quite common to have such ladder step lines if I'm not mistaken).
28th October 2004, 21:12 | #2978 | Link | ||
Mr. Sandman
So i will try to find a good compromise between Intra and Inter-Frame matrices coefficients but it requires some time... Saturday or sunday it will be ready. However here's a second try (beta 2): Code:
8 9 10 11 12 14 16 18 9 10 11 12 14 16 18 20 10 11 13 15 17 19 21 22 11 12 15 17 20 22 24 26 12 14 17 20 23 25 28 31 14 16 19 22 25 29 34 40 16 18 21 24 28 34 44 52 18 20 22 26 31 40 52 74 16 16 16 16 17 18 21 24 16 16 16 16 17 19 22 25 16 16 17 18 20 22 25 29 16 16 18 21 24 27 31 36 17 17 20 24 30 35 41 47 18 19 22 27 35 44 54 65 21 22 25 31 41 54 71 86 24 25 29 36 47 65 86 115 Quote:
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 29th October 2004 at 00:44. |
29th October 2004, 22:45 | #2979 | Link | |
Actually in reserve
Re: Re: Re: Re: Re: Subjective Quality Test (1 movie, v-1.60 vs 1.70)
When I will have the time I will try to dig, learn, use others progs like avisynth filtering, vdubmod with xvid settings but not at the moment, too much at once. In this context I will appreciate if/when filtering (whatever the method) become available in AutoGK but I can understand that it is not the highest priority at the moment. All my wishes for continuing developping this very good application. Did
30th October 2004, 07:20 | #2980 | Link | |
Re: Re: Sharp Matrix not used???
.sharpmatrix Created: Wednesday, October 27, 2004, 8:19:29 AM ->from the AutoGK.log: [10/27/2004 8:19:50 AM] AutoGK 1.70b [10/27/2004 8:19:50 AM] OS: Win2000 (5.0.2195).2 [10/27/2004 8:19:50 AM] Job started. Filename appears correct, and was created before encoding started.
